An alternative is to create a topic called Glossary and put
all terms and descriptions in there. Copy the text from the
projectname.GLO file and use styles (bold for the term, regular
indented for the description). You can add a button (or text),
either in the toolbar or in a topic template, to link to that
topic.
If you want to retain the info that the "class=glossterm"
provides, you could manually create tooltips with the ACRONYM tag
(see the sample code). Assign a style for that tag in your CSS
(background color, font size, etc.), and you're good to go!
We went this route because we have a huge merged Webhelp
project with 42 projects and seven authors, and we wanted to reduce
the chance of errors throughout the life of the project. This way,
there's one file that I maintain in the parent project, and I don't
worry about one or more authors not running the Glossary Hotspot
Wizard on their child projects.
Although this method requires a fair amount of work
initially, it will certainly provide the
Good luck,
Leon
