1 2 Previous Next 46 Replies Latest reply on Jul 23, 2013 12:14 PM by Sanjupr
    LDAP set up with CQ 5.5
    Murali Vusthipalli
      These instructions: http://dev.day.com/docs/en/cq/current/core/administering/ldap_authentication.html#Switchin g On LDAP Authentication does not seem to be updated for 5.5, because the file crx-quickstart\server\etc\ldap_login.conf does not exist(even the server directory does not exist). Could any one help?
        • 1. Re: LDAP set up with CQ 5.5
          hypnotec Adobe Employee
          see the user comment at the bottom of said documentation page:
          "Upgaded a 5.4 instance to 5.5 and LDAP does not work right away. You need to provide the full path to the ldap_login.conf on the start script."
          • 2. Re: LDAP set up with CQ 5.5
            Murali Vusthipalli Level 1
            Thanks Hypnotec
            • 3. Re: LDAP set up with CQ 5.5
              Also, http://dev.day.com/docs/en/cq/current/core/administering/ldap_authentication.html#Increase the logging level for LDAP to DEBUG. I can not find the file:crx-quickstart/server/runtime/0/_crx/WEB-INF/log4j.xml to debug the LDAP issues as server folder does not exist. Could you help me with this?
              • 4. Re: LDAP set up with CQ 5.5
                again, the documentation is outdated. log levels are managed via the system console (e.g. http://localhost:4502/system/console/configMgr). consult the logging docs: http://dev.day.com/docs/en/cq/current/deploying/configure_logging.html - i think they're reasonably up to date for instance, add a logger for the ldap package.
                • 5. Re: LDAP set up with CQ 5.5
                  Based on the documentation(pasted below), I would need to know the name of the OSGI service for LDAP logging. Could you please help with the right name for this?
                  specify the OSGi services for which the Logger is to log messages; for example, all of the following:
                  • org.apache.sling
                  • org.apache.felix
                  • com.day
                  • 6. Re: LDAP set up with CQ 5.5
                    Is this: com.day.crx.security.ldap.LDAPLoginModule the right one?
                    • 7. Re: LDAP set up with CQ 5.5
                      it is the java package name of the login module as referenced in your JAAS configuration.
                      • 8. Re: LDAP set up with CQ 5.5
                        Thanks for such a quick reply, hypnotec.... really appreciate it!
                        • 9. Re: LDAP set up with CQ 5.5
                          yes, or just the package name to have all classes: com.day.crx.security.ldap
                          • 10. Re: LDAP set up with CQ 5.5
                            My CQ instance is not coming up after I made changes to repository.xml and ldap_login.conf. Below is the error message that it is showing in error.log. I have configured a new logger for ldap, but it does not seem to have created, is it because CQ is down? Could you please help me? Thanks so much.
