I am using invokation method to invoke adobe livecycle processes. I am able to invoke livecycle process but not able to pass the parameters in map from java code to adobe process using invocation method.
when i run the smiliar code from another machine, the process is getting invoked too and parameters are also passing. But from some machines it is only getting invoked, parameter is passed as null.
I recorded the process and found that each input parameters are null.
It is system access issue : If yes, then i should not be able to invoke the process.
i get following errors because input parameters are null
14:02:38,142 ERROR [Document] DOCS001: Unexpected exception. While doing first time passivation for a document..
at com.adobe.repository.commands.RepositoryUrlDataProviderCommand.execute(RepositoryUrlDataProviderCommand.java:162)
at com.adobe.repository.commands.CommandProcessor.execute(CommandProcessor.java:135)
at com.adobe.repository.bindings.docmanager.DocManagerBinding.repositoryUrlDataProvider(DocManagerBinding.java:185)
at com.adobe.repository.bindings.docmanager.DocManagerBinding.repositoryUrlDataProvider(DocManagerBinding.java:162)
at com.adobe.idp.RepositoryHelperImpl.callRepository(RepositoryHelperImpl.java:109)
at com.adobe.idp.RepositoryHelperImpl.callPassivate(RepositoryHelperImpl.java:82)
at com.adobe.idp.Document.passivateInitData(Document.java:1524)
at com.adobe.idp.Document.passivate(Document.java:1241)
at com.adobe.idp.Document.passivate(Document.java:1180)
at com.adobe.idp.DocumentManagerClient.getDocumentInlineData(DocumentManagerClient.java:779)
at com.adobe.pdfdocumentmanager.client.DocumentAppenderByteWriter.newDocumentByteReader(DocumentAppenderByteWriter.java:423)
at com.adobe.pdfdocumentmanager.client.SharedPdfDocumentContext.toPDFDocument(SharedPdfDocumentContext.java:747)
at com.adobe.formServer.utils.CommonGibsonUtils.PDFDocumentFromDocument(CommonGibsonUtils.java:127)
at com.adobe.printSubmitter.PrintServer.transformPDF(PrintServer.java:336)
at com.adobe.printSubmitter.service.OutputServiceImpl.transformPDFInTxn(OutputServiceImpl.java:777)
at com.adobe.printSubmitter.service.OutputServiceImpl$4.doInTransaction(OutputServiceImpl.java:741)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doRequiresNew(EjbTransactionBMTAdapterBean.java:218)
at sun.reflect.GeneratedMethodAccessor302.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionContainer.java:237)
at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:158)
at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:173)
at org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:77)
at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstanceInterceptor.java:169)
at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:168)
at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor.java:138)
at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:648)
at org.jboss.ejb.Container.invoke(Container.java:960)
at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:430)
at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
at $Proxy216.doRequiresNew(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvider.java:133)
at com.adobe.idp.dsc.transaction.impl.DefaultTransactionTemplate.execute(DefaultTransactionTemplate.java:79)
at com.adobe.printSubmitter.service.OutputServiceImpl.transformPDFWithSMT(OutputServiceImpl.java:735)
at com.adobe.printSubmitter.service.OutputServiceImpl.transformPDF(OutputServiceImpl.java:724)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.java:118)
at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor.java:140)
at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptorChainImpl.java:60)
at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassivationInterceptor.java:53)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(TransactionInterceptor.java:74)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doBMT(EjbTransactionBMTAdapterBean.java:197)
at sun.reflect.GeneratedMethodAccessor308.invoke(Unknown Source)
at $Proxy216.doBMT(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvider.java:95)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInterceptor.java:72)
at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStrategyInterceptor.java:55)
at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateInterceptor.java:37)
at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterceptor.java:188)
at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:121)
at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessageReceiver.java:93)
at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:225)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispatcher.java:66)
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:861)
at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke(WorkflowDSCInvoker.java:347)
at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:158)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTransactionCMTAdapterBean.java:357)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequiresNew(EjbTransactionCMTAdapterBean.java:299)
at sun.reflect.GeneratedMethodAccessor289.invoke(Unknown Source)
at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:404)
at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:181)
at $Proxy215.doRequiresNew(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvider.java:143)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.invoke(AbstractMessageReceiver.java:329)
at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invokeCall(SoapSdkEndpoint.java:139)
at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invoke(SoapSdkEndpoint.java:81)
at sun.reflect.GeneratedMethodAccessor514.invoke(Unknown Source)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at com.adobe.idp.dsc.provider.impl.soap.axis.InvocationFilter.doFilter(InvocationFilter.java:43)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at com.adobe.idp.um.auth.filter.CSRFFilter.doFilter(CSRFFilter.java:41)
at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:179)
at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:84)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:157)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:241)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:580)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:619)
14:02:38,154 ERROR [OutputException] ALC-OUT-001-204: Could not transform input PDF file. com.adobe.repository.RepositoryException cannot be cast to com.adobe.repository.ResourceNotFoundException
14:02:38,175 ERROR [WorkflowDSCInvoker] An exception was thrown with name com.adobe.livecycle.output.exception.OutputException message:ALC-OUT-001-204: Could not transform input PDF file. com.adobe.repository.RepositoryException cannot be cast to com.adobe.repository.ResourceNotFoundException while
Solved! Go to Solution.
Total Likes
my jboss is running on windows 2008 and when i restarted the jboss server as administrator it worked fine. But i am confused.. why it didnt work tho i am adminstrator on this machine.
Total Likes
Total Likes
