1 2 Previous Next 59 Replies Latest reply on Mar 15, 2012 12:54 PM by Jeffrey54 Lane
    Server side includes
    Jeffrey54 Lane
      I have built a site I have tried to put server side in after but have found it very dificult to apley, If I start the site over again how would I go about starting it, is there some instructions on the net I can use, or dose any one have any other ideas that I could use, Please help
      http://www.thecarpetandflooringconsultant.co.uk
        • 1. Re: Server side includes
          John Waller Adobe Community Professional & MVP
          Where are you struggling with Includes exactly?
          I'm not seeing anything in your link that indicates what you need help with.
          • 2. Re: Server side includes
            Jeffrey54 Lane Level 1
            The site that you see on the server does not have any includes, the problem is that when I want to change anything like a link or something that is on every page I have to go in and manually change every page, and as the site gets bigger it’s going to get harder to do, I have a separate copy of the site here in Dreamweaver that I am trying it out on, thing is I don’t have a test site server I can put it on so you can see. Thanks Jeff Lane
            • 3. Re: Server side includes
              Yes, Includes make that much easier to maintain.
              That's fine. Can you set up a test server on your local PC? Are you running Windows (which version?)?
              Is there anything specific that you need help with? There are several Includes tutorials online.
              Forums are more suited to specific Q&A rather than a full tutorial.
              • 4. Re: Server side includes
                I’m running Windows Xp, But I would not have a clue how to set up a server on it
                • 6. Re: Server side includes
                  martcol Level 4
                  Taking a look at your page here's how you might approach it.
                  First off, duplicate your page (i.e. make a test copy).
                  Cut the portion of your code out of the document that you want to make into the include file.
                  Past that into a clean page and save it as say banner.php
                  In your case, it would mean all of this code:
                  <div id="banner">
                      <div id="banner_text">
                        <h2 align="center">The Carpet and Flooring Consultant</h2>
                     </div>
                      <div id="banner_email_phone">
                        <div align="center">Email: <a href="mailto:info@thecarpetandflooringconsultant.co.uk">info@thecarpetandflooringconsultant.co.uk</a></div>
                          <h4>Telephone Bristol: 0117 908 2753</h4>
                        </div>
                    </div>
                    <div id="menu-bar"><ul id="MenuBar">
                      <li> <a href="index.html">Home</a></li>
                      <li> <a href="commercial-contract_carpet_and_flooring.html">Commercial</a></li>
                      <li> <a href="residential-domestic_carpet_and_flooring.html">Residential</a></li>
                      <li><a href="more_links.html">More Links</a>
                        <ul>
                          <li><a href="carpet_and_flooring_accessories.html">Accessories</a></li>
                          <li><a href="carpet-and-flooring-fitting.html">Fitting Service</a></li>
                          <li><a href="contact.html">Contact</a></li>
                          <li><a href="products.html">Products</a>
                            <ul>
                              <li><a href="commercial_products.html">Commercial</a></li>
                              <li><a href="residential-products.html">Residential</a></li>
                              </ul>
                            </li>
                          <li><a href="tips_and_tricks.html">Tips and Tricks</a></li>
                          <li><a href="newsletter.html">Newsletter</a></li>
                          <li><a href="sitemap.html">Site Map</a></li>
                          </ul>
                      </li>
                      <li><a href="laminate_and_wood_flooring.html">Laminate/Wood</a></li>
                  </ul>
                  Then, add this piece of code to the page precisely where the above code was removed:
                  <?php include('banner.php') ?>
                  Upload both your test page and the banner.php page to your server and see what happens when you navigate to the tesp page.
                  This of course, is using PHP so, it's presuming PHP is available to you on your server.
                  In the piece of PHP code in your test page, it has to point to the file wherever it is in the structure of the site.
                  If your include file includes links, you have to be sure that the path to the links is accurate.
                  Have a go.
