1. Re: cfschedule
Aaron Neff Mar 21, 2012 6:51 PM (in response to Community Help)The "result" attribute is undocumented. It is used for the list action. The result attribute should be documented in these 2 places:
1) "History" (ColdFusion Zeus: Added the attributes..)
2) Attributes table
-Aaron
2. Re: cfschedule
Aaron Neff Mar 21, 2012 7:46 PM (in response to Community Help)Three more things:
1) The "Chained Task" feature should be documented.
2) The 'Required if action="update"' should be removed from the Req/Opt column for "Operation". This is b/c operation has a default value: HTTPRequest. Thus it is not required to pass this attribute.
3) The interval, startDate, and startTime attributes are no longer required for action="update" in CF10. If omitted, the task will become a chained task. So the 'Required if action="update"' should be removed from the Req/Opt column for each of these 3 attributes as well.
-Aaron Neff
3. Re: cfschedule
Aaron Neff Apr 28, 2012 2:38 PM (in response to Community Help)It might be helpful to add this note: "ColdFusion does not invoke Application.cfc methods, when invoking a task's event handler methods."
(This is by design, per: #3151858.)
Thanks!,
-Aaron
4. Re: cfschedule
Aaron Neff Apr 30, 2012 9:36 PM (in response to Community Help)The "invokeHandler" should probably be removed from the "Default" column for onComplete, b/c onComplete does not have a default value.
-Aaron
5. Re: cfschedule
Aaron Neff May 25, 2012 3:57 PM (in response to Community Help)"isDaily" is not a valid attribute and should be removed from the attributes table.
-Aaron
6. Re: cfschedule
Lucas Sherwood May 29, 2012 3:19 AM (in response to Community Help)it also looks like the "Group" property is required for deleting tasks
7. Re: cfschedule
MrMJackson Jun 28, 2012 12:24 PM (in response to Community Help)Would be kind of helpful if you were just able to get the status of a scheduled task (on,off,paused...)
8. Re: cfschedule
Aaron Neff Jun 29, 2012 1:19 AM (in response to Lucas Sherwood)@Lucas Sherwood, the group attribute is only required when deleting a task if the task isn't in the 'default' group. Examples:
(The group attribute is omitted in the 1st example, b/c the default value for the group attribute is 'default'.)
-Aaron
9. Re: cfschedule
Aaron Neff Jun 29, 2012 1:23 AM (in response to Aaron Neff)It'd help if comments didn't hide code. Here are the examples again, just replace the square brackets w/ angle brackets:
[cfschedule action="update" task="myTask" startdate="1/1/2012" starttime="12:00 AM" interval="once" url="http://a" /]
[cfschedule action="delete" task="myTask" /]
[cfschedule action="update" task="myTask" startdate="1/1/2012" starttime="12:00 AM" interval="once" url="http://a" group="default" /]
10. Re: cfschedule
Aaron Neff Jun 29, 2012 1:57 AM (in response to MrMJackson)@MrMJackson, here are some examples for returning a task's status (Running/Paused/Expired):
[cfschedule action="update" task="myTask" startdate="1/1/2014" starttime="12:00 AM" interval="monthly" url="http://a" /]
[cfschedule action="list" task="myTask" result="q1" /]
[cfdump var="#q1.status#" /]
[cfschedule action="pause" task="myTask" /]
[cfschedule action="list" task="myTask" result="q2" /]
[cfdump var="#q2.status#" /]
Returns: Running Paused
[cfschedule action="update" task="myTask" startdate="1/1/2011" starttime="12:00 AM" interval="once" url="http://a" /]
[cfschedule action="list" task="myTask" result="q3" /]
[cfdump var="#q3.status#" /]
[cfschedule action="list" result="q4" /]
[cfdump var="#q4.status#" /]
Returns: Running Expired
That should return "Expired Expired". I will file a bug.
-Aaron
11. Re: cfschedule
Aaron Neff Oct 3, 2012 6:34 PM (in response to Community Help)The 'file' attribute's description should note: "The file can only have a .txt or .log extension by default. You can add more extensions in cfusion\lib\neo-cron xml."
This restriction is new in ColdFusion 10. ER #3336106 has been filed to also support .htm & .html extensions by default: https://bugbase.adobe.com/index.cfm?event=bug&id=3336106
12. Re: cfschedule
Charlie Arehart Jan 1, 2013 4:11 PM (in response to Community Help)Those who may want more information on the new scheduling feature in CF10 should see the corresponding chapter in the "Developing CF Apps" manual of the CF docs: http://help.adobe.com/en_US/ColdFusion/10.0/Developing/WSe61e35da8d31851899e53a51353e87049 3-8000.html
