4 Replies Latest reply on Mar 26, 2012 4:22 AM by MSSDedalus
    How to localize Photoshop layer names
    MSSDedalus Level 1
      I'm trying to get the default layer names for background, group, etc used by Photoshop depending on users local language.
      As I haven't found a direct way I decided to use javascript instead:
      I have a jsx code like
      function GetBackground()
      var message = localize( "$$$/LayerName/Background=Background");
      return message;
      and in the extension I use
      var result:SyncRequestResult = CSXSInterface.instance.evalScript("GetBackground");
      trace(result);
      but result value is undefined.
      Any help would be appreciated.
        • 1. Re: How to localize Photoshop layer names
          emerasoft.srl
          Hello MSSDedalus,
          the returned result from the called extend is in form of a object; so you should add this code to the extendscript (just a example):
          var xml = '<object>';
          var xml = xml += '<property id="strMessage"><string>'+message+'</string></property>';
          var xml = xml += '</object>';
          and then return the xml variable instead of the message one.
          Then, you should have to modify the actionscript code as well:
          var oResult:Object;
              if((SyncRequestResult.COMPLETE == result.status) && result.data)
               oResult = result.data as Object;
               //Make sure oResult has the property you are expecting
                 if(oResult.hasOwnProperty("strMessage"))
                  var localizedString:String = oResult.strMessage;
          This can be found on the official documentation too.
          Best,
          Luca
          • 2. Re: How to localize Photoshop layer names
            MSSDedalus Level 1
            Thanks so much, Luca
            I believe I have to look more carefully at the samples, had tried almost anything except the correct way.
            • 3. Re: How to localize Photoshop layer names
              Harbs. Adobe Community Professional & MVP
              Have you tried this? (no separate jsx required)
              var message:String = HostObject.getRoot(HostObject.extensions[0]).localize( "$$$/LayerName/Background=Background");
              1 person found this helpful
              • 4. Re: How to localize Photoshop layer names
                MSSDedalus Level 1
                Just tried and works fine, thanks.
                May be even better for my purpose as I don't need to add jsx.
