17 Replies Latest reply: Apr 23, 2012 5:10 PM by Chris Cox RSS
    Using the Free Transform/Warp Tool causes CS6 to stop working
    hjIndy
      Using the Free Transform/Warp Tool causes CS6 to stop working. Created an object with the brush on a new layer. Ctrl/T, Right Click and choose Warp. Moving one of the points causes the object to show up very distorted then I get a message that CS6 has stopped working.
        • 1. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
          Howard Pinsky CommunityMVP
          What is the exact error message you get? Does Photoshop crash? If it does, make sure to submit a crash report. http://forums.adobe.com/message/4209084#4209084
          • 2. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
            hjIndy Community Member
            I guess you would say it crashes - the message I get is: "Photoshop CS6 has stopped working" (Microsoft message). Then the CS6 screen closes.
            BTW - if I convert it to a smart object first it works fine.
            • 3. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
              Are all your video drivers up to date? Have you tried restarting Photoshop/your computer?
              If Photoshop completely crashes, make sure you're submitting a crash report, and try to reply with the Crash Data. http://blogs.adobe.com/crawlspace/2011/03/submitting-crash-reports.html
              • 4. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
                Yes, my drivers are all updated. I am using Windows Vista and CS4 now and don't have any problems.
                Where do I find the Crash Report for Photoshop CS6?  I did post the problem in the comments section at the bottom of the link you posted above.
                • 5. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
                  Adding my System Settings sinceI still have a problem with the Free Transform/Warp Tool.  Everything else I've tried seems to be working. Sometimes Camera Raw is a little slow but for the most part all looks good.
                  Adobe Photoshop Version: 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00) x64
                  Operating System: Windows Vista 64-bit
                  Version: 6.0 Service Pack 2
                  System architecture: Intel CPU Family:6, Model:7, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1
                  Physical processor count: 4
                  Processor speed: 2333 MHz
                  Built-in memory: 6142 MB
                  Free memory: 3446 MB
                  Memory available to Photoshop: 5387 MB
                  Memory used by Photoshop: 70 %
                  Image tile size: 128K
                  Image cache levels: 4
                  OpenGL Drawing: Enabled.
                  OpenGL Drawing Mode: Basic
                  OpenGL Allow Normal Mode: True.
                  OpenGL Allow Advanced Mode: True.
                  OpenGL Allow Old GPUs: Not Detected.
                  Video Card Vendor: ATI Technologies Inc.
                  Video Card Renderer: ATI Radeon HD 3450
                  Display: 1
                  Display Bounds:=  top: 0, left: 0, bottom: 768, right: 1280
                  Video Card Number: 1
                  Video Card: ATI Radeon HD 3450
                  OpenCL Unavailable
                  Driver Version: 7.01.01.798
                  Driver Date: 20081029060648.000000-000
                  Video Card Driver: atidxx32,atidxx64.dll,atiumdag,atiumdva,atiumd64.dll,atiumd6a.dat,atitmm64.dll
                  Video Mode: 1280 x 768 x 4294967296 colors
                  Video Card Caption: ATI Radeon HD 3450
                  Video Card Memory: 256 MB
                  Video Rect Texture Size: 8192
                  Serial number: Tryout Version
                  Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
                  Temporary file path: C:\Users\Helen\AppData\Local\Temp\
                  Photoshop scratch has async I/O enabled
                  Scratch volume(s):
                    Startup, 581.1G, 175.8G free
                  Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
                  Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
                  Additional Plug-ins folder: not set
                  Installed components:
                     A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                     ACE.dll   ACE 2012/01/18-15:07:40   66.492997   66.492997
                     adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
                     AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
                     AdobeOwl.dll   Adobe Owl 2012/02/09-16:00:02   4.0.93   66.496052
                     AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
                     AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1642
                     AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
                     AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
                     AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
                     adobe_caps.dll   Adobe CAPS   5,0,10,0
                     AGM.dll   AGM 2012/01/18-15:07:40   66.492997   66.492997
                     ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
                     aif_core.dll   AIF   3.0   62.490293
                     aif_ocl.dll   AIF   3.0   62.490293
                     aif_ogl.dll   AIF   3.0   62.490293
                     amtlib.dll   AMTLib (64 Bit)   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
                     ARE.dll   ARE 2012/01/18-15:07:40   66.492997   66.492997
                     AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
                     AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
                     Bib.dll   BIB 2012/01/18-15:07:40   66.492997   66.492997
                     BIBUtils.dll   BIBUtils 2012/01/18-15:07:40   66.492997   66.492997
                     boost_date_time.dll   DVA Product   6.0.0
                     boost_signals.dll   DVA Product   6.0.0
                     boost_system.dll   DVA Product   6.0.0
                     boost_threads.dll   DVA Product   6.0.0
                     cg.dll   NVIDIA Cg Runtime   3.0.00007
                     cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                     CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