                            Exception in error.log:
                            27.03.2012 14:05:48.234 *ERROR* [FelixStartLevel] org.apache.jackrabbit.core.RepositoryImpl failed to start Repository: Neither JAAS nor RepositoryConfig contained a valid configuration for com.day.crx javax.jcr.RepositoryException: Neither JAAS nor RepositoryConfig contained a valid configuration for com.day.crx
                                      at org.apache.jackrabbit.core.DefaultSecurityManager.init(DefaultSecurityManager.java:178)
                                      at org.apache.jackrabbit.core.UserPerWorkspaceSecurityManager.init(UserPerWorkspaceSecurityM anager.java:107)
                                      at com.day.crx.core.CRXSecurityManager.init(CRXSecurityManager.java:39)
                                      at org.apache.jackrabbit.core.RepositoryImpl.initSecurityManager(RepositoryImpl.java:463)
                                      at org.apache.jackrabbit.core.RepositoryImpl.<init>(RepositoryImpl.java:324)
                                      at com.day.crx.core.CRXRepositoryImpl.<init>(CRXRepositoryImpl.java:283)
                                      at com.day.crx.core.CRXRepositoryImpl.create(CRXRepositoryImpl.java:258)
                                      at com.day.crx.core.CRXRepositoryImpl.create(CRXRepositoryImpl.java:243)
                                      at com.day.crx.sling.server.impl.jmx.ManagedRepository.activate(ManagedRepository.java:164)
                                      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                                      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                                      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                                      at java.lang.reflect.Method.invoke(Unknown Source)
                                      at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:227)
                                      at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:38)
                                      at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:591)
                                      at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:472)
                                      at org.apache.felix.scr.impl.helper.ActivateMethod.invoke(ActivateMethod.java:146)
                                      at org.apache.felix.scr.impl.manager.ImmediateComponentManager.createImplementationObject(Im mediateComponentManager.java:226)
                                      at org.apache.felix.scr.impl.manager.ImmediateComponentManager.createComponent(ImmediateComp onentManager.java:118)
                                      at org.apache.felix.scr.impl.manager.DelayedComponentManager.createRealComponent(DelayedComp onentManager.java:95)
                                      at org.apache.felix.scr.impl.manager.AbstractComponentManager$Registered.getService(Abstract ComponentManager.java:1296)
                                      at org.apache.felix.scr.impl.manager.DelayedComponentManager.getService(DelayedComp
                            • 11. Re: LDAP set up with CQ 5.5
                              Ron @ SFU
                              Hi Murali,
                              The problem is probably due to a misconfiguration in your ldap_login.conf or repository.xml file. Make sure your repository.xml is a valid XML (i.e. all tags, quotes are properly closed).  If you're still having problems please post your repositor.xml and ldap_login.conf.
                              Hope this helps.
                              Ron
                              • 12. Re: LDAP set up with CQ 5.5
                                Hi Ron,
                                Thanks for your reply. Here are the configuration files. When I use an active directory client tool, it works fine.
                                ldap_login.conf:
                                com.day.crx {
                                   com.day.crx.core.CRXLoginModule sufficient;
                                   com.day.crx.security.ldap.LDAPLoginModule required
                                                principal_provider.name="RootDSE"
                                                principal_provider.class="com.day.crx.security.ldap.principals.LDAPPrincipalProvider"
                                              host="<MYLDAPHOST>"
                                              port="389"
                                              authDn="CN=Murali,OU=Users Accounts (UnSorted),DC=us,DC=ad,DC=com"
                                                authPw="March1234%"
                                              userRoot="OU=eBT,OU=Users Accounts (UnSorted),DC=us,DC=ad,DC=com"
                                                userIdAttribute="sAMAccountName"
                                                groupRoot="CN=eBT-IWOV,OU=eBT,OU=User and Group Accounts,DC=us,DC=ad,DC=com"
                                                groupMembershipAttribute="member"
                                                autocreate="create"
                                              autocreate.path="none"
                                              autocreate.user.cn="rep:fullname"
                                              autocreate.user.mail="profile/email"
                                              autocreate.user.sn="profile/familyName"
                                              autocreate.user.givenName="profile/givenName"
                                              autocreate.group.cn="rep:fullname";
                                              autocreate.group.mail="profile/email"
                                              cache.expiration="7200"
                                              cache.maxsize="200"
                                repository.xml:
                                <!DOCTYPE Repository PUBLIC "-//Day Management AG//DTD CRX 2.4//EN"
                                                            "http://www.day.com/dtd/repository-2.4.dtd">
                                <Repository>
                                    virtual file system where the repository stores global state
                                    (e.g. registered namespaces, custom node types, etc.)
                                    <FileSystem class="com.day.jackrabbit.fs.cq.CQFileSystem">
                                        <param name="path" value="${rep.home}/repStore.dat"/>
                                        <param name="autoRepair" value="false"/>
                                    </FileSystem>
                                    <FileSystem class="org.apache.jackrabbit.core.fs.local.LocalFileSystem">
                                        <param name="path" value="${rep.home}/repository"/>
                                    </FileSystem>
                                    large binary objects are stored in the data store.
