We are trying to use a web service to retrieve a recordset
from a API on a remote server via COM. I created a CFC on the API
server to handle the communication with the COM objects. It has
been set up to act as a web service. I then have a script running
on our web server that invokes the web service to retrieve the
information requested. I am getting the following error and am
stuck. I was wondering if anyone had any ideas. Below is the error
and and the two code files. Thanks in advance for any help.
Error:
Exceptions
14:22:08.008 - Application Exception - in
C:\CFusionMX\wwwroot\test4.cfm : line 15
Could not perform web service invocation
"getCustGeneralInfo" because AxisFault
faultCode: {
http://schemas.xmlsoap.org/soap/envelope/}Server.userException
faultSubcode:
faultString: org.xml.sax.SAXParseException: Next character
must be ">" terminating comment .
faultActor:
faultNode:
faultDetail:
http://xml.apache.org/axis/}stackTrace:
org.xml.sax.SAXParseException: Next character must be ">"
at
org.apache.crimson.parser.Parser2.fatal(Parser2.java:3339)
at
org.apache.crimson.parser.Parser2.fatal(Parser2.java:3333)
at
org.apache.crimson.parser.Parser2.nextChar(Parser2.java:3255)
at
org.apache.crimson.parser.Parser2.maybeComment(Parser2.java:1051)
at
org.apache.crimson.parser.Parser2.maybeMisc(Parser2.java:1233)
at
org.apache.crimson.parser.Parser2.parseInternal(Parser2.java:621)
at org.apache.crimson.parser.Parser2.parse(Parser2.java:333)
at
org.apache.crimson.parser.XMLReaderImpl.parse(XMLReaderImpl.java:448)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:345)
at org.apache.axis.encoding...
Calling file:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01
Transitional//EN">
<html>
<head>
<title>Service</title>
</head>
<body>
<cfinvoke webservice="
http://localhost:8500/components/CustInfo.cfc?wsdl"
method="getCustGeneralInfo"
returnVariable="rData">
<cfinvokeargument name="companyID" value="100">
<cfinvokeargument name="accountNumber" value="2839">
<cfinvokeargument name="tankNumber" value="0">
</cfinvoke>
</body>
</html>
CFC:
<cfcomponent>
<cffunction name="getCustGeneralInfo" access="remote"
returntype="any" output="false">
<cfargument name="companyID" default="" hint="companyID"
required="true" type="numeric">
<cfargument name="accountNumber" default=""
hint="Customer account number" required="true" type="numeric">
<cfargument name="tankNumber" default="" hint="Customer
tank number" required="true" type="numeric">
<CFOBJECT ACTION="CREATE" NAME="getLogin"
CLASS="EnergyAPI.cCustomerInfo">
<cfset iCompanyID = 100>
<cfset lAccountNumber = 2839>
<cfset cSysUser = "WebUser">
<cfset lRetCode = "">
<CFSET resultSet=getLogin.GetGeneralInfo(iCompanyID,
lAccountNumber, cSysUser, lRetCode)>
<cfreturn resultSet>
</cffunction>
<cffunction name="getDelivGeneralInfo" access="remote"
CLASS="EnergyAPI.cDelivery">
<cfset iCompanyID = arguments.comapnyID>
<cfset lAccountNumber = arguments.accountNumber>
<cfset iTankNumber = arguments.tankNumber>
lAccountNumber, iTankNumber, cSysUser, lRetCode)>
</cffunction>
<cffunction name="getServiceGeneralInfo" access="remote"
<cfargument name="serviceNumber" default=""
hint="Customer tank number" required="true" type="numeric">
CLASS="EnergyAPI.cService">
<cfset iServiceNum = arguments.serviceNumber>
lAccountNumber, iServiceNum, cSysUser, lRetCode)>
</cffunction>
</cfcomponent>
