2 Replies Latest reply on Apr 12, 2012 4:42 AM by whwi999
    rtmfp application multicast h264 best results (video quality)
    whwi999 Level 1
      hello
      i test differnt settings for a application p2p multicast live stream
      firt i think there a two differnet settings for h264 stream
      1, use variable bitrate
      camera.setQuality(0,70)  0 bandwith so variable bitrate is used only works with rtmfp not with rtmp right ?
      in this mode the quality slider what is the diffenrt when i use 0 or 100 ? same?
      2,fix bitarte
        camera.setQuality(8192,100) set the max bitrate and best quality
      for p2pmulticast ithink mode 1 is the best varibale bitrate right?  the only problem is sometimes on motions the bitrate
      i stoo high so i set both bandwidgh and quality ?
      next i can not see any different if i use h264 profile MAIN or BASELINE or any change of the Profile Level
      is there any limitation on resolution or anything else
      best regards
