2 Replies Latest reply on Aug 28, 2012 10:57 PM by AidySun
    The text frame in a table cell cannot be exported correctly as PDF in ID CS5.5
    AidySun Level 1
      I'm using command "kPDFExportItemsCmdBoss" to export the page items to PDF files. In ID CS5.5, the text frames in a table cell can execute kPDFExportItemsCmdBoss successfully, but the PDF files are blank.
      Does anyone meet the same issue here?
      The problem is it only occurs when using ID CS5.5, the same code can work well in ID CS4. Maybe there is some bugs in the CS5.5 SDK, but i'm not sure.
      Any suggestion would be appreciated.
      Thanks a lot,