                  Martin
                  • 7. Re: Server side includes
                    Hi I’m Following Johns lead. I went to the Setting up a PHP development environment for Dreamweaver, it has taken some time but I am getting there, on page 25 0f 47 (printed in landscape) Heading using the sample files, It says. If you haven’t already done so (I haven’t) download the sample files for the tutorial, unzip, and so on, but I’m not sure where to get them from, I’ve gone back to the Apache Friends website, looked on there and I can’t see any down loads relating to it, I think I am probably missing something simple but you know how it is, if you can’t see it, you can’t see it, any help will be appreciated, thank you Jeff
                    • 8. Re: Server side includes
                      You seem to be jumping around a bit without telling us exactly what you're doing (page 25 of 47 of what? why are you going to the Apache Friends website?) so it's a bit hard to follow your replies and visualize which hurdle you're currently facing.
                      I'm going to take a wild guess and presume that you're following this tutorial
                      http://www.adobe.com/devnet/dreamweaver/articles/setup_php.html
                      in which case, the sample files are linked at the top of the page in the grey box (php_test.zip)
                      • 9. Re: Server side includes
                        Thanks John that was it ,I thought it might be something simple, I will has a go at doing this new, Thanks
                        • 10. Re: Server side includes
                          Hi me again I’ve down loaded that file Gone to php my admin to Create the new data base Typed in php_test in the text box ladled Create New Database and Clicked Create, I had the report saying it is created ok, I then clicked the Import tab at the top of the page, I click in the browse box to find the file, php_test.sql from the assets folder in the PHP test site. I then clicked GO at the bottom of the page, and it just came up with an error page saying MySQL said #1046-No database selected. Hope you can help Thanks Jeff
                          • 11. Re: Server side includes
                            Nancy OShea Adobe Community Professional & MVP
                            You're making this too hard on yourself.
                            First, you don't need a MySQL database to use server-side includes. You only need databases if you plan to store content in them.
                            Includes statement tell the server to look for a file (include.ssi or include.html) and parse that info into the parent .php or .shtml page.  That's it.  Not complicated.
                            You don't need a local testing server, either.  It's more convenient to have one for previewing locally but it's not required to use includes.
                            More on Server-Side Includes
                            http://forums.adobe.com/message/2112460#2112460
                            Nancy O.
                            Alt-Web Design & Publishing
                            Web | Graphics | Print | Media  Specialists
                            http://alt-web.com/
                            http://twitter.com/altweb
                            http://alt-web.blogspot.com/
                            • 12. Re: Server side includes
                              As Nancy says, if all you're trying to do is learn to put Server Side Includes (SSIs) on your webpages then none of where you're going is necessary.
                              SSIs are really simple and you don't need a local testing server to set them up.
                              Just upload your small Include files to the server, upload the website pages with a .php extension and Includes statements where required and you're done.
                              • 13. Re: Server side includes
                                Hi John and Nancy Thank you for that, has you can see that my site now is getting bigger all the time (by my standards), there has been about four or five changes that I have made to the spry bar and banner, and I have had to change every page on the site each time, as you know this is time consuming not to mention tedious, the problem is if I make a SSI’s for the banner ,spry bar & footer and  put it on the site without testing it, and it don’t work then I will be in a bit of a muddle, I don’t really want the site off line if I can help it, but I still have to make things easier in future, so is there a way I can test the site without a test site, I hope you don’t think that I am a pain in the neck. Thank you Jeff
                                • 14. Re: Server side includes
                                  martcol Level 4
                                  Take a look again at my post.
                                  Using SSI to do what you describe is a typical implementation.
                                  Use a duplicate page nd try it out.
                                  Once it clicks in your head, it is easy.
                                  For development purposes, you can easily cut and paste the code between your includ file and page.  Leave yourself a reminder in the page if you need to.
                                  <!--banner SSI start-->
                                  <!--banner SSI end-->
                                  Martin
                                  • 15. Re: Server side includes
                                    Test SSIs online on your current site. No need for the site to be offline at all.
