Hi
I am looking for a way to set up individual Flash Access protection settings for each of some <Location /{url-path}> tags in httpd.conf in the Apache. I have found in the documentation that EncryptionScope can be set to content or server. If I set it to server and use FlashAccessV2 as ProtectionScheme, how or where do I specify the Flash Access certifications and so on?
best regards
Johan Acevedo
You can use it as below - i think its miss from our side on documentation front - we will get that corrected and i have filed the bug for same. Thanks for letting us know.
<Location /hds-vod>
HttpStreamingJITPEnabled true
HttpStreamingContentPath "../webroot/vod"
JitFmsDirPath ".."
EncryptionScope server
ProtectionScheme FlashAccessV2
FlashAccessCommonKeyFile <location to key file to be used>
FlashAccessLicenseServerURL <http://<license-server-url>>
FlashAccessTransportCertFile <location to the certifica
...Copy link to clipboard
Hi
If you set the scope to server, that tells fms to use http.conf (jithttp_module)
Ive not seen anyone set up individual settings for locations, but I guess you can try the tags that you find in the normal /hds-vod location
I found this documentation for what fields/tags/attributes that are availible for the jithttp_module and nothing there enables me to specify the Flash Access credentials for the entire location/application.
I can solve my problem with the jit.conf file, but I don't want that file to be exposed to an FTP user who upload material to the publish folder.
By default in the FMS now, all jit.conf files are exposed to normal HTTP requests through the Apache unless you yourself put a limitation in the Apache httpd.conf. This might be a overlooked security error in the update from FMS 4.5.0 to 4.5.1 when HTTP (HDS) traffic was changed to go through the Apache only by default.
<Location /hds-vod>
JitFmsDirPath ".."
FlashAccessTransportCertFile <location to the certificate files>
FlashAccessLicenseServerCertFile <location to license server certificates>
FlashAccessPackagerCredentialFile <location to packager credential file>
FlashAccessPackagerCredentialPassword <password for packager credentials>
FlashAccessPolicyFile <policy to be used to packaging the content>
Options -Indexes FollowSymLinks
</Location>
Works like a charm!
