2 Replies Latest reply on Mar 29, 2012 4:58 AM by frameexpert
    MIF and cross references
    Smartcard8101 Level 1
      I created a simple MIF file:
      <TextFlow
          <Para
              <PgfTag `Body'>
              <Pgf <PgfFont <FSize  9.0 pt> >>
              <ParaLine
                  <String `Please see the '>
                  <XRef
                      <XRefName `FunctionReference'>
                      <XRefSrcText `Table: foo'>
                      <XRefSrcFile `'>
                  <XRefEnd>
                  <String `for details.'>
      When I insert this into an existing document, there is a newline exactly where the reference should be. I could not manage to remove it. How can I get avoid of the ugly newline? Even after updating the references I get
      Please see the
      Function foo
      for details.
      instead of
      Please see the Function foo for details.
      Furthermore I defined the cross reference format as "<X-ref><$elemtext>" but the link does not work in Acrobat (although it is blue and underlined). What could be the problem?
      And finally, when I use the MIF file as an inset, the XRefFormats do not update :-( They seem once to be imported and never updated. This means when I change the format of the reference in the MIF file, the changes are not reflected in the document which includes the MIF file - not even after removing and re-inserting. The one thing that helps is to manually delete the format. Is there a way to avoid this?
      Regards
      Niki