                                    Trial one dummy page online (on the current website) with SSIs for testing purposes.
                                    e.g. save index.php as index-test.php, upload to your server.
                                    Try adding an SSI to that index-test.php page alone and test it. The rest of the website will continue to function normally while you experiment in the background.
                                    Once it clicks in your head and you 'get' SSIs and it works, you can easily retrofit SSIs to your other pages.
                                    Just make the relevant code changes in your other real site pages and you're done.
                                    • 16. Re: Server side includes
                                      Create a TEST folder on your server.
                                      Upload pages & include files to the TEST folder to test remotely.
                                      When you're done, remove the TEST folder from your server.
                                      Nancy O.
                                      http://alt-web.com/
                                      • 17. Re: Server side includes
                                        Hi it’s me again, the test page that will become my index/ home, I have ended with .shtml and the file that as my includes in it I have ended with .php is this right. Also I’ve got a container in the index page do I also need a container in my includes file, and do I need a different includes file for each instruction i.e. one for banner, one for spry bar, one for the links at the bottom of the page and one for the footer, or can they all go in to the same file. Thanks Jeff
                                        • 18. Re: Server side includes
                                          Depends on the layout.  I typically put the container divisions on the parent page like so.
                                          <div id="header">
                                          <!--#include virtual="../Includes/header.html" -->
                                          </div>
                                          <div id="navbar">
                                          <!--#include virtual="../Includes/navbar.html" -->
                                          </div>
                                          <div id="footer">
                                          <!--#include virtual="../Includes/footer.html" -->
                                          </div>
                                          You can name your include file anything you wish:  include.php, include.html, include.ssi, include.foo.  It doesn't matter which extension you use on the include file.    It's the parent page extension that matters.  .shtml or .php will work on most Apache servers.
                                          Nancy O.
                                          http://alt-web.com/
                                          • 19. Re: Server side includes
                                            martcol Level 4
                                            The most straightforward way to look at this is that after building your page, you consider which parts are common accross your site.  Those parts will form your include files.  You make the choice about how much of your code you want to use in the include.  For instance, if you have a navigation menu in a containing <div>  you could cut the <ul> and everything inbetween to the </ul> and copy that to your include file.  You could cut the contiaining <div> or you could cut the whole <div id="header">  Like I say, you make that decision.  Whatever you cut out goes in the include file and you add the php precisely where you lifted that section of code.
                                            Yes, you do need seperate include file for each section of code.  If your, "spry bar" is in your banner, or right next to it, you could cut that whole section into your include and just have one.  If the code is common to all pages, that's where this technique really helps.  Again, if your links at the bottom of the page are contained within your footer, or adjoins the footer, then again, you would only need one.
                                            You could end up with just three includes: header.php, sidebar.php and footer.php.
                                            They can't all go in the same file but it makes sense to keep them all in the same place.
                                            Martin
                                            • 20. Re: Server side includes
                                              Hi it’s me again this is what I have done so far, as you can see I have only tried it with the banner and spry bar, you can will see from my site that they are quite tightly instigated so like martin said if they are next to each other, then include them together, so that is what I’ve done, all sounds good, funny enough it works great in DR live view, but up on the site when I try to open the page it comes up with a 404, I have got to get beyond this part of the problem before I can go any further hope you people can help thank you Jeff.
