Hello,
I am a novice user of Adobe Livecycle but learning. I am creating an expense voucher for employees to be reimbursed for mileage however I would like to create a if statement that says if the expense date is equal to or before June 30, 2012 then multiply the number of miles drived by a rate of $0.555 per mile and if the expense rate is equal to or after July 1, 2012 then multiply the number of miles by a rate of $0.600 per mile. I have created specific fields labeled dteexpenseDate (field with user entered date), decnumberMiles (number of miles driven) and decmileageRate (mileage rate).
Currently, I have this code;
var currentDate = Date2Num(dteexpenseDate.rawValue = "2012-06-30")
var expenseDate = Date2Num(dteexpenseDate.rawValue, "YYYY-MM-DD")
var expenseTest = expenseDate - currentDate
if(expenseTest<0) then
sum(decnumberMiles*0.555)
else
sum(decnumberMiles*0.600)
endif
I am using formcalc currently but would be open to using javascript. I am aware that this is not correct since I am getting errors but I haven't found anything on the internet to help me. Any help would be greatly appreciated.
Thank you
Lindsay
Solved! Go to Solution.
Total Likes
I am assuming you want to populate the last of the 3 fields (mileage rate)? If so, use the calculate event in formCalc with something like
var changeDate = Date2Num( "2012-07-01", "YYYY-MM-DD" )
var expenseDate = Date2Num( dteexpenseDate.rawValue, "YYYY-MM-DD" )
var expenseTest = expenseDate - changeDate
if ( expenseTest < 0 ) then
$ = decnumberMiles * 0.555
else
$ = decnumberMiles * 0.600
endif
FormCalc has its advantages (faster, better date handling, etc.) but its not as flexible as javascript along with the fact that there are not as many places on the web that can give you examples.
Total Likes
else
endif
Total Likes
That worked! Thank you very much.
I would love to be more familiar with javascript, I guess I just have to jump in and figure it out.
Total Likes
