1 4 5 6 7 8 Previous Next 1,716 Replies Latest reply on Dec 18, 2012 11:37 AM by Victoria Bampton LR Queen Go to original post
      • 200. Re: Lightroom 4 is slow
        nph2go
        I reported on the feedback site - please add your feedback too:
        http://blogs.adobe.com/lightroomjournal/2012/03/lightroom-4-hot-issues.html#comment-50650
        • 201. Re: Lightroom 4 is slow
          pdeeh Level 1
          Sick of the speed issue, I have tried two things:
          First I deleted Camera Raw cache & the entire Previews folder, then rebuilt all previews (1:1)
          This made no difference
          Then I renamed my old catalogue, restarted LR4, created a fresh catalogue and imported all my images, creating 1:1 previews on importl finally I read in metadata from disc.
          This seems to have improved matters somewhat - there is still a noticeable but not unbearable lag when zooming, but more importantly, sliders are no longer laggy - it works about as well as LR3.6 in this respect.
          For me this wasn't too much of a hardship as I have less than 3K images.
          The major downside is I have lost all the autostacked raw+jpg/virtualcopies, and detailed history for each edit.
          If this improvement is not sustained as time goes on I will of course report back
          • 202. Re: Lightroom 4 is slow
            SnewpersObiwan
            Well yeah I did notice that too. Seems like the delay is for LR to get the info on the image.
            In Dev mode selecting another image indeed greys out the panes for a second but only to gather the info on the image (all modifications and settings I think).
            Maybe that part of the delay is related to SQLite engine, which LR uses to store data?
            • 203. Re: Lightroom 4 is slow
              -Agfaclack- Level 3
              my system:
              i7 2600k @ 4.2 GHz
              16 GB ram
              240 GB Vertex 3 SSD (for catalog and preview)
              geforce 460 GTX 1GB
              win7 64 bit
              i had the beta installed before. i removed LR4 BETA and the LR4 BETA catalog prior to installing LR 4 final.
              im working with a fresh test catalog (not imported from LR 3.6) that contains ~9000 images.
              the LR 4 final works MUCH smoother end responsive then the beta.
              the beta was nearly unuseable. the sliders moved like snails.
              but.... i have the impression that LR 3.6 was a bit faster. not much but a bit.
              especially switching from the library to the develop modul feels not so fluid anymore... i think there is a small lag (but maybe it´s just pure imagination).
              overall i can not complain about speed with my system.... but i don´t know how things look on slower systems.
              • 204. Re: Lightroom 4 is slow
                Geoff the kiwi Adobe Community Professional & MVP
                http://blogs.adobe.com/lightroomjournal/2012/03/lightroom-4-hot-issues .html#comment-50650
                Mate, that is not the feedback site at all.
                The feedback site is here
                • 205. Re: Lightroom 4 is slow
                  stationarymotionOKC Level 1
                  Something has to give somewhere, using the full upgrade to LR4 and working with 5DmII & 7D images and it's unuseably slow. Reimporting images is too much of a task also having a current library of over 300k images. I am going to need an energy drink for the night ahead of me.
                  • 206. Re: Lightroom 4 is slow
                    Jeff Schewe Level 5
                    Sorry you are having problems...a couple of things to try assuming your speed hit is in Develop (it's useful to spell out EXACTLY where LR is being slow). If you are using noise reduction in PV 2012, try turning off the apply switch in the detail panel. New in LR 4 is the attempt to try to render the noise reduction at any screen view. This take cpu clicks...if you turn off the noise reduction while doing other work, it'll speed up the responsiveness of other adjustments. Other things that are known to tend to slow things down are lens correction and tons of local correction.
                    Again it would be far more useful to know EXACTLY where your slow downs are coming from...I'll also say that due to the adaptive image nature of PV 2012, a lot more cpu cycles are being used. Not for nothing, but if you are running a lot of other apps in the background that are stealing cpu cycles, that will also add to the speed hit. I have issues when running LR and photoshop at the same time but LR by itself seems to be fine...YMMV.