                                              www.thecarpetandflooringconsultant.co.uk Email: info@thecarpetandflooringconsultant.co.uk
                                              Home
                                              Commercial
                                              Residential
                                                1. [More Links | ../more_links.html]
                                                1. [Accessories | ../carpet_and_flooring_accessories.html]
                                              Fitting Service
                                                1. [Contact | ../contact.html]
                                                2. [Products | ../products.html]
                                                1. [Commercial | ../commercial_products.html]
                                              Residential
                                                1. [Tips and Tricks | ../tips_and_tricks.html]
                                                2. [Newsletter | ../newsletter.html]
                                                3. [Site Map | ../sitemap.html]
                                                1. [Laminate/Wood | ../laminate_and_wood_flooring.html]
                                              // BeginOAWidget_Instance_2141544: #MenuBar
                                              var MenuBar = new Spry.Widget.MenuBar2("#MenuBar", );
                                              // EndOAWidget_Instance_2141544
                                              This is a snippet of my index test page shtml
                                              THE CARPET AND FLOORING CONSULTANT. COMMERCIAL AND CONTRACT. RESIDENTIAL AND DOMESTIC. CARPET AND FLOORING. IN BRISTOL.
                                              +Hide+
                                               </div
                                              • 21. Re: Server side includes
                                                I always use one Include per page element. So I would set up the banner and Spry menu as two separate Includes. But that's just me.
                                                Which page do we view to see where you're getting a 404?
                                                The code/content you've posted (from Design View?) doesn't tell us anything. Go into Code View and copy and paste from there.
                                                • 22. Re: Server side includes
                                                  Sorry one more thing the link on my site that takes you to the page that is sowing the 404, is at the bottom of the home page at the end of the line of links, it says Test
                                                  • 23. Re: Server side includes
                                                    That link is pointing to
                                                    http://www.thecarpetandflooringconsultant.co.uk/index-test.php/index_test.shtml
                                                    meaning a file called "index_test.shtml" inside a folder named "index-test.php" (presumably that's wrong).
                                                    Should it be
                                                    http://www.thecarpetandflooringconsultant.co.uk/index_test.shtml
                                                    or
                                                    • 24. Re: Server side includes
                                                      martcol Level 4
                                                      can't look at your site at the moment but my first thought would be check the includes are uploaded and check the path.
                                                      Martin
                                                      • 25. Re: Server side includes
                                                        Hi it’s me again I done what John said and now the path is now working ok. But the page is coming up with this error message, as you can see below I have kept the page quite simple, first off I tried to do it with the banner and the spry bar, but because they are tightly intricate, I thought that might be causing the problem, so I decided that I would make it simpler so I have just used the Telephone Div, the Links bar and the footer, these are separate objects so there should be no problem, but unfortunately there is,
                                                        As I said in my last email, the link to this page is at the bottom of the home page, at the end of the links bar (Test)
                                                        Sorry for not caching on very quick, to you guys it’s probably quite simple, but I think I’m getting there.
                                                        Thanks for your help Jeff
                                                        www.thecarpetandflooringconsultant.co.uk   Commercial.  [Commercial.   Products. | commercial_products.html]  Residential.  Residential Products.  [Laminate and Wood Flooring. | laminate_and_wood_flooring.html]  [Accessories. | carpet_and_flooring_accessories.html]  Fitting Service.
                                                          Contact Us.    [Tips and Tricks. | tips_and_tricks.html]   [Newsletter. | newsletter.html]
                                                        Director: B.M.W. Lane.
                                                        Quality Carpets and Flooring is a trading style of Orchard Flooring (services) Ltd Registered Address: Red Brick House, St Augustine's Yard, Bristol. BS1 5DS
                                                        Company No: 7593598 Vat No: 111 411 77
                                                        Thank you for visiting this page I hope you have found what you were looking for. If you would like to send any comments you may have
                                                        please do so by using the E-mail on the contact Page.
                                                        Thank you. Mr Bradley Lane.
                                                        </div
                                                        • 26. Re: Server side includes
                                                          osgood_ Level 8
                                                          Lets try and make this simpler. (personally I think its easier to have a local testing server set up but its not strictly necessary)
                                                          Let's assume you're going to use .php as your final page extentions.
