1. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
JS4653 Mar 19, 2012 8:00 AM (in response to JWW001)I had the same issue. It has to be toggled several times, then it's OK.
Check it on, then off again, then save. See if the data is being exported then.
2. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
JWW001 Mar 19, 2012 8:10 AM (in response to JS4653)Thanks for suggestion but this doesn't work for me
3. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
b_gossweiler Mar 19, 2012 3:53 PM (in response to JWW001)Can you post a small JPEG, together with screen shots of the metadata panel and the export dialog here?
Beat
4. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
JWW001 Mar 20, 2012 4:16 AM (in response to b_gossweiler)As requested I attach screen shots of the LR4 metadata panel after I have updated the coordinates in LR4 and also the LR4 export dialog. Also a JPEG of the exported photo which still has the original coordinates untouched from the camera along with the EXIF coordinates. These are incorrect as the camera hadn't acquired the satellites. LR4 has successfully exported the copyright information.
regards, JWW001
5. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
b_gossweiler Mar 20, 2012 1:26 PM (in response to JWW001)OK, I can reproduce what you're seeing. It seems to be happening when exporting a JPEG file with updated GPS data as JPEG. Doesn't happen when changing GPS data on a Raw image and exporting it as JPEG (export contains updated information).
I would report it as a bug here.
Beat
6. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
JWW001 Mar 20, 2012 1:50 PM (in response to b_gossweiler)I also have the same problem with Raw images.
I will report it
thanks, JWW001
7. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
b_gossweiler Mar 20, 2012 2:25 PM (in response to JWW001)What are the exact steps to produce with a Raw?
Beat
8. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
JWW001 Mar 21, 2012 1:14 AM (in response to b_gossweiler)For an original Raw I perform the same steps as for an original JPEG and again the changed coordinates are not written to the exported JPEG.
It is the JPEG export that doesn't write the new coordinates, it correctly writes the Copyright Info that I have input into the Metadata.
Save metadata to file, correctly writes the changed coordinates to the original file but I don't want to change the original file in any way.
John
9. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
b_gossweiler Mar 21, 2012 3:46 PM (in response to JWW001)OK, I now can see what you mean. It only happens on Raw files if they already contained GPS data in Raw-Exif while importing them.
Beat
10. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
sixninefive Apr 7, 2012 9:43 AM (in response to b_gossweiler)This was happening to me when the original RAW did not have any GPS data, then added via Map view (and jf Geocodeing plugin via GPX file). I found that the suggestion above of cycling the "remove location info" checkbox in editing publish settings for my service did the trick.
Steven
11. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
JWW001 Apr 7, 2012 10:33 AM (in response to sixninefive)I did see and try the suggestion to try cycling the 'remove location info' but unfortunately it didn't work for me.
John
13. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
JWW001 Apr 8, 2012 6:41 AM (in response to mailking)But I don't want to change my originals.
Adobe have acknowledged that my problem is a bug.
Thanks for helping
14. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
mailking Apr 8, 2012 7:27 AM (in response to JWW001)Oh... Okay, I just saw that this question was not answered. Hope it gets solved for you!
15. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
Guenther Blumenstock Apr 9, 2012 5:02 AM (in response to JWW001)I can confirm this behaviour of Geodata not being exported to JPG files by LR 4.0. It works fine for DNG and CR2 files, though.
I wonder if this has already been fixed in LR 4.1 RC. Did you try LR4.1 already?
16. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
cheliel Apr 10, 2012 1:19 PM (in response to Guenther Blumenstock)I try LR4.1 RC version but it doesn't works : my GPS coordinates are not output in my export JPGs. I don't understand.
Note : My GPS coordinates have been saved in my origins JPGs, without problem.
17. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
ChaeeBokaa Jun 2, 2017 9:53 AM (in response to JWW001)Hi guys... Is this resolved at all by Adobe OR is there any workaround for this?
I have Lightroom 6 Version 6.0 but still facing the same issue while export using GPS coded RAW file.
Bokaa
18. Re: Lightroom 4 - GPS coordinates not saved in EXIF when Exporting JPGs
johnrellis Jun 2, 2017 10:50 AM (in response to ChaeeBokaa)See my reply to your other post here: Re: GPS data are not exported