                    You all really need to be explicit in your reports of slowdowns and what your OS & processors are, ram and other things running.
                    • 207. Re: Lightroom 4 is slow
                      nph2go Level 1
                      Jeff
                      Thx a lot for helping out, you are the first person to try and steer this conversation towards a solution! So much appreciate your help here.
                      W7, 64bit, i7 quad core, 16GB, 2TB HDD - upper end system with 1 monitor turned on.
                      50K images in catalog
                      i see the incredibly slow response in LIBRARY module, all i am doing is - working in a folder with ~200 images, using the filmstrip view and scrolling between images using the arrow key as i scored the images (1-5).
                      if you need more details please (hardware or software) please let me know.
                      thx again
                      nagendra
                      • 208. Re: Lightroom 4 is slow
                        Jeff Schewe Level 5
                        Are these images that have already had previews made? Are you looking at the images in Loupe View? (as apposed to the thumbnails inside of Library) Once you've got the images imported, have you given LR enough time to render the previews?
                        I wouldn't expect major slow downs when viewing Fit Image size in Loupe unless you haven't gotten the standard previews rendered...if you are viewing at 1:1 and you haven't made 1:1 previews, I would expect that to also be slow'ish.
                        This is an entirely different animal than having slow response time to adjustments made in Develop. That's why it's super critical to know exactly where the slow downs are and what people are doing when they see a slow response.
                        I would expect moving between Fit Image zoom views to be pretty fast (no lag) after you've made the standard previews after an import. If you are importing and immediately trying to Loupe the images, yes I would expect slow downs.
                        • 209. Re: Lightroom 4 is slow
                          quenton8 Level 2
                          If I may interject -- I am running
                          W7, 64bit, i5 quad core, 8Gb
                          My catalog is on my c:\ drive, my photographs on a USB-2 1Tb drive.
                          I tried working in a collection of 18,000+ photos, many of which had not been viewed other than as thumbnails.
                          I used the single-photo view, and the arrow keys.
                          I was able to move as fast as I could hit the arrow keys.  The full preview however would take about 1/2 sec before
                          the view was fully clean.   I then exited LR4 and re-entered and moved over the same photos.  In this case they
                          appeard fully clean as fast as I could press the key (not holding the key down, just a normal down-up-down-up).
                          Is this sort of what you were doing?
                          • 210. Re: Lightroom 4 is slow
                            Apologies Jeff, I should have included that.
                            Windows 7 64bit, Quad core i7, 8gb of ram, ATI video card I believe...
                            Using LR4 out of the box, I've created quite a few mapped locations & develop presets but that's it.
                            Upon launching LR, sometimes it won't ever show that there are images across 9 hard drives in the catalog. All of the date folders are greyed out. If I close LR4 and re-open it, generally within 3-6 minutes, it will show the image counts in each folder. When in Develop mode, I have the same complaint as so many others, you move the clarity slider from 0 to 18 and it's a 30-60 second turnaround. When clicking on a preset I have created, sometimes you don't ever get the image updated with the new settings.
                            LR3 also gave me major speed issues and was not snappy at all and I was hoping LR4 would remedy that.
                            Currently working through 1,200 images from a wedding and I'm able to multi-task to other design projects while I'm waiting on LR.
                            Thank you!
                            • 211. Re: Lightroom 4 is slow
                              Jeff Schewe Level 5
                              When you imported the 9 drives of images...did you actually try to use the previews or did you simply upgrade a LR3 catalog? Big difference...when you import images either from a CF car or a previous catalog, LR has to "know the images" meaning it needs to have loaded and previewed all the image you may look at. Initially after an import, particularly before the previews are done rendering, it takes a while for LR to absorb the image data and organize the previews. That's why sometimes it shows a grayed out drive/folder name and sometimes shows the three dots next to an image preview and sometimes shows the preview as a grey square...that's normal for new use of an import or catalog. This tends to go away over time (once LR works in the background to fully enter in the database records and makes previews).
