1 9 10 11 12 13 Previous Next 1,716 Replies Latest reply on Dec 18, 2012 11:37 AM by Victoria Bampton LR Queen Go to original post
      • 400. Re: Lightroom 4 is slow
        KKuja Level 1
        Lets hope the proper LR4.0 comes out soon, not the unofficial beta 2 that most people have paid for.
        I'm a little bit frightened because if I recall correctly these were almost the same words that someone said about Lr3 (and even Lr2).
        I'm sorry I don't have anything ontopic to say. I have to confess I haven't yet even tested Lr4, because long ago I made a decision I wait for at least .1 or .2 update before testing.
        • 401. Re: Lightroom 4 is slow
          Lee Jay Level 4
          hamish niven wrote:
          Thanks Tony
          so it went to the right place, to where bugs were posted and not to the user to user forums, where people were talking about it, where people where asking about it and where the Adobe feedback would have been really appreciated.
          Oh well.
          shame that it was not shared here.
          You're welcome.
          • 402. Re: Lightroom 4 is slow
            hamish niven Level 2
            Thanks Lee Jay
            appreciate you passing it on for everyone.
            Good job done for all
            Cheers
            • 403. Re: Lightroom 4 is slow
              KKuja, you are pretty right to be concerned.
              I'd consider downloading the LR4 on the 30 day and making a catalog with a new set of images. Its got superb processing.
              A LARGE issue is that +50 on exposure -25 highlight and +12 shadow is not the same for 2 photos, - kinda irritating as its very hard to set limits on where you would or would not place sliders.
              With LR3.x, I'd never go above
              • exposure +1
              • fill +25
              • black +20
              but with  LR4, its semi sort of relative, ie zoom to 100% to check.
              However, pushing the shadows - sorta little like fill to 50 adds so little noise.... amazing
              You may be lucky with your computer set up and have few issues like I also have.
              Import all your new images as DNG, and have an import preset that
              • sets the lens profile
              • sets any vignetting you want on the lens
              • sets the CA - Chromatic Aberration
              • sets the noise & pre sharpening
              • sets the tone curve (even if default NOW linear)
              • generates 100% previews
              This will help with the speed, even if importing a 16 Gb chip takes as long as boiling a kettle having laid the fire, started it, filled a 4 gallon kettle and waited for it to heat.
              Give it a go, the trial is only ±1Gb for PC / mac and even if you dont like it , you'd have the images in the LR4 catalog for when  ( I hope not if) Adobe get LR4.2 working nicely.
              I hear your reticence and sensible model to avoid X.0 and X.1 releases, will you upgrade straight to Photoshop CS6 though?
              Good luck, but do give it a try and I hope you are one of the lucky ones.
              hamish NIVEN Photography
              Message was edited by: hamish niven missed out and R
              • 404. Re: Lightroom 4 is slow
                gadgetgeek Level 1
                I'm replying to say that I'm experiencing much of the same slowdown that everyone else is experiencing. I've noticed a few things:
                1. If I pull up the Windows task manager to see my CPU usage, I can see that just moving the mouse over Lightroom causes my CPU to spike between 50% and 80%.  This could be causing a lot of the problems with the sliders, since I'm trying to use the mouse to adjust the sliders at the same time that Lightroom is trying to calculate the changes.
                2. I use a mouse/keyboard sharing program called "Mouse Without Borders" from Microsoft labs. It lets me use a single keyboard/mouse for two computers. With this program running my CPU spike is higher than without it running.
                3. Deleting my preferences file helped bring down the maximum CPU usage a bit.
                4. Opening a new catalog rather than my converted Lightroom 1 --> 2 --> 3 --> 4 catalog helped bring down the maximum CPU usage a bit. I am still hoping to be able to use my existing Lightroom catalog.
                5. I have an NVidia graphic card. I used the following NVidia control panel 3D settings, which helped bring down the maximum CPU usage a bit. These same settings made Lightroom 3 brushes work. Without these settings I could barely brush on any effect:
                     Anisotropic filtering: OFF
                     Antialiasing - Gamma correction: OFF
                     Antialiasing - Mode: Override any application setting
                     Antialiasing - Setting:  2x (2xMS)
                     Antialiasing - Transparency: Off
                     Buffer-flipping mode:     Use block transfer
                     CUDA - GPUs: All
                     Enable overlay: Off
                     Exported pixel types: Color indexed overlays
                     Maximum pre-rendered frames:  3
                     Multi-display/mixed-GPU acceleration: Compatibility performance mode
                     OpenGL Rendering GPU: Quadro FX 2700M
                     Power management mode: Prefer maximum performance
                     Threaded optimization: Auto
                     Triple buffering: Off
                     Texture filtering - Anisotropic filter optimize: Off
                     Texture filtering - Anisotropic sample op: Off
                     Texture filtering - Negative LOD bias: Allow
                     Vertical sync: Force on
                That said, I have returned some performance to my machine, but Lightroom is still highly unusable. Where I used to be able to process a few hundred photos in an hour, it now takes hours to process 30 or 40, just because the response in the program is so unbearably slow.
