Show 4 replies
1. Re: History doesn't update, can't save changes
Rob Dillon Mar 27, 2012 4:46 AM (in response to Dr Missile)I've never seen that problem but... Try using saveAs... to save the file with a new name. Then you should be able to carry on with that new file.
2. Re: History doesn't update, can't save changes
Dr Missile Mar 27, 2012 10:41 AM (in response to Rob Dillon)Thanks for the reply, Rob. Unfortunately save as yields the same results. It treats the file as if it had never been changed, as if I had opened the file and simply saved it in another location.
3. Re: History doesn't update, can't save changes
*Q Mar 27, 2012 1:59 PM (in response to Dr Missile)Hi Dr Missile,
Which version of Flash do you have? Are you on Mac or Window? Did you use copy and paste frame in your file?
Quynh
Flash Pro, QE
4. Re: History doesn't update, can't save changes
Dr Missile Apr 17, 2012 10:21 AM (in response to *Q)Q - I'm on windows flash cs5 - and yes I am using copy and paste frames - After a few tests it seems that is what causes the behavior. Any suggestions?