                                    <DataStore class="com.day.crx.core.data.ClusterDataStore"/>
                                    security configuration
                                    <Security appName="com.day.crx">
                                            security manager:
                                            class: FQN of class implementing the JackrabbitSecurityManager interface
                                        <!--SecurityManager class="com.day.crx.core.CRXSecurityManager" workspaceName="" -->
                                        <SecurityManager class="com.day.crx.core.CRXSecurityManager">
                                            optional user manager configuration
                                            <UserManager class="org.apache.jackrabbit.core.security.user.UserPerWorkspaceUserManager">
                                                <param name="usersPath" value="/home/users"/>
                                                <param name="groupsPath" value="/home/groups"/>
                                                <param name="defaultDepth" value="1"/>
                                                <param name="autoExpandTree" value="true"/>
                                                <AuthorizableAction class="org.apache.jackrabbit.core.security.user.action.AccessControlAction">
                                                  <param name="groupPrivilegeNames" value="jcr:read"/>
                                                  <param name="userPrivilegeNames" value="jcr:all"/>
                                                </AuthorizableAction>
                                                <!--AuthorizableAction class="com.day.crx.core.ntlm.NTLMAuthorizableAction"/>-->
                                            </UserManager>
                                            optional workspace access manager configuration
                                        </SecurityManager>
                                        access manager:
                                        class: FQN of class implementing the AccessManager interface
                                        <AccessManager class="org.apache.jackrabbit.core.security.DefaultAccessManager"></AccessManager>
                                        Use LoginModule authenticating against repository itself
                                        <!--LoginModule class="com.day.crx.core.CRXLoginModule">
                                            <param name="anonymousId" value="anonymous"/>
                                            <param name="adminId" value="admin"/>
                                            <param name="disableNTLMAuth" value="true"/>
                                            <param name="tokenExpiration" value="43200000"/>
                                        </LoginModule-->
                                    </Security>
                                    location of workspaces root directory and name of default workspace
                                    <Workspaces rootPath="${rep.home}/workspaces" defaultWorkspace="crx.default" maxIdleTime="5"/>
                                    workspace configuration template:
                                    used to create the initial workspace if there's no workspace yet
                                    <Workspace name="${wsp.name}" simpleLocking="true">
                                        virtual file system of the workspace:
                                        class: FQN of class implementing FileSystem interface
                                            <param name="path" value="${wsp.home}"/>
                                        </FileSystem>
                                        persistence manager of the workspace:
                                        class: FQN of class implementing PersistenceManager interface
                                        <PersistenceManager class="com.day.crx.persistence.tar.TarPersistenceManager"/>
                                        Search index and the file system it uses.
                                        <SearchIndex class="com.day.crx.query.lucene.LuceneHandler">
                                            <param name="path" value="${wsp.home}/index"/>
                                            <param name="resultFetchSize" value="50"/>
                                        </SearchIndex>
                                        Workspace security configuration
                                        <WorkspaceSecurity>
                                            <AccessControlProvider class="org.apache.jackrabbit.core.security.authorization.acl.ACLProvider">
                                                <param name="omit-default-permission" value="true"/>
                                            </AccessControlProvider>
                                        </WorkspaceSecurity>
                                        XML Import configuration of the workspace
                                        <Import>
                                            <ProtectedItemImporter class="org.apache.jackrabbit.core.xml.AccessControlImporter"/>
                                            <ProtectedItemImporter class="org.apache.jackrabbit.core.security.user.UserImporter">
                                                <param name="importBehavior" value="besteffort"/>
                                            </ProtectedItemImporter>
                                        </Import>
                                    </Workspace>
                                        Configures the versioning
                                    <Versioning rootPath="${rep.home}/version">
                                            Configures the filesystem to use for versioning of the respective
                                            persistence manager
                                            <param name="path" value="${rep.home}/version"/>
                                        </FileSystem>
                                            Configures the persistence manager to use for the versioning.
