Updated to flash 11, and i can not add a folder to the "trusted file location". Once i add it and "confirm" and close the settings, and reopen it, it has disappeard. I have tried a fresh install but that did not work.
Any help is appreciated!! Thanks
This might help: http://blog.vizio360.co.uk/2010/02/flash-trust-file-on-windows-7/
Hi Kendrik,
What OS and browser are you using?
Chris
Windows 7 64 bit.
Have you tried http://forums.adobe.com/thread/892474 ?
Tried but still does not want to save the trusted folder.
Could you please check the mms.cfg available in the %WINDIR%\SysWow64\Macromed\Flash directory? Is there any entry for AllowUserLocalTrust. Just checking ... Since you have deleted that folder, chances are less.
I checked but im not seing anything like that. Would there be something in registry i could edit that would allow it?
Could you please check to make use the OS can see hidden files and folders. The ProgramData directory in Windows 7 is hidden by default.
For more info, see: The User Flash Player Trust directory
I checked all that before i even added a folder to the trusted file, i can see hidden files/folders.
Do you have Global Security Settings configured to "Always Deny"? The panel you see there contains the current settings on your own machine. You should be able to add to it by using the menu.
No, i have it set to "Always Ask". It seems whatever browser i use to edit those settings, once i close that browser, it deleted the settings (Trusted files location).
OMG I dont know how to thank you. It works like a charm. Thank you so much for the help!!!!
You're welcome.