                My machine
                Lenovo W700DS, with the second laptop screen turned off.
                6GB RAM
                512GB SSD primary disk, Lightroom catalog, previews, and imported images on this disk.
                1TB secondary disk, unused by Lightroom.
                Intel Core2 Extreme processor (processor is a bit slower, which does affect my import/export times, but I render 1:1 previews on import and wait for the CPU to settle down before attempting to work)
                1920x1080 primary display
                Standard previews set to 2048.
                Windows 7 64-bit Professional edition
                I routinely work with full-resolution RAW images from my Canon 5D Mark II (very large).
                I hope this information helps shed some light on the problems. Can anyone else confirm that their CPU spikes just moving the mouse across the application? Not even pressing buttons or trying to do anything. Just move.
                Geoff
                • 405. Re: Lightroom 4 is slow
                  kwdaves Level 2
                  For those with slider problems, widening the right panel by clicking on its left edge and dragging it to the left may help a bit by lengthening the slider lines (whatever their proper names are).
                  For those who have sluggish behavior overall, for example taking 10+ secs to generate a preview in the Library module, deleting and then regenerating your standard previews may work wonders. Please, please. Someone be the guinea pig and try it.
                  • 406. Re: Lightroom 4 is slow
                    gadgetgeek Level 1
                    I deleted all my previews. It didn't make a difference for me. I still have
                    problems with CPU when moving the sliders and moving my mouse.
                    Sent from my iPhone
                    • 407. Re: Lightroom 4 is slow
                      Boggy4062 Level 1
                      There is no doubt - Lightroom 4 IS slow on any hardware configuration, much slower when comparing to Lightroom 3.x.  I doesn't matter how beefy the machine is (my is i7 with 8 CPUs and 16GB of RAM) which made the previous version fligh.  I descovered another bug: syncing of keywords does NOT work.  (and I did not test the rest of the fields). I believe that the product was rush to the market, and was not tested sufficiently. Not impressed with Adobe on this
                      • 408. Re: Lightroom 4 is slow
                        tfitz100 Level 1
                        While I haven't been *as* troubled by the slowness issues reported, I did see them a lot in the beta where the system would just slow down to a crawl when trying to make simple Develop Module adjustments.
                        That being said, I DO notice a delay when making some changes with some adjustment brushes. Up to a second or more sometimes. When I use the Tint brush and change the Tint on the slider, I have to wait about a second for the changes to propogate up into the image. This is not tolerable.
                        I currently have an i7-2600K with 8GB of memory, a SSD drive for the LR4 cache and a seperate drive for the actual catalog and RAW files being used, so it's certainly NOT a harware issue as so many have pointed out.
                        Adobe needs to investigate this problem now. This should be the TOP priority for the development team, nothing else. I've seen the list of issues they have on their developers forum and they are all issues that need to be solved, but not nearly as serious as this one. Adobe engineers should be working AROUND the CLOCK on this one, period. Everything else should be on the backburner until then.
                        Another issue is that Adobe has NOT SAID ANYTHING about this problem to this community. That, in and of itself, is a problem--almost worse than the actual problem. A simple report of their progress thus far would suffice. I'm a senior software engineer, and if my team let a problem like this go for so long without any acknowledgement whatsoever, our heads would be on a platter with our company.
                        • 409. Re: Lightroom 4 is slow
                          Blind Monk Level 1
                          I was successful importing keywords in a Text file -tab separated values (TSV) format -into LR4. No problems using a TSV file at all.
                          A decent explanation of how this type of file should look can be found below (just forget that they use MS Excel as the example software):
                          http://www.cs.tut.fi/~jkorpela/TSV.html
                          Export lightroom 3 keywords into Save the resulting file as a .txt file, and import.
                          • 410. Re: Lightroom 4 is slow
                            unique_jb Level 1
                            I think this is a general proble with adobe. Each new version is much slower than before. LR3 is much slower than LR2. Sounds like LR4 is going to be slower than LR3. Each new version of acrobat is much slower than the previous one. The same seems to be true for illustrator and photoshop. It seems that adobe for some reason is unable to make new versions of their software as fast (or ideally faster) than the previous one. This practice was acceptable in the 1990s (when single threaded performance was increasing exponentially) but since around 2003 this has no longer been the case, and it is critical to optimize single threaded performance and user interface latencies. Adobe for some reason doesn't consider this a priority I think.