                                            Please note, that the current versioning implementation is based on
                                            a 'normal' persistence manager, but this could change in future
                                            implementations.
                                    </Versioning>
                                        Enable searching the /jcr:system subtree
                                        <param name="path" value="${rep.home}/repository/index"/>
                                    </SearchIndex>
                                        Cluster configuration.
                                    <Cluster>
                                        <Journal class="com.day.crx.persistence.tar.TarJournal"/>
                                    </Cluster>
                                        Configures extension modules
                                    <Modules>
                                           Sample configuration of an EventLoggerModule requiring configuration
                                           <Module class="com.day.crx.eventlogger.EventLoggerModule">
                                               <param name="workspaces" value="crx.default"/>
                                               <param name="logWorkspace" value="crx.logger"/>
                                               <param name="logPath" value="/logger"/>
                                           </Module>
                                    </Modules>
                                </Repository>
                                • 13. Re: LDAP set up with CQ 5.5
                                  justin_at_adobe Adobe Employee
                                  Murali-
                                  I believe you are missing a semi-colon after cache.maxsize="200" and there's an extra semi-colon after autocreate.group.cn="rep:fullname"
                                  The semi-colon has to go at the end of the options, not in the middle.
                                  I'm a bit surprised that JAAS isn't complaining about this with a meaningful (or even not-so meaningful) error message.
                                  Justin
                                  • 14. Re: LDAP set up with CQ 5.5
                                    Thanks Justin. My CQ instance is up and running now. I want to sync a user from LDAP to CQ, so with reference to the document: http://dev.day.com/docs/en/cq/current/core/administering/ldap_authentication.html#LDAP User Synchronization, I can't locate LDAP User Synchronization option in CRX explorer. Could you please help?
                                    • 15. Re: LDAP set up with CQ 5.5
                                      Ron @ SFU Level 1
                                      Hi Murali,
                                      The documentation is outdated for 5.5.  I haven't been able to find that feature in 5.5, but if your CQ instance is properly connected to your LDAP then you should just be able to login with your LDAP credentials.  Since you have autocreate="create" within your ldap_login.conf file, it should automatically create/sync that account from LDAP to CQ.
                                      Cheers,
                                      Ron
                                      • 16. Re: LDAP set up with CQ 5.5
                                        Ron, I tried to login using my domain id, password with many different ways(id,name,lastname, firstname), but it does not work. I have also looked at /home/users and /home/groups, it does not have any domain ids there.
                                        • 17. Re: LDAP set up with CQ 5.5
                                          Ron @ SFU Level 1
                                          Any errors in the error.log?  You may need to enable debug logging for LDAP to get more info.  My guess CQ can't find the user in LDAP.  The problem might be your values for 'userRoot' in your ldap_login.conf.  From looking at your authDn "CN=Murali,OU=Users Accounts (UnSorted),DC=us,DC=ad,DC=com", I suspect your userRoot should be ""OU=Users Accounts (UnSorted),DC=us,DC=ad,DC=com".  Give that a try.
                                          • 18. Re: LDAP set up with CQ 5.5
                                            You are right. After changing the userRoot, it started working. I am able to login using domain id/pwd. But the custom LDAP log file(that I created as mentioned in this thread above) is not created under logs or any where else under crx-quickstart.
                                            • 19. Re: LDAP set up with CQ 5.5
                                              That is working now, Ron. The log file path should not contain ".." in the path as in (../logs/ldap.log). Once I changed that to /logs/ldap.log, it started working.
                                              Another question: On my ldap server, I have two locations where CQ users are created. How can I configure two locations in ldap_login.conf?
