10 Replies Latest reply: Apr 9, 2012 9:00 AM by na mara RSS
    changing a bicycle sprocket size while maintaining shape,
    na mara
      this is a stroke of a path of a bicycle sprocket with 32 teeth,
      after removing 4 teeth from 4 different parts(there is a pair of 2 different type of teeth after every 6 standard teeth,i want to remove 1 of these 6 in each of the 4 parts)
      I do not know how to join up the open ends of the path
      to maintain the circular shape to produce a  28 tooth sprocket,
      the teeth size are not to change just the circle,
      thanks if anyone can help,
        • 1. Re: changing a bicycle sprocket size while maintaining shape,
          Manish-Sharma Adobe Employee
          Select complete bicycle sprocket
          Go to object>path>join
          • 2. Re: changing a bicycle sprocket size while maintaining shape,
            rcraighead MVP
            You might make your life simpler by creating a pattern brush for the sprockets. Here's one approach. I'm sure there are numerous ways to do it.
            Adjust the "Scale" setting, in the brush dialog, to get the right number of sprockets.
            • 3. Re: changing a bicycle sprocket size while maintaining shape,
              Jacob Bugge MVP
              na mara,
              The shape/shapes of the individual teeth actually has/have to be changed to go from 32 to 28.
              You may maintain the concave rounded part forming the transition from tooth to tooth and their faces, but the transition/angle between the face and the top land (the tip) changes with the size, as does the shape of the top land itself, following the outer bounding circle which has a different size (28/32 of the original one). The inner bounding circle corresponding to the bottoms of the roundings also changes, of course.
              This means that you will have to create everything anew.
              You may do it in different ways.
              Using a Pattern Brush is one, but then you will have to know the angle/transition, so you will need the bounding circle.
              An Art Brush will adapt, with a certain change of shape when applied.
              In either case you will need to use a path that is a circle midway between the outer and inner bounding circles, and to make the two different teeth the right height (corresponding to (half) the difference between the bounding circles.
              A third way is to:
              1) Draw the bounding circles,
              2) Draw/redraw/copy one normal concave rounded shape vertically above the centre so its bottom touches the inner bounding circel and so that it is extended to cross the outer bounding circle (without the rounded transition to be made later),
              3) Rotate 2) round the centre by 360/28 degrees (you may rotate a copy),
              4) Repeat 2) for the different rounding (you may edit the original normal one if you rotate a copy in 3),
              5) Rotate copies of 3) round the centre by 360/28 degrees 5 times, now you have the basic shapes of the 6 normal roundings and one different one,
              6) Rotate copies of the whole set of 7 roundings by 90 degrees 3 times to have the full circle,
              7) Hide or delete the inner bounding circle, select everything, and Pathfinder>Minus Front, now you have all roundings/teeth, only without the rounded transitions,
              8) Use the free Round Any Corner script, either on all transitions at the same time or first on the normal transitions and then on the special ones (to get different roundings).
              The Round Any Corner script with instructions is available here:
              http://park12.wakwak.com/~shp/lc/et/en_aics_script.html
              • 4. Re: changing a bicycle sprocket size while maintaining shape,
                Wade_Zimmerman Community Member
                This is the way i would do it admittedly irt requires working this the various setting until you get it right bu you can after some experience update the art fairly easy using the Transform effect.
                • 5. Re: changing a bicycle sprocket size while maintaining shape,
                  rcraighead MVP
                  Wade, how would you make it a filled shape, using this method?
                  • 6. Re: changing a bicycle sprocket size while maintaining shape,
                    JETalmage Community Member
                    Object>Expand Appearance
                    Ungroup
                    Join
                    See the other thread (about "expanding a circle") to avoid fiddling around with settings.
                    JET
                    • 7. Re: changing a bicycle sprocket size while maintaining shape,
                      Jacob Bugge MVP
                      rcraighead,
                      And be aware that whenever you change the size of the defining circle, the angle between adjacent (later to be sub)paths will change, in other words you will have (possibly insignificant, depending on your requirements/inclination) small disruptions of the shape (change of direction where they meet or top lands that are straight (plane) instead of circular (cylindrical), unless you do it (corresponding to) the way described in post #3, where the paths cross the outer bounding circle and cut themselves out of it (with subsequent rounding, if needed).
                      • 8. Re: changing a bicycle sprocket size while maintaining shape,
                        Using Transform Effect, there is no defining circle path to change the size of. The diameter of the sprocket is automatically determined by the widths and number of teeth, as it should be. Draw the original path symmetrically; from center of top land to center of the next top land. That will cause the angle change to occur at the center of each tooth point, rather than at the side of a tooth and the next bowl. In my experience, the tops of motorcycle sprockets do not describe a large circle; the teeth usually have tapered facets at their tops, so that there is not a sharp edge to encounter the chain rollers. But if you want that, it's easy to do after expanding the effect and joining: Just draw a large circle and use the intersect Pathfinder.
                        Actually, the arc of the bowls on an actual sprocket may differ from 180° depending on diameter, too. But that's probably needless hair-splitting for illustration purposes.
                        JET
                        • 9. Re: changing a bicycle sprocket size while maintaining shape,
                          Expan the Appearance and Command or Control J and fill it?
                          • 10. Re: changing a bicycle sprocket size while maintaining shape,
                            na mara Community Member
                            Wade, in your post-No.4,how do you create a bounding box over part of path as in image,one will not create from making a rectangle,nor can i shrink the bounding box over entire image without effecting entire image,tnx,
                            Date: Mon, 2 Apr 2012 07:13:47 -0600
                            To: grahammcnamara@hotmail.com
                            Subject: changing a bicycle sprocket size while maintaining shape,
                                created by Wade_Zimmerman in Illustrator - View the full discussion
                            Expan the Appearance and Command or Control J and fill it?  http://forums.adobe.com/servlet/JiveServlet/downloadImage/2-4307578-181024/450-496/ScreenShot2012-04-02at9.08.16+AM.png
                                 Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/4307578#4307578
                                 To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/4307578#4307578. In the Actions box on the right, click the Stop Email Notifications link.
                                 Start a new discussion in Illustrator by email or at Adobe Forums
                              For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
