0 Replies Latest reply: Mar 26, 2012 1:04 AM by Macnimation RSS
    FMS 4.5 and H.264 - streaming is irratic and slow with FMLE 3.2
    Macnimation Community Member
      When I stream using VP6 the streams are stable and good quality.
      I have starting playing with the H.264 format to see what improvements I can get out of it.
      I find that when I use H.264 and use the MP4 format, the streams buffer a lot and get irratic with momenary freezing.
      What is causing this and where can I find straight forward informtion on different setups using FMLE 3.2 aith FMS 4.5?
      I have tried 100, 200, 500 and higher Bit Rates but they all behave the same.
      I am using a custom built machine that is dedicated to FMS 4.5. It has 8 physical Quad Duo Core Xeon processors with 24 GB RAM and 8 TB Hard Drives. The main drive is a 256 GB SSD.
      The network is a gigabit lan, and all of the test computers running FMLE 3.2 would be similar.
      This should rule out network issues and processing problems.