                     CoolType.dll   CoolType 2012/01/18-15:07:40   66.492997   66.492997
                     data_flow.dll   AIF   3.0   62.490293
                     dvaaudiodevice.dll   DVA Product   6.0.0
                     dvacore.dll   DVA Product   6.0.0
                     dvamarshal.dll   DVA Product   6.0.0
                     dvamediatypes.dll   DVA Product   6.0.0
                     dvaplayer.dll   DVA Product   6.0.0
                     dvatransport.dll   DVA Product   6.0.0
                     dvaunittesting.dll   DVA Product   6.0.0
                     dynamiclink.dll   DVA Product   6.0.0
                     ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
                     FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
                     filter_graph.dll   AIF   3.0   62.490293
                     hydra_filters.dll   AIF   3.0   62.490293
                     icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                     icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                     image_compiler.dll   AIF   3.0   62.490293
                     image_flow.dll   AIF   3.0   62.490293
                     image_runtime.dll   AIF   3.0   62.490293
                     JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
                     libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                     libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
                     LogSession.dll   LogSession   2.1.2.1640
                     mediacoreif.dll   DVA Product   6.0.0
                     MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
                     msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                     msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                     msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                     msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                     msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                     msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                     msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                     msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                     pdfsettings.dll   Adobe PDFSettings   1.04
                     Photoshop.dll   Adobe Photoshop CS6   CS6
                     Plugin.dll   Adobe Photoshop CS6   CS6
                     PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (64 bit)   3.0.0.383
                     PSArt.dll   Adobe Photoshop CS6   CS6
                     PSViews.dll   Adobe Photoshop CS6   CS6
                     SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
                     ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
                     tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
                     tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
                     TfFontMgr.dll   FontMgr   9.3.0.113
                     TfKernel.dll   Kernel   9.3.0.113
                     TFKGEOM.dll   Kernel Geom   9.3.0.113
                     TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                     updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
                     WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
                     wu3d.dll   U3D Writer   9.3.0.113
                  Required plug-ins:
                     3D Studio 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Accented Edges 13.0
                     Adaptive Wide Angle 13.0
                     ADM 3.11x01
                     Angled Strokes 13.0
                     Average 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Bas Relief 13.0
                     BMP 13.0
                     Camera Raw 7.0
                     Chalk & Charcoal 13.0
                     Charcoal 13.0
                     Chrome 13.0
                     Cineon 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Clouds 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Collada 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Color Halftone 13.0
                     Colored Pencil 13.0
                     CompuServe GIF 13.0
                     Conté Crayon 13.0
                     Craquelure 13.0
                     Crop and Straighten Photos 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Crop and Straighten Photos Filter 13.0
                     Crosshatch 13.0
                     Crystallize 13.0
                     Cutout 13.0
                     Dark Strokes 13.0
                     De-Interlace 13.0
                     Dicom 13.0
                     Difference Clouds 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Diffuse Glow 13.0
                     Displace 13.0
                     Dry Brush 13.0
                     Eazel Acquire 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Embed Watermark 4.0
                     Entropy 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Extrude 13.0
                     FastCore Routines 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Fibers 13.0
                     Film Grain 13.0
                     Filter Gallery 13.0
                     Flash 3D 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Fresco 13.0
                     Glass 13.0
                     Glowing Edges 13.0
                     Google Earth 4 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Grain 13.0
                     Graphic Pen 13.0
                     Halftone Pattern 13.0
                     HDRMergeUI 13.0
                     IFF Format 13.0
                     Ink Outlines 13.0
                     JPEG 2000 13.0
                     Kurtosis 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Lens Blur 13.0
                     Lens Correction 13.0
                     Lens Flare 13.0
                     Liquify 13.0
                     Matlab Operation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Maximum 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Mean 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Measurement Core 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Median 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Mezzotint 13.0
                     Minimum 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     MMXCore Routines 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Mosaic Tiles 13.0
