Hi nelsonworks
Why do you ask? Do you feel you may need more than a few?
Realistically, I believe there is no limit from the
standpoint of how many you can create. However, I do believe there
IS a limit to the size of the build expression. I think it's
about 255 characters or so. As you might imagine, if you need to
exclude a gob of tags via the expression, it behooves you to be
brief with the names of the actual tags. The build expression often
looks like this:
NOT taga AND NOT tagb AND NOT tagc AND NOT tagd
So if your tag names are long, like this:
NOT myverywonderfulbuildtaga AND NOT myverywonderfulbuildtagb
AND NOT myverywonderfulbuildtagc
you won't be able to exclude nearly as many via the
expression.
Hopefully this helps... Rick
