Correct Sort Numbers Stored As Text
Oct 06, 2006 Oct 06, 2006
I have some document numbers stored as text values that I would like to sort by in the correct order. However, what I'm getting is 1-101, 1-10A, 1-11, 1-14, 1-17A, 1-17A.i, 1-19, 1-2, 1-21, 1-30, 1.35, 1.47, 1-4-A, 1-5, 1-7, 1-A, 1-B, 1-C. These are the document's ID so that is why the inconsistancy. I wish they would have done better with this, but these ar old docs and and all I have to work with. This is just a small set. I have many more begining with 2's, 3's, and so on.
I was wondering how can I get these to be sorted in the correct order from smallet to largest. I.E.
1-2, 1-4-A, 1-5, 1-7, 1-10A, 1-11, 1-14, 1-17A, 1-17A.i, 1-19, 1-21, 1-30, 1.35, 1.47, 1-101,1-A, 1-B, 1-C
The ABC can be at the beggining or end, does not matter just as long as the numbers are correct.
Is this at all possible. Thanks for the help.
Advanced techniques
373
Community Beginner , Oct 12, 2006 Oct 12, 2006
It is stored in a MS Access DB. I think I figured out how to get things in the correct order. Since there is an inconsistancy in the naming convention, I made a way to make it consistent. I have 2 columns, 1 with the document ID number and the other with just the number of the document (1-17A would have 17 for the second column.) This way I can sot first based on the second column since they are all numeric and the sort for the first column of I have duplicated in the second column.
For example...
Advisor ,
These are stored in a DB, right?
It is very important to know which one (Access, MS SQL. etc.) because the needed syntax is DB specific.
Also is "1-101' one id or a range?
For example 1-17A and 1-17A.i would both have 17 in the second column, but by sorting by both columns, the order is correct and 1-17A comes before 1-17A.i. For dcoument ID's that don't have a number and rather a letter such ast 1-A, I assing a number of 1000 for A, 1001 for B and so on. This way they too have a number and will usually appear at the end of the list.
Oct 08, 2006 Oct 08, 2006
My first concern would be the inconsistent way the values are stored:
1-2
1-4-A
1-17A
1-A
1.35
Depending on how you are using the data and how often they change, you might want to create a look-up table that holds the native ID (like above) and then a well formed id (or series of columns to make the id) that will search and sort correctly.
Documentation
