5 Replies Latest reply on Jun 11, 2012 4:24 PM by simbur999
    .PDF File Association for All User Profiles
      Hello. I am currently working on a deployment of Adobe Acrobat X Professional.  The deployment works folllowing this process:
      • Remove Foxit Reader
      • Install Adobe Acrobat X Professional (Which removes Adobe Acrobat 8)
      • Run command >>> assoc .pdf = "C:\Program Files\Adobe\Acrobat 10.0\Acrobat\Acrobat.exe" "%1"
      Foxit removes itself fine, Acrobat 8 gets removed, and Acrobat X is installed, the only issue is PDF files are not associated with Acrobat X.  If you choose to open the pdf in a browser it opens in Acrobat fine, but if you have a PDF saved somewhere it pops up asking what program to open it with.
      I am looking for a way to associate PDF files with Adobe Acrobat X Professional across all user profiles.  I thought the command assoc .pdf = "C:\Program Files\Adobe\Acrobat 10.0\Acrobat\Acrobat.exe" "%1" was going to be my solution but it does not work, even though it runs fine.
      Any ideas / advice is greatly appreciated, even if you point out that I am doing something complety incorrect.
