2 Replies Latest reply on Mar 12, 2012 9:03 AM by arenol
    Getting the global position matrix for each text character
    arenol Level 1
      This post is a follow up to this related post.
      I need to get the position and orientation of the first and the last character in a text frame art, that is, I need its  matrix.
      There are a number of functions in the API that is supposed to help you; here's a snippet from the file ATESuites.h
      /** Return transformation matrix of this run.
      The matrix returned spesify the full transformation of the given run.  You need to transform the origin by IGlyphRun::GetOrigins() and
      concat with ITextFrame::GetMatrix() in order to get the location of the glyphs.
      ATEErr (*GetMatrix) ( GlyphRunRef glyphrun, ASRealMatrix* ret);
      Hence, getting the matrix of the first character or glyph should look something like this:
      AIErr
      VMGetFirstTextMatrix(  AIArtHandle textArt, AIRealMatrix *matrix)
          ASRealMatrix frameMatrix, glyphMatrix;
          ASRealPoint firstPoint;
          try
              TextFrameRef ateTextRef;
              sAITextFrame->GetATETextFrame( textArt, &ateTextRef);
              ITextFrame textFrame( ateTextRef);
              ITextLinesIterator lnItr = textFrame.GetTextLinesIterator();
              ITextLine txtLine = lnItr.Item();
              IGlyphRunsIterator grItr = txtLine.GetGlyphRunsIterator();
              IGlyphRun glyphRun = grItr.Item();
              IArrayRealPoint pointArray = glyphRun.GetOrigins();
              firstPoint = pointArray.Item(0);   // comes out with wrong values!!!
              frameMatrix = textFrame.GetMatrix();
              glyphMatrix = glyphRun.GetMatrix();
              sMath->AIRealMatrixConcatTranslate( &glyphMatrix,
                              firstPoint.h, firstPoint.v);
              sMath->AIRealMatrixConcat( (AIRealMatrix*) &glyphMatrix,
                         (AIRealMatrix*) &frameMatrix,
                         matrix);
              return kNoErr;
          catch (ATE::Exception e)
              return e.error;
              return kNoErr;
      But the coordinates, either returned in frameMatrix (tx and ty) or the firstPoint are obviously wrong. It appears that they an offset which is allmost constant.  The x-values are approx 7664 points too large (give and take a few decimals), and the y-values are approx 7893 too large (also give and take a few decimals).
      I'm reall puzzled by this, because I need to get accurate positions...
        • 1. Re: Getting the global position matrix for each text character
          btemp Level 2
          Like I said in the other thread.... it sounds like you need to convert between hard and soft coordinates.
          • 2. Re: Getting the global position matrix for each text character
            arenol Level 1
            Well, I worked it out eventually.
            The ITextFrame::GetMatrix() method usually  returns an identity matrix, unless I have moved or transformed the text frame object on the artboard.  For example, if I have duplicated a text frame object by draging the object while pressing the alt-key, this matrix will hold the relative transformation compared to the object it was spawned from. Since this is a relative transformation, it's neither in hard nor soft coordinates, so it makes no sense to harden or soften it (actually, you musn't do that).
            Next, the IGlyphRun::GetMatrix() method will  usually return the identity matrix, but will contain a rotation for example if the object is a text along a path.
            Finally, the IGlyphRun::GetOrigins() method will return hard coordinates for each glyph position, but without the transformation from the frame matrix.  This method is oblivious to the GetCoordinateSystem / SetCoordinateSystem functions of the HardSoft suite, and returns hard coordinates regardlessly.
            Thus, in order to get the actual art board coordinates of a glyph, the following code will do the trick:
                AIRealPoint firstPoint = pointArray.Item(0);
                AIRealMatrix frameMatrix = textFrame.GetMatrix();
                sMath->AIRealMatrixXformPoint( &frameMatrix, &firstPoint, &hardPoint);
                sHardSoft->AIRealPointSoften( &hardPoint, &glyphPoint);
            In order to get the absolute position matrix of the first glyph of a text frame art, the following function seem to work:
            AIErr
                ASRealPoint firstPoint, softPoint, hardPoint;
                try
                    sHardSoft->AIRealPointSoften( &firstPoint, &softPoint);
                    sHardSoft->AIRealPointSoften( &hardPoint, &softPoint);
                              matrix);
                    matrix->tx = softPoint.h;
                    matrix->ty = softPoint.v;
                    return kNoErr;
                    return e.error;
            But, this didn't come easy, and I must be allowed to blame the poor documentation on this issue...
            Agnar
            1 person found this helpful