                                              For ex:
                                              userRoot: OU=Users Accounts (UnSorted),DC=us,DC=ad,DC=com and
                                              OU=eBT,OU=ParkRidge,OU=Users Accounts and Groups,DC=us,DC=ad,DC=com
                                              • 20. Re: LDAP set up with CQ 5.5
                                                Ron @ SFU Level 1
                                                Glad it hear it's working now.  As for different userRoots, not sure if you can use a more top level userRoot (e.g. DC=us,DC=ad,DC=com) with a userFilter.  You may need to check with you LDAP admin.   But you may be able to just simply setup this other userRoot as a separate LDAP server.  Checkout this KB article - http://dev.day.com/content/kb/home/Crx/CrxSystemAdministration/HowToMultipleLdapServer.htm l
                                                • 21. Re: LDAP set up with CQ 5.5
                                                  Thank you so much for the help!!
                                                  Sure, I will refer that KB article. One more observation is that after I login for the first time using the domain id, the documentation says that it will copy the LDAP groups to CRX. It did not happen even after I login multiple times. LDAP.log file does not show any messages related to that. Could you please help?
                                                  • 22. Re: LDAP set up with CQ 5.5
                                                    Ron @ SFU Level 1
                                                    Problem seems to be your groupRoot of "CN=eBT-IWOV,OU=eBT,OU=User and Group Accounts,DC=us,DC=ad,DC=com".  I'm assuming your group ID/name is 'eBT-IWOV'.  Since the default groupNameAttribute is "cn", try setting your groupRoot to "OU=eBT,OU=User and Group Accounts,DC=us,DC=ad,DC=com".  You will need to restart CQ for the changes take affect.
                                                    • 23. Re: LDAP set up with CQ 5.5
                                                      I have been assigned to multiple groups on active directory and eBT-IWOV is one of them. And OU=eBT,OU=User and Group Accounts,DC=us,DC=ad,DC=com has lot of other groups under it. I am confused on how CQ works with LDAP actually - does it pull all the groups that the logged in user belongs to under the groupRoot? or when a user logs in, will it pull up all the groups under the groupRoot?
                                                      I have already tried groupRoot as OU=eBT,OU=User and Group Accounts,DC=us,DC=ad,DC=com, but I don't see any groups created in CQ.
                                                      • 24. Re: LDAP set up with CQ 5.5
                                                        Ron @ SFU Level 1
                                                        From my understanding, the way CQ's LDAPUserSync work is that it will import and create the LDAP groups that is under the defined groupRoot that that user is a member of.  One problem is that CQ's LDAPUserSync isn't compatible with your LDAP Schema.  We had this problem initially because of the way we were storing groups in LDAP.
                                                        We were initially storing our group information in an object which has a member of locally defined attributes and stores the members of the group in multi-valued "memberUid" attributes (e.g. Murali). CQ assumes that the value of the member attribute has the form of the fully qualified name (e.g. uid=Murali,OU=Users Accounts (UnSorted),DC=us,DC=ad,DC=com).  So when it searches for group members it searches for "memberUid=uid=Murali,OU=Users Accounts (UnSorted),DC=us,DC=ad,DC=com" which produces no match.
                                                        Now, we have since changed our LDAP schema to match this, however, we are still unhappy with the CQ LDAPUserSync.  Problem we have discovered is that when it creates CQ groups pulled from LDAP, it creates the group with the ID using the principal-name which is the full DN in LDAP.  For example, it will actually create the LDAP group of eBT-IWOV as /home/groups/C/CN/CN=eBT-IWOV,OU=eBT,OU=User and Group Accounts,DC=us,DC=ad,DC=com (if using <param name="defaultDepth" value="3"/> for the com.day.crx.core.CRXUserManagerImpl in repository.xml).  This is a problem for us because it would result in a very flat group hiearchy in the repository, creating 1000's of group records under the same node of /home/groups/C/CN/.