                     Multiprocessor Support 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Neon Glow 13.0
                     Note Paper 13.0
                     NTSC Colors 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Ocean Ripple 13.0
                     Oil Paint 13.0
                     OpenEXR 13.0
                     Paint Daubs 13.0
                     Palette Knife 13.0
                     Patchwork 13.0
                     Paths to Illustrator 13.0
                     PCX 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Photocopy 13.0
                     Photoshop 3D Engine 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Picture Package Filter 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Pinch 13.0
                     Pixar 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Plaster 13.0
                     Plastic Wrap 13.0
                     PNG 13.0
                     Pointillize 13.0
                     Polar Coordinates 13.0
                     Portable Bit Map 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Poster Edges 13.0
                     Radial Blur 13.0
                     Radiance 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Range 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Read Watermark 4.0
                     Reticulation 13.0
                     Ripple 13.0
                     Rough Pastels 13.0
                     Save for Web 13.0
                     ScriptingSupport 13.0
                     Shear 13.0
                     Skewness 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Smart Blur 13.0
                     Smudge Stick 13.0
                     Solarize 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Spatter 13.0
                     Spherize 13.0
                     Sponge 13.0
                     Sprayed Strokes 13.0
                     Stained Glass 13.0
                     Stamp 13.0
                     Standard Deviation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Sumi-e 13.0
                     Summation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Targa 13.0
                     Texturizer 13.0
                     Tiles 13.0
                     Torn Edges 13.0
                     Twirl 13.0
                     U3D 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Underpainting 13.0
                     Vanishing Point 13.0
                     Variance 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Variations 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Water Paper 13.0
                     Watercolor 13.0
                     Wave 13.0
                     Wavefront|OBJ 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     WIA Support 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     Wind 13.0
                     Wireless Bitmap 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
                     ZigZag 13.0
                  Optional and third party plug-ins: NONE
                  Plug-ins that failed to load: NONE
                  Flash:
                     Mini Bridge
                     Kuler
                  Installed TWAIN devices: NONE
                  • 6. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
                    Pattie F Employee Hosts
                    If you could cut and paste the text you see when it crashes, that would help also.
                    Hopefully we can figure out what's up here. I do see you are using vista, which is not officially supported for CS6.
                    Pattie
                    • 7. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
                      I was not aware that Windows Vista is not supported. I read that XP was supported so I thought Vista would be also.
                      • 8. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
                        FYI, Here are the system requirements:
                        What are the System Requirements for the Photoshop CS6 Beta?
                        Did the program end up crashing and giving a report or did it get stuck in the mode in the screen shot above?
                        Pattie
                        • 9. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
                          It got stuck - had to go to task manager.
                          I guess if CS6 is no supported on XP, I'll just have to forget CS6 for a while. I can't afford to upgrade everything at once.  Thanks for your help Pattie.
                          • 10. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
                            Do you have two systems? You say Vista and later XP and your system info provided says Vista. True Photoshop is not officially supported in Vista, although many are running on it. Photoshop CS6 is supported on XP, but you will not be able to use the GPU features such as 3d.
                            Did you go to the ATI website and carefully look for the latest date/version driver for this card and update it rather than letting windows look?
                            For a full list see here:
                            What features use the GPU and how do I troubleshoot GPU issues?
                            Pattie
                            • 11. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
                              adam ahmad
                              I'm using Windows7 Ultimate and i have the same problem so i guess it is not a compatibility problem
                              Using the "warp" tool causes the program to crash
                              PLz click on the followong pic so u can see the problem details
                              • 12. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
                                Adam-
                                Can you also paste in your system information from help>system info?  Do you have a supported video card and most recent driver?
                                This link shows supported cards and has additional troubleshooting suggestions. Give these a try and let us know what happens.
                                Pattie
                                Quick GPU Troubleshooting Steps
                                You can experience problems such as artifacts, errors, and crashes if there are incompatibilities between Photoshop and the display components that access the GPU.