                                                          So for instance eventually you will change the index.html page below to index.php, right? (and the rest of your pages will end in .php as well)
                                                          http://www.thecarpetandflooringconsultant.co.uk/index.html
                                                          As a test make a complete copy of your site folder and call it - ssi_test
                                                          In the ssi_test folder change index.html to index.php
                                                          Open index.php and cut everything inside your <div id="menu-bar"></div> (which is the spry menu code below)
                                                          <ul id="MenuBar">
        <ul>
        <ul>
        </ul>
        </li>
        </ul>
                                                              </li>
                                                          </ul>
                                                          <p> </p>
                                                          <script type="text/javascript">
                                                          var MenuBar = new Spry.Widget.MenuBar2("#MenuBar", {
        widgetID: "MenuBar",
        widgetClass: "MenuBar  MenuBarLeftShrink",
        insertMenuBarBreak: true,
        mainMenuShowDelay: 100,
        mainMenuHideDelay: 200,
        subMenuShowDelay: 200,
        subMenuHideDelay: 200
                                                              </script>
                                                          Paste the spry menu code above into a new Dreamweaver document and save it as - top_nav.php - into a folder in your site root folder called - includes.
                                                          In index.php insert the php code below between the 'menu-bar' <div> tags (as shown below)
                                                          <div id="menu-bar">
                                                          <?php include('includes/top_nav.php'); ?>
                                                          </div>
                                                          That's it, done. You have now included the top navigation within your index.php file.
                                                          Now you need to change all your other page extentions from .html to php, remove the spry code form each page and replace it with the <?php include('includes/main_nav.php'); ?> between the menu-bar <divs>
                                                          Don't forget to amend the linked pages in the 'top_nav.php' include file to to .php from .html
                                                          Upload the ssi_test folder to your server and test it out.
                                                          As a footnote getting to grips with SSI is NOT as easy as its made out to be. You have to find a way to use them which suits your workkflow. Personally I always use absolute paths to any links in the include files as you can soon trip up if your pages and images are stored in different directories in your site root folder.
                                                          What I'd do in the long run is set up a local testing server environment and use localhost as the absolute path whilst testing locally and then once you have everything working the way you need it to work amend the localhost path to the remote absolute path.
                                                          So for instance in your include files your localhost link paths to files would look like:
                                                          <li> <a href="http://localhost/nameOfYourSiteFolder/commercial-contract_carpet_and_flooring.html">Commercial</a></li>
                                                          Change them to the remote absolute path once you have finished testing: (you can do this in seconds with 'find and replace' in Dreamweaver)
                                                          <li> <a href="http://www.thecarpetandflooringconsultant.co.uk//commercial-contract_carpet_and_flooring.html">Commercial</a></li>
                                                          The alternative is to set up a virtual host for each website on your testing server then there in no need to keep flicking backwards and forward with the paths.
                                                          • 27. Re: Server side includes
                                                            osgood_ Level 8
                                                            Another thing you may want to take into consideration is the possiblity that your .html pages have good google rankings. You don't want to loose those rankings by changing them from .html to .php so I would get a htaccess page together with a list of pages whose address has altered:
                                                            redirect 301 /index.html http://www.thecarpetandflooringconsultant.co.uk/index.php
                                                            • 28. Re: Server side includes
                                                              polar_bare Level 4
                                                              This thread is getting a little long, but thought I would give my two cents worth.
                                                              If you are having problems with the SSI working, ask your ISP if they allow SSI. The .shtm extension is working as I can see the index file in the folder. If they do support SSI, make sure you don't use absolute paths for the SSI. Some host don't allow this (osgood, I know you do use them and I have a deep respect for you, but I have always used links relative to site root and never had a problem*). Another thing to try is the afore mentioned is all correct is to rename your SSI with a .html or htm extension as some sites don't allow php extensions on SSIs. If you are passing variables in your SSI, some hosts don't allow this also (long story here).
                                                              If you have good tech support with your provided, contact them on the do's and don'ts of using SSI.
                                                              Server Side Includes are not as complicated if everything is setup right. It will make your life easier if implimented correctly. A good plan for directory stucture is always, as stated before, good!