                              This has nothing to do with potential slowdowns when in Develop. Unless you explicitly tell LR to make previews, it doesn't do it as a foreground function, it does it as a background operation. Which means anything you may do in the foreground will impact (negatively) the background operations.
                              With regards to the Develop slowdown (and entirely different animal) again I would ask whether or not noise reduction has been applied/turned on. That is a cpu hog when dealing with any images whose noise reduction is other than zero.
                              For the engineers to understand what's happening, the reports of slowdowns need to be less emotional (ranting) and more informational. That's the only way to try to isolate what's going on for some but not impacting others.
                              • 212. Re: Lightroom 4 is slow
                                mizzified Level 1
                                just thought i would update my info, had a chance to work on LR4 again tonight to see if i could get it flowing. Here is some details of my personal issues. none of which i had with LT3
                                my system update:
                                Dual monitors. Loupe view. (A MUST)
                                AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor
                                Win 7 64bit
                                12 gigs ram
                                HIS H467QR1GH Radeon HD 4670 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
                                2 External 2T ESATA drives (500K images or so) .CR2 Files
                                slideshow works nice, and library mode is fine.... little lag there, but for me it's not bad.
                                in develope mode... as i start to edit an image (dual monitors on) the more i edit the more it lags to the point on complete 5 second frustration.... sliders wait seconds to move then jump.... everything just starts to lag dramatically to the point of total frustration. Of course unselecting details section helps.... as does turning off the dual monitor view.... slightly, but, i'm really hoping this isn't they way I'm expected to use the software.
                                some other notes: works really nice on my macbook pro with single monitor view and a DRAMATICALLY smaller catalog. Just a little sluggish if i get to crazy with edits and detail perameters. Otherwise, very useable in this way.
                                thanks everyone for all the posts... good to see i'm not alone on this.
                                • 213. Re: Lightroom 4 is slow
                                  Jeff, here is my develop panel, it's upgraded to 2012, but I'm not seeing the option you're mentioning.
                                  Here is part of the library list, which is pretty standard. When importing all of these, I didn't import the LR3 catalog, if I remember correctly, it told me it wasn't valid for one reason or another (I may be losing it, I really don't remember) and I just used the Add function in the Import options to get them in to LR.
                                  • 214. Re: Lightroom 4 is slow
                                    Jeff Schewe Level 5
                                    There are reports that something about dual display is really, really slow....it would be useful to know if this is a facot. Can you go to single display and do the same steps and see if you are getting the same response?
                                    • 215. Re: Lightroom 4 is slow
                                      I'm also using two monitors, I'll try it on one and see if that helps.
                                      • 216. Re: Lightroom 4 is slow
                                        Jeff Schewe Level 5
                                        So, based on your screen shots, I would expect the Develop module to be slow showing images zoomed in since the Develop previews are ripped not from the LR previews but directly from the raw file. Again it would be useful to know whether or not you've applied and noise reduction.
                                        Just understand the Library and Loupe views are using the previews rendered by LR when you import. When you go to Develop, LR must (by nature) re-render the whole raw file to present a color accurate rendering which will include any noise reduction you've applied. It's not at all surprising that moving image by image in Develop in the film strip is slow unless you've visited that image before.
                                        Again, all of these reports of "slowness" are separate and distinct. You may not realize how LR works, but there is a standard practice that would be useful to follow. Wait till LR is done rendering standard previews, then use Loupe view to view the images, if you want 1:1 (100% previews) that's gonna take time to generate. No free lunch...getting pixel level info takes time.
                                        • 217. Re: Lightroom 4 is slow
                                          nph2go Level 1
                                          i am displaying using 'Fit' in Library.
                                          the display is set to 1920x1080
                                          i imported from LR3.6. dont know about the previews, what do i need to do to check on previews
                                          i've been running LR4 for several hours (with occasional use) - what do i need to do to check this and what do you recommend - i.e should i create new previews?
                                          • 218. Re: Lightroom 4 is slow
                                            Makes sense to me, I'm working on files that were imported in to LR3.6, but I didn't start touching them until after I had download 4 and re-imported everything. I will work on being patient with it and allow it to do it's job. Having each image between 20-30 mb on average can be a strain I'm sure.