                                If you experience crashes, incorrectly rendered windows or objects, redraw issues, or performance issues while running Photoshop, first determine whether OpenGL is causing the problem.Turn off OpenGL.
                                • Choose Edit > Preferences (Windows) or Photoshop > Preferences (Mac OS).
                                • In the Performance panel, uncheck Use Graphics Processor. Click OK.
                                • Restart Photoshop, and perform the same function.
                                If the problem recurs while OpenGL Drawing is disabled, OpenGL is not the cause. For additional troubleshooting, seeTroubleshoot system errors and freezes | Adobe software on Windows (cpsid_82252) or Troubleshoot system errors and freezes | Adobe software on Mac OS 10.x (cpsid_82414).If the problem resolves, proceed with the rest of the troubleshooting steps to fix OpenGL.
                                1. Make sure that you're using the latest update of Photoshop.
                                  • Updates fix bugs and issues.
                                2. Update the display driver.
                                  • Updated display drivers can fix many issues, such as crashing, incorrectly rendered objects, and performance problems. Determine what video card you have and go directly to the manufacturer's website (nVidia or ATI/AMD) and download the latest driver. (Note: Simply doing a Windows Update is does not guarantee you are using the latest driver. You must go directly to the nVideo or ATI/AMD websites to get the absolute latest driver.) After you update your driver, turn on Use Graphics Processor in Photoshop preferences.
                                3. Reset preferences.
                                  • Resetting preferences returns OpenGL settings to their default status. Reset Photoshop preferences by pressing and holding Shift+Ctrl+Alt (Windows) or Shift+Option+Command (Mac OS) immediately after you start Photoshop.
                                  • Click Yes when asked if you want to delete the Adobe Photoshop Settings File.
                                  • Retry the function that caused the problem.
                                4. Change the OpenGL mode to Basic.
                                  • Setting the OpenGL mode to Basic uses the least amount of GPU memory and the most basic GPU feature set.
                                  • Close all documents.
                                  • In the Performance panel, click the GPU Settings Advanced Settings button.
                                  • Choose Mode > Basic
                                  • Restart Photoshop.
                                    If this solution resolves the problem, switch to Normal mode. See if the issue recurs. If the issue recurs, return to Basic mode.
                                  • Note:  If you’re changing GPU preferences to troubleshoot a problem, re-launch Photoshop after each change.
                                5. If you are using more than one video adapter, remove the additional cards.
                                  • Multiple video adapters can cause problems with GPU accelerated or enabled features in Photoshop. It's best to connect two (or more) monitors into one video adapter. If you have to use more than one video adapter, make sure that they are the same make and model. Otherwise, crashes and other problems can occur in Photoshop.
                                  • Note: Using two video adapters does not enhance Photoshop's performance.
                                6. Check your Cache Levels setting.
                                  • If you've set your Cache Levels to 1 in Photoshop preferences, you can experience performance issues with GPU features. Reset Cache Levels to the default setting, which is 4.
                                  • Choose Edit > Preferences > Performance (Windows) or Photoshop > Preferences (Mac OS)
                                  • In the Performance panel, choose Cache Levels > 4.
                                • 13. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
                                  Patti,
                                  I just tried to respond on line but for some reason I couldn't.
                                  Anyway, I updated my video card driver today and now I'm not getting the error.
                                  I tried some of the other features that use the GPU and they all appear to work.
                                  Thank you so much for your help.
                                  Helen
                                  • 14. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
                                    Adam,
                                    I just updated my video card driver and the problem went away.  You might want to try that.
                                    Helen
                                    • 15. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
                                      Helen-
                                      Excellent! Glad to hear it is all up and working. How about you, Adam?
                                      Pattie
                                      • 16. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
                                        adam ahmad Community Member
                                        Patti,
                                        I think I can't thank u enough .. the "OpenGL" was the cause, i turned it off and now it works
                                        I owe you one
                                        And Helen, thank you for trying to help
                                        I really appreciate it
                                        Adam
                                        • 17. Re: Using the Free Transform/Warp Tool causes CS6 to stop working
                                          Chris Cox Adobe Employee
                                          Adam - OpenGL drawing is not the cause.  Bugs in your video driver are the cause, and by turning off the OpenGL features you are avoiding the bugs in the video card driver.  But to use all the features, you need to update your video card driver to fix the bugs in the driver.