                                                        Since CRX2.2 (CQ5.4) the UserManager API has been updated to allow for creating groups with arbitrary groupd IDs (e.g. CN valud of the LDAP group).  However, we were disappointed to discover that in 5.5 the LDAPUserSync hasn't been updated yet to make use of new API.  So since 5.4, we've been managing groups manually using scripts and we automate the synching vai cron job.
                                                        Within the CQ Higher Education group, I don't believe anyone uses the LDAPUserSync for group integration simply because of its limitations.
                                                        • 25. Re: LDAP set up with CQ 5.5
                                                          Thanks for the such an useful information, Ron. From your experience, it would be great if you suggest an ideal LDAP schema for CQ needs? Do we have to create a special CQ LDAP group and then assign all users to that. And do we need to make sure that these LDAP user ids don't belong to any other LDAP groups?
                                                          • 26. Re: LDAP set up with CQ 5.5
                                                            C. Vozar - CITYTECH
                                                            For new Adobe CQ5.5 users I feel this thread needs a bit of clarity on LDAP integration with CQ. I wrote a blog about the topic: http://www.citytechinc.com/us/en/blog/2012/03/adobe_cq5_5_and_ldap.html but will elaborate here.
                                                            The changes to LDAP setup between CQ 5.4 and 5.5 are minimal (and mainly just not particularly clear) but the documentation on the support site has yet to reflect it. In CQ 5.5 (a fresh install) you will not get a /crx-quickstart/server/etc/sample_ldap_login.conf file to modify. However, it's still appropriate to use in 5.5 as JAAS configs are a standard for the JVM. Also, beware if you enable JAAS in the quickstart script that comes with 5.5, it has an order of parameters issue and JAAS configs won't parse correctly, you'll need to specify the JAAS config prior to the -jar JVM option.
                                                            In short if you are a new CQ user to 5.5 and looking for LDAP integration simply use the sample on the support site but refernce the configuration in the JVM as a command-line option rather than trying to figure out why /server/etc no longer exists.
                                                            • 27. Re: LDAP set up with CQ 5.5
                                                              rguggenb
                                                              I'm getting the following error after a login with correct credentials (authentication works):
                                                              java.lang.IllegalArgumentException: Invalid token ''
        at org.apache.jackrabbit.api.security.authentication.token.TokenCredentials.(TokenCredential s.java:42)
        at com.day.crx.security.token.impl.TokenAuthenticationHandler.createCredentials(TokenAuthent icationHandler.java:528)
        at com.day.crx.security.token.impl.TokenAuthenticationHandler.extractCredentials(TokenAuthen ticationHandler.java:345)
        at org.apache.sling.auth.core.impl.AuthenticationHandlerHolder.doExtractCredentials(Authenti cationHandlerHolder.java:75)
                                                              at org.apache.sling.auth.core.impl.AbstractAuthenticationHandlerHolder.extractCredentials(Ab stractAuthenticationHandlerHolder.java:60)
        Truncated. see log file for complete stacktrace
                                                              Any ideas on how to troubleshoot?
                                                              • 28. Re: LDAP set up with CQ 5.5
        kstailey
        The invalid token error followed by empty single quotes '' is coming out of jackrabbit code that checks if the token is null or an empty string.
        if (token == null || token.length() == 0) {
        throw new IllegalArgumentException("Invalid token '" + token + "'");
        The way it works for me:
        1. Log in as an administrator.  I use admin
        2. Delete any LDAP created test user account so logging in will be creating the account using LDAP.
        3. Log into the the Felix (Web) Console as admin and keep this window open for the duration of this test.
        4. Log out of CQ but not the Felix (Web) Console.  Since the console uses HTTP basic auth you can do this.
        5. Log out all users from CQ.
        6. Use the Felix console CRX Login Tokens display to see that there are no tokens.
        7. Configure CQ to use LDAP and try to log in to the test account that had no CQ account created yet.
        8. The CQ will return error 500 as jackrabbit throws "Invalid token '' "
        9. Your account will be created anyway from the LDAP data.
        10. Use the Felix console CRX Login Tokens display to see that there is no token for your account.
        11. Delete the cookie from your web browser with the host name of your CQ URL and the value "login-token".
        12. Try to login to CQ using your LDAP account again.  This time you will get a login token and things will be normal.
        Why doesn't the first login attempt get a CRX Login Token?
