1. Re: Remove unwanted objects with content-aware healing
Jesscasey123 Mar 17, 2012 3:42 PM (in response to community help)I cannot find Content-Aware in the options bar in Photoshop Elements 10
2. Re: Remove unwanted objects with content-aware healing
photodrawken Mar 17, 2012 3:43 PM (in response to Jesscasey123)It's only available when you choose one of the Spot Healing tools.
Ken
3. Re: Remove unwanted objects with content-aware healing
Jesscasey123 Mar 17, 2012 4:01 PM (in response to community help)Thanks, I tried removing a person from a picture and it left a mess behind, I guess it takes practice.
4. Re: Remove unwanted objects with content-aware healing
photodrawken Mar 17, 2012 4:06 PM (in response to Jesscasey123)Yep. Try using a very small brush size, even if the area you're removing is large. The small brush size doesn't pull in content from so far away.
Ken
5. Re: Remove unwanted objects with content-aware healing
MD Miller Mar 25, 2012 10:50 AM (in response to photodrawken)Also, this page:
has a broken link. It offers a video of content aware
For a video about this process, see www.adobe.com/go/lrvid911_pse_en , but when you go to that page it's all about creating a calendar.
6. Re: Remove unwanted objects with content-aware healing
Barbara B. Mar 25, 2012 11:56 AM (in response to Jesscasey123)For something as large as a person, the healing brushes alone aren't always going to do it. You may need to add the clone stamp to cover up what's left over, or you may be better off by starting with the Recompose tool and just healing and cloning any bits that recompose can't remove. It all depends on the image.
7. Re: Remove unwanted objects with content-aware healing
HaileyBruce Apr 25, 2012 10:46 PM (in response to photodrawken)The only way the Spot Healing Brush Tool (with Content-Aware checked) worked for me was using a brush that completely covered the item to be removed. A small brush didn't work at all.
8. Re: Remove unwanted objects with content-aware healing
MD Miller Apr 26, 2012 5:16 AM (in response to HaileyBruce)Thank you very much Hailey for responding. I was trying to remove an out of focus, close shoulder and head on the lower right corner. Couldn’t effectively crop it out. Will try again.
9. Re: Remove unwanted objects with content-aware healing
Roadie1 May 20, 2012 7:42 PM (in response to community help)Have no idea what I did, so don't even ask. lol Double clicked on background layer and ended up creating a clipping mask. The using spot healing brush, I was able to remove water hose by the side of the pool, like I originally intended. I finally had upgraded from PSE 7 because of content aware fill and photomerge (and other stuff lol). The only thing was I seem to have lost my background layer. No problem, was working on a test file copy. Worked pretty good though. Not just have to find out what happened to my background layer. It was locked but ????? lol
10. Re: Remove unwanted objects with content-aware healing
HNDNV07 Sep 2, 2012 5:07 PM (in response to community help)I got as far as painting over the object I want to remove. Do I use the Hand Tool to move the object or?
Frank
11. Re: Remove unwanted objects with content-aware healing
burgandine Sep 15, 2012 1:17 PM (in response to community help)I too am having problems with this healing brush with content aware. I got a lot of blur in the area I was trying to clean up.
Any ideas?
12. Re: Remove unwanted objects with content-aware healing
HaileyBruce Sep 15, 2012 8:40 PM (in response to burgandine)I wish I could help, but I've had little experience with content aware. Good luck, Bruce