                                            • 219. Re: Lightroom 4 is slow
                                              A C G Level 1
                                              OK Jeff,
                                              I have turned Sharpening and Noise to Off
                                              Lens Correction is Off
                                              Effects are Off.
                                              I have clicked Render Standard size for all images
                                              I have clicked Render 1:1 Preview for the image I am working on.
                                              I move the Exposure Slider and my CPU shoots to 100%. I lose control of the Exposure Slider. The CPU does not settle down for about four to five seconds.
                                              That's with LR4.
                                              In LR 3.6 with the three items set to On I can move the Exposure Slider. The CPU raises to 90% (never 100%) and drops back to zero or 1% or 2% within a second. I never lose control of the Exposure Slider.
                                              If LR4 is working fine can you tell me what I am doing wrong, please?
                                              Tony
                                              • 220. Re: Lightroom 4 is slow
                                                kkelln@sasktel.net Level 1
                                                A C G - my experience is nearly identical to yours, though I find the NOISE slider to be the worst. Every experiment I have tried, the deifference in the amount of CPU usage and even memory usage between Lr4 and Lr3.6 is generally huge. Then a red hearing pops up. After my 30th reboot, I opened Lr4 intending to create yet another new catalog and try something differet but when I did I noticed it opened faster than before.So I clicked on the develop module and fiddled around and BAM, without me doing a thing, all sliders seemed perfectly responsive. I then opened up my resource monitor and sure enough, resource usage was no longer peeking. I flipped through a few pictures and tried developing them Here too the things were quite responsive. I can't explain it. I closed the catalog, opened my "real" catalog, which has over 30,000 images, and it was right back to being slugissh. So, I fiddled for a while, closed my  'real' catalogue and opened up the test catalogue and BAM, it was slugish again. ARE YOU KIDDING ME!  The hardest problems to fix are one that can't be reliably reproduced. Until now, the slugishness issue has been a near constant for me. I have no idea how this is possible. Ugh.
                                                • 221. Re: Lightroom 4 is slow
                                                  A C G Level 1
                                                  Kirk,
                                                  I'll keep this short. You and I have been around here a lot.
                                                  I'm the guy who posted, probably last Friday, that if you uninstall the beta, remove all the lrdata files, reboot and install the paid up version you'll be OK. At the time I posted that I was.....but, like you, things changed for the worse.
                                                  I'm typing this msg on a PC that never had the beta. Initially LR4 was fine - and now it us unuseable.
                                                  That's all for now.
                                                  Tony   a c g
                                                  • 222. Re: Lightroom 4 is slow
                                                    ChrisFourie-Lipman
                                                    I installed Lightroom 4 on a newly setup Windows 7 64bit computer and if I compare it to Lightroom 3.6 (running on a 5 year old box with an Intel Quad Core processor & 8GB Memory), Lightroom 4 is very sluggish with most adjustments, things get even worse when I enable viewing on a second monitor.
                                                    Adobe, believe us, Lightroom 4 is SLOW!!!!
                                                    Computer configuration:
                                                    Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz, 3401 Mhz, 4 Cores, 8 Logical Processors
                                                    Microsoft Windows 7 Ultimate x64
                                                    16.0 GB Physical Memory (RAM) (4 x 4096MB DDRIII)
                                                    1 x 240GB Kingmax SATAIII 2.5” Solid State Disk (Operating System, Programs Lightroom Catalogues & Caching)
                                                    2 x 1000GB Seagate SATAIII 7200RPM Drives
                                                    Nvidia GTX560TI 2048MB Graphics Card.
                                                    All hard drives are less than 30% full with no fragmentation of any files.
                                                    • 223. Re: Lightroom 4 is slow
                                                      mizzified Level 1
                                                      Thanks for askin jeff. I did switch to single display and it does make a considerable difference.... way less delayed responses and long winded redraws.