        • 29. Re: LDAP set up with CQ 5.5
        kstailey Level 1
        Also the cookie that comes back on the first LDAP login that creates the QA account has three fields and the second one is not filled in.
        The details of a sample cookie from the create followed by the cookie content from the second login:
        b7649c06-ad22-4115-8947-773f030f5579::crx.default
        b7649c06-ad22-4115-8947-773f030f5579:cbb60011-7526-4282-b89f-b44777def323_f9c7d8a78e20d620:crx.default
        The LDAP login that creates the CQ account has a cookie with an empty second colon separated field.  Most likely that field would have the CRX Login Token if there was one.
        • 30. Re: LDAP set up with CQ 5.5
        kstailey Level 1
        Tokens are stored in the user's home directory jcr node tree.
        There is no home directory jcr node tree for an LDAP user that has never logged in.  Autocreate mode specifies that the account is created on demand including the home directory.
        If the user's LDAP CN is Adams\, Alice
        and LDAP sAMAccountName is A-Adams
        Then on the first login, autocreate causes these nodes to be created
        /home/users/Adams\, Alice/A-Adams
        /home/users/Adams\, Alice/A-Adams/profile
        /home/users/Adams\, Alice/A-Adams/rep:policy
        /home/users/Adams\, Alice/A-Adams/rep:policy/allow
        What is not created is:
        /home/users/Adams\, Alice/A-Adams/.tokens
        I think that the routine that creates the .tokens node is executed prior to the one that creates the parent node of .tokens (in this case /home/users/Adams\, Alice/A-Adams).  The result is that it fails to create the .tokens node.
        The second LDAP login works, the home directory already exists and the .tokens node is created.
        • 31. Re: LDAP set up with CQ 5.5
        Vijay Nagpal
        Same problem here. First time login does not work for LDAP user because of blank token. Are there any workarounds/config changes that will help first-time login to succeed?
        • 32. Re: LDAP set up with CQ 5.5
        kstailey Level 1
        If your LDAP (AD) user name contains upper case letters you must type them in exactly as they are in LDAP (AD) in order to avoid this error.
        • 33. Re: LDAP set up with CQ 5.5
        sBurogyne
        Hello Ron,
        I have a similar problem, i have doublecheck with my repository.xml, it's exactly the same as Murali posted.. and my ldap_login.conf, i actually name my config file jaas.conf, here is the content of my jaas.conf:
        com.day.crx {
        host="my ldap server"
        port="389"
        secure="false"
        authDn="cn=dcp,ou=users,o=com"
        authPw="XXXXXX"
        userRoot="ou=users,o=com"
        userFilter="(objectclass=user)"
        userIdAttribute="cn"
        groupRoot="ou=groups,o=com"
        autocreate="create"
        autocreate.user.membership="contributor"
        autocreate.user.givenname="profile/givenName"
        autocreate.path="direct"
        cache.expiration="600"
        cache.maxsize="1000";
        I tested the config by running the following comment:
        java -Djava.security.auth.login.config=c:/cq/author/crx-quickstart/etc/jaas.conf -Xmx1024M -XX:MaxPermSize=256M -jar cq5-author-p4502.jar
        I have been look at it for a day now and don't seem to figure out.. I am running CQ5.5 on my localhost. Any help will be great.
        Silka B.
        • 34. Re: LDAP set up with CQ 5.5
        Sanjupr
        I think i was able to replicate, in my case this, it had to do with the username ie SamAccountName(logon name) and Distinguished name.
