14 Replies Latest reply on Apr 12, 2012 8:31 AM by lmtorres
    APSB12-06: Exception When Posting File After Hotfix Applied
    JR "Bob" Dobbs
      After applying the fix for APSB12-06 the exception below is logged when attempting to upload a file via a form post.
      java.lang.NoSuchMethodError: com.oreilly.servlet.multipart.MultipartParser.<init>(Ljavax/servlet/http/HttpServletReque st;J)V
          at coldfusion.filter.FormScope.fillMultipart(FormScope.java:177)
          at coldfusion.filter.FusionContext.SymTab_initForRequest(FusionContext.java:436)
          at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:33)
          at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
          at coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:126)
          at coldfusion.CfmServlet.service(CfmServlet.java:198)
          at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
          at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
          at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 )
          at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
          at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
          at jrun.servlet.FilterChain.service(FilterChain.java:101)
          at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
          at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
          at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)
          at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
          at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:203)
          at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320)
          at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
          at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266)
          at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
      This occurs on every post which includes a file, regardless of the post/file size.  I have edited my neo-runtime.xml file per the patch instructions.  Note that the site on which I am seeing this problem uses basic authentication.
      If I remove the file {ColdFusion-Home}/lib/updates/hf801-00005.jar and restore the file hf801-00004.jar (which was removed per the patch instructions) the exception no longer occurs.
      My environment:
      OS: Windows 2003 Server R2, service pack 2, 32bit
      ColdFusion: 8.0.1 with all previous security hotfixes applied
      JVM: 1.6.0_24
      Is there a fix for this problem?
      References:
      ColdFusion Security Hotfix APSB12-06
      http://helpx.adobe.com/coldfusion/kb/coldfusion-security-hotfix.html