                                                              Jim
                                                              * to use links relative to site root your site definition must be set correctly to your root folder.
                                                              • 29. Re: Server side includes
        osgood_ Level 8
        Been through this before and relative links within include files don't work locally UNLESS you have a virtual server environmemt set up other wise I would use them - alternative absolute paths
        • 30. Re: Server side includes
        I‘m getting a bit lost here, what is the difference between absolute and the other.
        Jeff
        • 31. Re: Server side includes
        polar_bare Level 4
        Absolute would be like this in a folder called includes off the root:
        http://www.yoursite.com/includes/mysite.shtml
        Now a if you have  your site set to "links relative to site root" it would be like this:
        the / tells it to start at the root of the site. I would ask that you contact your isp to see if they allow SSI and have them turn it on for you. I think this is the case here.
        When I use an include in a page with a php extension, the syntax is a little different than Nancy states above, but listen to her, she is very smart on all things web.
        Here is what I would use to include an include with a php extension, in a php document.<?php include('includes/myinclude.inc.php'); ?> as compared to Nancy's <!--#include virtual="../Includes/header.html" --> which I use with asp pages.
        Jim
        • 32. Re: Server side includes
        Hi I done what Osgood said and I got this error message
        Warning: include(includes/main_nav.php) [ <http://www.thecarpetandflooringconsultant.co.uk/function.include> function.include]: failed to open stream: No such file or directory in/web2/user38453/website/index.php on line 189
        Warning: include() [ <http://www.thecarpetandflooringconsultant.co.uk/function.include> function.include]: Failed opening 'includes/main_nav.php' for inclusion (include_path='.:') in/web2/user38453/website/index.php on line 189
        I have tried the coding polar bare said and sill got the same message.
        Thanks Jeff
        • 33. Re: Server side includes
        polar_bare Level 4
        There is no main_nav.php file there. The only file in that directory is top_nav.php
        Your include file sytax should be like this.<?php include('includes/top_nav.php'); ?>
        Sorry this is so confusing for you. You can test your server to see if it can parse the php files by creating a simple php file. Use the following and name it test.php and save it in your root.
        <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
        <html xmlns="http://www.w3.org/1999/xhtml">
        <head>
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
        <title>Untitled Document</title>
        </head>
        <body>
        <?php
        echo "Hello World!";
        </body>
        </html>
        Once this is uploaded to the server, open your browser and go to it. It should be a simple page with "Hello World!" on it.
        • 34. Re: Server side includes
        Osgood that’s done it thanks mate, and all the rest of you I would never done it without you all Thanks you all very much.
        All I have to do new is move all the other items over, so don’t be surprised to see my name pop up again. Thanks Jeff
        • 35. Re: Server side includes
        osgood_ Level 8
        Oops sorry I made a mistake put - 'main' instead of 'top'
        Seems like you got there in the end though
        • 36. Re: Server side includes
        Hi I said I might be back soon, Thiers one more question, on the secondary links bar at the bottom of the page, there is a link that takes you back to the top of the page that you are on, obviously in an includes that can only take you to one page but all of the pages are different, How do I handle this.
        Thanks Jeff
        • 37. Re: Server side includes
        Not to worry its main now
        • 38. Re: Server side includes
        osgood_ Level 8
        Thanks Jeff
        The 'back up' link?
        Not sure what you mean 'all of the pages are different' - a link to the top of the page should'nt be any different from page to page.
        • 39. Re: Server side includes
        Hi Osgood, If you go on the site and go to the bottom of the home page there’s a link called Test if you click on that, it will take you to the test page at the bottom there a link that takes you back to the top of the page BACK UP this link is in the includes, at the moment on all of the pages it is linked to each individual page, so now there is affectively only one link, I can’t do this. Thanks Jeff
        www.thecarpetandflooringconsultant.co.uk <http://www.thecarpetandflooringconsultant.co.uk/
        1 2 Previous Next