        Lets say the user in ldap exist as Tom DN(CN=Tom,CN=Users,DC=vmlabs,DC=ad,DC=local). But the logon name is tom(lower case).
        case1: Login as Tom.
        When ldap does the lookup it does find Tom, it creates a user as Tom, it would generates a  login token and the login is successfull.
        If you see in the crx, you will see a new user with Tom.
        Delete the user that got created
        Case2: login as tom.
        Ldap does a look up, and it finds varun, I might be wrong but my hypothesis regarding this behaviour is, it does find the user tom but it fails to create a token for the same maybe because of Dn mismatch. But if you go ahead and check in crx you will find the user created as Tom. But when it tries to authenticate using that name, Ldap rejects that and no Token is generated for the user.
        • 35. Re: LDAP set up with CQ 5.5
        shailesh08 Level 1
        I am not able to get the user in CQ from the LDAP server, I have configured the ldap_login.conf and repository.xml as required. Can anyone help me out in figuring out what wrong I am doing.
        Thanks & Regards,
        Shailesh
        • 36. Re: LDAP set up with CQ 5.5
        Sanjupr Level 1
        What is the error that you are getting in the error.logs? And what version of CQ are you using?
        • 37. Re: LDAP set up with CQ 5.5
        shailesh08 Level 1
        Hi Sanjupr,
        I am not getting any error in error log, but I am not able to login by the users I create using the LDAP.
        I will share the ldap_login.conf and respository.xml with you
        REPOSITORY.XML
        <?xml version="1.0" encoding="ISO-8859-1"?>
        <!-- $Id: repository-template.xml 78567 2011-06-16 04:27:03Z tripod $ -->
        <!-- Copyright (c) 1997-2008 Day Management AG                               -->
        <!-- Barfuesserplatz 6, 4001 Basel, Switzerland                              -->
        <!-- All Rights Reserved.                                                    -->
        <!-- This software is the confidential and proprietary information of        -->
        <!-- Day Management AG, ("Confidential Information"). You shall not          -->
        <!-- disclose such Confidential Information and shall use it only in         -->
        <!-- accordance with the terms of the license agreement you entered into     -->
        <!-- with Day.                                                               -->
        <Repository>
        </FileSystem>
        </FileSystem>
        security manager:
        </UserManager>
        </SecurityManager>
        access manager:
        <LoginModule class="com.day.crx.core.CRXLoginModule">
        <!-- param name="trust_credentials_attribute" value="d5b9167e95dad6e7d3b5d6fa8df48af8"/ -->
        </LoginModule>
        </Security>
        </FileSystem>
        </SearchIndex>
        <WorkspaceSecurity>
        <Import>
        </Import>
        </Workspace>
        persistence manager
        </FileSystem>
        implementations.
        </Versioning>
        </SearchIndex>
        <Cluster>
        </Cluster>
        <Modules>
        </Module>
        </Modules>
        </Repository>
        ldap_login.conf
        com.day.crx {
        host="10.242.135.12"
        port="10389"
        secure="true"
        userRoot="ou=users, ou=system"
        groupRoot="ou=groups, o=example"
        groupMembershipAttribute="uniquemember"
        autocreate="create"
        autocreate.group.description="profile/aboutMe"
        autocreate.group.cn="profile/givenName"
        cache.maxsize="100";
        I am able to get the connection from the LDAP server i checked that by creating a connection by using jxplorer VDS.I am using CQ5.5
        Thanks & Regards,
        Shailesh
        • 38. Re: LDAP set up with CQ 5.5
        Sanjupr Level 1
        Did you deliberately remove the below params?
        authDn=
        authPw=
        • 39. Re: LDAP set up with CQ 5.5
        shailesh08 Level 1
        No i copied the ldap_login.conf from somewhere and pasted at  C:\author\crx-quickstart\conf. Is that the ldap_login.conf is not correct and because of that I am facing the issue?
        Thanks & Regards,
        Shailesh
        1 2 Previous Next