                            • 411. Re: Lightroom 4 is slow
                              gadgetgeek Level 1
                              I posted a video on Youtube demonstrating the problem with CPU usage with Lightroom. Almost 100% CPU utilization on a dual-core processor when moving the Temp slider.
                              http://www.youtube.com/watch?v=lUZR0W2bpQk
                              Geoff
                              • 412. Re: Lightroom 4 is slow
                                Scooby007 Level 3
                                I get between 15% and 30% (i7 3.4)
                                • 413. Re: Lightroom 4 is slow
                                  Lee Jay Level 4
                                  So do I, but don't you want it to use 100%?  That's how it's going to be the fastest.  If there's a bug or limitation, it's that it's NOT using all the available processor power.
                                  • 414. Re: Lightroom 4 is slow
                                    joema3 Level 1
                                    I just installed LR4 and am appalled at how slow the Library module is when sequentially stepping through photos. At 1:2 zoom, it takes 3.3 seconds to change and render the next photo. This is on a overclocked quad-proc, hyperthreaded i7-860 @ 3.8 Ghz with 8GB RAM, catalog on a 10k rpm SATA drive and photos on a RAID 0 array. 64-bit Windows 7. GPU = nVidia GeForce GTX-275, 896MB, driver = 8.17.12.9053 (290.53).
                                    This is not a fringe, esoteric operation. You click once to magnify, then hit the right arrow key for next. In UI parlance it is a "common user path". How could Lightroom testers or program managers sign off on something like this?
                                    LR3 was much faster. Is there any rational explation for this, or installation/config error which explains it?
                                    I haven't had major problems with sliders in the Develop module, but LR4 in general feels sluggish and Library browsing is intolerably slow. I see the "Loading..." message so often it's essentially a logo.
                                    • 415. Re: Lightroom 4 is slow
                                      kwdaves Level 2
                                      The problem you describe is exactly what I saw after the LR2-LR3 upgrade. I fixed it by deleting and then regenerating my previews.
                                      Try this: delete the contents of your previews folder in the Lightroom folder, then in LR4 select "all photographs" and then click on Library/Previews/Render Standard-Sized Previews.
                                      This is a separate issue from the sluggish slider behavior others have reported.
                                      • 416. Re: Lightroom 4 is slow
                                        bob frost Level 3
                                        Have you created your previews? If you are allowing LR to create the
                                        previews as you step through the library, it will be slow. But if you
                                        created your standard previews on import, or just did it by selecting build
                                        previews from the library menu, it should be much faster.
                                        Bob Frost
                                        • 417. Re: Lightroom 4 is slow
                                          falschrum Level 1
                                          Same here. Rubbish performance on my system. LR3 was very fast but LR4 is just slow and often crashes without a reason.
                                          The overall system performance is also rubbish when i export pictures. In LR3 it was possible to run two export batches at one time without issues working in windows or surfin the web. With LR4 everything slows down. Even my cursor ist struggelin.
                                          Dell Precision T3500, Intel Xeon 2,4 GHz, 12 GB RAM, All Data on an OCZ Vertex 2.
                                          I´ll switch back to LR3 until Adobe will release a real final. LR4 looks for me just like a pay-beta.
                                          • 418. Re: Lightroom 4 is slow
                                            acresofgreen Level 4
                                            I was really looking forward to upgrading to LR 4 from LR 3, but this thread has convinced me to hold off for the time being or until I buy a new high-end computer, which won't be any time soon.
                                            • 419. Re: Lightroom 4 is slow
                                              Bob Gates Level 2
                                              I just upgraded and found that when using a slider nothing happened until I clicked to enlarge the image, the the change kicked in.  I mean I could wait forever, just nothing happened.  I found the advice to export to a new catalogue, remove all previews and clear the cache and so far everything seems to be working ok.  On a fast Windows machine.
                                              • 420. Re: Lightroom 4 is slow
                                                joema3 Level 1
                                                Bob Frost
                                                Thanks, selecting build standard previews during import, or afterward via Library>Previews>RenderStandard-Sized Previews reduced the "next photo" lag from about 3.3 sec to about 0.1 sec for standard size viewing. However -- if I click magnify once (default 1:2) then next photo takes about 3.3 sec.
                                                Building 1:1 previews m