                                                      I tried to come up with a workflow like this, single monitor and no details panel active..... as these two things seem to me to be the killers...... but it still started to bog down in time as I worked with the sliders editing even without them options in my flow. I'm guessing here, but I don't think Adobe would want people with my computer specs to have to find work arounds to use their software. The dual monitors and details tab rock in LR3.
                                                      I'll try some new tricks tonight.... maybe rebuilding catalog files and previews, i'm just a little couscous when it comes to touching my catalog files... lots of work and time associated with those darn files
                                                      Thanks everyone. I'm glued to this forum until I can get this LR4 into my work-flow with dual monitor view. Absolutely love the changes to the develop module.
                                                      • 224. Re: Lightroom 4 is slow
                                                        andreas603 Level 1
                                                        I've now tried so many different things to speed it up I'm losing track of which variables I'm playing with.  For me, dual display doesn't make a diff unlike many of you... I was hopeful that creating a new catalong and importing everything again would help and I thought it it...In Library Mod, it seem to have sped up just a bit but still not a quick as 3.6 ( I regenerated previews as well)... In Dev Module its made NO difference- loading each file takes 2-3 seconds during which time everything greys out while it trys to read the RAW file.. .Someone posted that the 'engine' used to pain RAW files in Dev is the RAW file itself, while in Lib, its the LR preview file.... This could help to determine the root cause perhaps....
                                                        I've not messed with any other setting like noise, lens correction, etc...This is a direct import of CR2 files from Canon 5D MII and its still not usable in the Dev Module.  Back to 3.6...
                                                        Will Adobe refund an upgrade???
                                                        • 225. Re: Lightroom 4 is slow
                                                          quenton8 Level 2
                                                          Does not seem to be a lot of consistency except that a lot of people are finding it slow, and another "a lot" are NOT finding it slow.
                                                          Maybe its time adobe development staff visited a few of the "slow" people to get a handle on this??
                                                          • 226. Re: Lightroom 4 is slow
                                                            Dual display also didn't have an effect on my speed. It's slow all the way around overall. I had to keep working so as I posted earlier, I just continued editing until around 4 this morning while multi-tasking on other design projects while waiting on LR.
                                                            What's scary is the fact that LR4 is still so much better off than After Effects. That program is so great and yet almost unuseable due to the bugs.
                                                            • 227. Re: Lightroom 4 is slow
                                                              googull Level 1
                                                              Like many others, I use LR3 daily and it blazes even when I enable the 2nd screen.   If LR4 survivied BETA but is now having issues with it must be connected to differences in the HW platforms. I am one that never installed the LR4 BETA.
                                                              Running Vista-64 SP2
                                                              LR 4.0 64 bit
                                                              PS CS 5.1 Extended 64 bit (configured to use 48% of available RAM)
                                                              Notes:
                                                              1. Adobe DL link for my purchase failed so I had to use the Trial Download to install and license application.  Perhaps just an issue with the Trial Build?
                                                              2.I have two monitors but rarely use the 2nd for LR.
                                                              3. I didn't notice the perf hit unitl AFTER i had messed with the MAP and BOOK module and AFTER I had performed an import of some fresh JPEG images.
                                                              4. I have messed with catalogs, changes in settings and viola - things appear better - but I can't be certain the changes I made caused the improvement or just another restart.  But one thing is clear, after I run another import the system slugs again.  It really feels like the import module is triggering the change for me.  I just imported 100 JPEGS (small) and it took 4 min 35 seconds and the LR4 perf is totally hosed again.
                                                              4. Response is just as others have described but best place to see the hit for me is the crop tool under DEVELOP module.  It isn't just slow, it painfully repaints the screen in ways I have never seen before in LR1,2,3.
                                                              5. I get sluggish reponse with or without PS5 running.  Also, if I run PS5.1 first I can run LR4 but if I load LR4 then try to open an image from LR in PS5.1 the system has tendenancy to hang. I am used to flipping between LR and PS with extreme regularity.
