4 Replies Latest reply on Mar 13, 2012 12:07 PM by -==cfSearching==-
    CFC SQL help request
    earwig75
      Hello. I am using a CFGRID and I have a search box that filters the results. One database field is called "inactive". The grid should only populate with records where "inactive" is NULL but it shows all records anyway. It does filter out the inactive records but only when a search is run  Below is what I am using in my CFC. Could someone help and tell me what could be wrong? Thank you.
      <cffunction name="myfunction" access="remote" returntype="struct">
      <cfargument name="page" required="true" />
      <cfargument name="pageSize" required="true" />
      <cfargument name="gridsortcolumn" required="true" />
      <cfargument name="gridsortdirection" required="true" />
      <cfargument name="getSearchString" required="true" />
      <cfset var data="">
      <cfquery name="getdata" datasource="#this.source#">
        SELECT  IDNumber, FirstField, SecondField, ThirdField, ForthField, Inactive
        FROM   masterTable
        WHERE Inactive is Null
        and lower(SecondField) like <cfqueryparam value="%#lcase(arguments.getSearchString)#%" cfsqltype="cf_sql_varchar">
        or lower(ThirdField) like <cfqueryparam value="%#lcase(arguments.getSearchString )#%" cfsqltype="cf_sql_varchar">
        <cfif len(arguments.gridSortColumn) and len(arguments.gridSortDirection)>
        order by #arguments.gridsortcolumn# #arguments.gridsortdirection#
        </cfif>
        </cfquery>
        <cfreturn queryConvertForGrid(getdata, arguments.page, arguments.pageSize)>
      </cffunction>
        • 1. Re: CFC SQL help request
          Dan Bracuk Rockstar
          Probably because of this:
          • 2. Re: CFC SQL help request
            -==cfSearching==- Rockstar
            You have a mix of AND/OR operators which creates ambiguity. (See operator precedence) For example, do you want records where:
                   Inactive is Null  AND SecondField LIKE '%xxx%'
                         ... OR
                   ThirdField like '%xxx%'
            .. or do you want records where
                   Inactive is Null
                       ... +AND+
                   SecondField LIKE '%xxx%' OR ThirdField like '%xxx%'
            You need to use parenthesis so the database processes the conditions in the correct order
              ie  WHERE  Inactive is Null  AND
                                ( SecondField LIKE '%xxx%'  OR ThirdField like '%xxx%' )
            BTW: That is a sql injection risk. You should validate those values before using them in the sql.
            Message was edited by: -==cfSearching==-
            • 3. Re: CFC SQL help request
              earwig75 Newcomer
              cfSearching, I thought the cfqueryparam took care of the injection risk. Could you explain how I would validate them further? Thanks again.
              • 4. Re: CFC SQL help request
                It does, but only for simple values like strings or numbers. You cannot use it with object names (ie table or column names).
                Passing data from the client side directly into sql is always a risk. Either value could potentially contain a malicious sql string and nothing in the code would stop it from executing. Granted exploiting it requires a little more savy than your typical where clause attack. But it is still possible. You should validate the column name and sort direction (ie only "asc" or "desc" allowed) before using those values within the sql.
                -Leigh
