12 Replies Latest reply on Mar 21, 2012 6:46 AM by HiTopp
    ColdFusion caching SQL Server credentials?
    HiTopp
      I have been using ColdFusion's storedProc() service for a while with no issue.  However, I have run into a scenario where I have a local stored procedure executing a remote stored procedure.  When I attempt this via ColdFusion, I receive a very cryptic error:
      The DBMS has returned the command code 224...
      The following is the code I am using:
      variables.storedProcService = new storedProc();
      variables.storedProcService.clear();
      variables.storedProcService.setAttributes(datasource="DATASOURCE", procedure="STOREDPROCNAME");
      variables.storedProcService.addParam(cfsqltype="CF_SQL_INTEGER", type="in", value=0);
      variables.storedProcService.execute();
      However, executing the exact same procedures from SQL Server Management Studio results in no issues.
      Then, when I use the following code:
      variables.storedProcService.setAttributes(datasource="DATASOURCE", procedure="STOREDPROCNAME", username="USERNAME", password="PASSWORD");
      The execution runs without issue.  My question is this, does ColdFusion cache SQL Server/Datasource credentials?  Why does it [seem to] not use the credentials I provided in Jrun?
