We have application on Oracle and D2K. Is it possible to
create context sensitive help (What's this) for RoboHelp for
HTMLHelp(.chm) and WinHElp (.hlp)?
Hi Meenakshmi. You can certainly create "What's This" type
help in both CHM and HLP files. You just need to create a map file
that maps the application call to a specific help topic. How your
Oracle and D2K applications do this is down to the developers.
Normally all you'll have to do is give them a map file containing
the mapids and they should do the rest.
Yes you can Meenakshmi. It works in a similar way to HTML
Help or Winhelp. The only difference is the call from the
application which uses a different call syntax. Your developers
should be able to help set up the application with this. From a RH
perspective, just setup the map file in the normal manner and
supply the map file to your developer - unless they've already
provided you with a map file that is
You may not find the exact content for the code calls, but
the links should help you get on the right track. There is also a
lot of useful information specifically for developers in Robohelps
own online help.
