1. Re: Adobe Media Encoder Fail - need help please
Mark Mapes Mar 15, 2012 2:55 PM (in response to nofxspam02)The export dimensions do not default to 1920x1080 because AME CS5.5 and prior versions do not have h.264 presets for QuickTime for the program ot default to, and the individual settings for that format do not have a "Same as Source" option. If you will be using a particular set of settings regularly, I recommend saving a custom preset. To do so, click the Save Preset button to the right of the Preset pulldown in the Export Settings dialog.
As for the failure to encode, we'll need to learn more about the particulars. Does the error log [File>Show Errors] have any useful information?
2. Re: Adobe Media Encoder Fail - need help please
nofxspam02 Mar 28, 2012 5:32 AM (in response to Mark Mapes)Sorry it took so long to get back to you I had to go out of town. Error message doesn't say anything to me... maybe to you. I'm not really sure what to set for "Field Type" so I just leave it at Lower. Not sure if I should set it to higher or progressive instead.
- Source File: F:\master_project\Fetterman\Premiere\Fetterman_Actos.prproj
- Output File: F:\master_project\Fetterman\Premiere\Fetterman-Actos.mov
- Preset Used: Custom
- Video: 1920x1080, 29.97 fps, Lower, Quality 100
- Audio: 48000 Hz, Stereo, 16 bit
- Bitrate: H.264
- Encoding Time: 00:00:00
03/15/2012 04:05:21 PM : Encoding Failed
3. Re: Adobe Media Encoder Fail - need help please
Mark Mapes Mar 29, 2012 10:29 AM (in response to nofxspam02)You're right. Not much useful information there. Our best bet is probably to try troubleshooting this over the phone. I'm sending you a private message...