                                                              It feels like memory managmenet has been severly broken and/or the GPU isn't being used  (I thought LR exploited GPU) or the GPU use is being interrupted so I see this on again/off again behavior perf behavior. (NVIDIA GTX280)
                                                              Intel Q9550, 8GB, Vista-64, NVIDIA GTX280
                                                              • 228. Re: Lightroom 4 is slow
        andreas603 Level 1
        dumb question...how do I know if a file has a preview generated already in the Library Module...?
        • 229. Re: Lightroom 4 is slow
        Jeff Van de Walker Adobe Employee
        The Lightroom team is investigating this problem. Right now we attempting to nail down the specific issue/ issues. Just be aware that development may go dark on the forums while trying to research this problem. In addition we may be contacting people individually for more information.
        Jeff Van de Walker
        Lightroom QE
        • 230. Re: Lightroom 4 is slow
        hamish niven Level 2
        Good to hear from Adobe.
        Thanks guys. Its been pretty dark since release date of LR4.0, but I'm sure you are well aware of the issues.
        Communication is appreciated and even a comment every few days will make us customers feel appreciated and that our concerns are noted.
        Go make LR4.1 an amazing product, and Jeff VdW, thanks for the feedback
        • 231. Re: Lightroom 4 is slow
        Wanchese West Level 1
        Now THAT is what I like to hear!
        I hate to say it but, I am getting used to the balky sliders, slow rendering to the 2nd monitor and herky jerky crop tool. I wonder how I will feel though Friday, which is my deadline day....
        • 233. Re: Lightroom 4 is slow
        randydellingerLR
        Possible solution: I left LR4 running for 10 hours w/o using it and now it's much faster, almost at LR3.6 speed. Perhaps it was converting my large catalog (82K photos) in the background which was slowing everything? I hope the speed lasts!
        • 234. Re: Lightroom 4 is slow
        Eaglerapids
        Thank you for the reply Jeff, good to know you guys are looking into this issue.
        • 235. Re: Lightroom 4 is slow
        Michel_13 Level 1
        Yes, same conditions for LR3 and LR4 : LR3 was fast, LR4 is very slow. A trick indicated by a user, make LR4 working better but after a certain time, rebooting or so, LR4 is becoming slower. So much posts concerning speed (actually very low speed) couldn't be only the fact of users configurations. My LR3 library is 30 more bigger than the one of LR4, configurations are the same concerning previews aso.. Even DxO which was not the fastest RAW software in the past, is now faster as LR4 !
        Curious thing that even LR3 was a little bit slower from time I installed LR4 beta, replaced now with released LR4.
        I think I will not upgrade to LR4 until I've retrieved speed of LR3, particularly because from my personal point of vue, LR4 is NOT a major release.
        • 236. Re: Lightroom 4 is slow
        SnapshotNinja
        I am on a Quad 4GHz machine w/ 12GB of ram.  My catalog & images are on 550MB/s read/write SSD drives.  Yet LR4 is very sluggish.  LR3 was responsive (still slower than I would like, but worked fine), LR4 is almost like running a Java app at times.
        • 237. Re: Lightroom 4 is slow
        tgutgu Level 1
        Java apps aren't generally slow.
        If there are other slow applications there might be a bottleneck in your hardware or system configuration.
        On my system - 2 year old i5-750, 4 Gb RAM, Windows 7 64-bit - LR4 runs mostly as quick as LR3.
        You should also more clearly define, what actually is sluggish, and how is sluggish to you (i.e times images needs to get rendered, how responsive sliders are etc.)
        • 238. Re: Lightroom 4 is slow
        Mag_74
        I installed a big update from Nvidia ( 130 Mb ) in windows update.   After that it´s working smooth again.   Before I was just like many above has explained.
        • 239. Re: Lightroom 4 is slow
        SnapshotNinja Level 1
        Many java apps are slow (visually) but not all, I agree especially with newer runtimes, but I think it gets the point across.
        Image render times are very slow, moving around the catalog is very slow, sliders can be slow at times.
        It is not a bottleneck in my system.  My system is faster for most everything else and runs LR3 very well. I have brand new $600 video card and 4 top of the line SSD drives.
