How to create a Date or time field that automatically saves current date or time?
Avatar
Level 2
hello,
i want to know that how to create a Date/Time field that automatically shows current Date/Time when .pdf form is opened.
also want to how to stop user to give input in Date/Time field
currently im putting a Date field but it is accepting user input.
hoping for quick response
Thanks in advance!
Avatar
Level 10
You can place the below code in the initialize event of the field to display the current date and time.
Set the language to FormCalc.
You can play around the formats to get the desired format of date and time.
if($.rawValue eq null or $.rawValue eq "") then
$.rawValue = Concat(Num2Date(Date(), "MM/DD/YYYY")," ", Num2Time(Time(), "h:MM:SS A"));
endif
You can not restrict the input area in Date time field instead you can validate the input while existing the field.
(OR) set the field to either readOnly or protected mode.
Srini
Avatar
Level 2
but the problem is when i edit half filled form
it keeps the date and time when first it was filled!
i want it to save the date/time when it was last time saved/edited.
Avatar
Level 10
Every time you save the form, assign the current date and time again to the same field.
That way it will retain the last saved date and time.
Srini
Avatar
Level 2
how to assign current date/time when the field is already filled with earlier date/time?
please let me know step by step instructions!
thanks
Avatar
Level 10
In your Save/ Submit button click event, place the following code to populate the date and time..
Use FormCalc as the language..
     DateTimeField1.rawValue = Concat(Num2Date(Date(), "MM/DD/YYYY")," ", Num2Time(Time(), "h:MM:SS A"));
     You can use rawValue property of the field to assign value at any time.
Srini
