9 Replies Latest reply on Mar 29, 2012 7:49 AM by Natalie Butler
    Multiple timeout objects (object declaration problem?)
    Natalie Butler
      So what I'm trying to do here is create 4 separate timeOut objects that are each applied to 4 different sprites. Each has a variable for the duration that is set to 0 by default so that it does not even check to call the timeout handlers. When the user clicks on a sprite, the variable associated with that sprite's related timer duration is set to 5 seconds. When that timer runs out, the handler that is called stops the timer, resets the duration variable of the timer to 0, and changes that particular sprite's image.
      Essentially, I want it so that the user can click each individual sprite and have each sprite change its image 5 seconds after that specific sprite was clicked.
      While my code is probably repetitive and clunky, it seems like it should work to me - but I am no expert by far. It compiles fine, but when it runs, I get this message:
      Script error : Object expected
      timer1 = timeOut().new("timer1", timeoutDuration1, #timeOut1, me)
      What exactly did I do wrong? I'm assuming it's some kind of simple syntax error but I can't figure out what. I've tried changing the name of the timer objects, setting them as global properties, etc., all I can think to do, but I can't figure it out. Or am I doing it entirely wrong altogether? Thank you SO much to anyone who can provide help.
      My code is below.
      property spriteNum, pMySpriteRef
      property timeOut1, timeOut2, timeOut3, timeOut4
      on beginSprite me
        timeoutDuration1 = 0
        timeoutDuration2 = 0
        timeoutDuration3 = 0
        timeoutDuration4 = 0
        timer2 = timeOut().new("timer2", timeoutDuration2, #timeOut2, me)
        timer3 = timeOut().new("timer3", timeoutDuration3, #timeOut3, me)
        timer4 = timeOut().new("timer4", timeoutDuration4, #timeOut4, me)
      end
      on enterFrame me
        if (_mouse.clickOn = me.spriteNum) then
          pMySpriteRef = sprite(me.spriteNum)
          if pMySpriteRef = 1 then
            timeoutDuration1 = 5000
          else if pMySpriteRef = 2 then
            timeoutDuration2 = 5000
          else if pMySpriteRef = 3 then
            timeoutDuration3 = 5000
          else if pMySpriteRef = 4 then
            timeoutDuration4 = 5000
          end if
        end if
      end
      on timeOut1 me
        timeOut("timer1").forget()
        sprite(1).member = "Jellyfish_new_1"
      end
      on timeOut2 me
        timeOut("timer2").forget()
        sprite(2).member = "Jellyfish_new_1"
      end
      on timeOut3 me
        timeOut("timer3").forget()
        sprite(3).member = "Jellyfish_new_1"
      end
      on timeOut4 me
        timeOut("timer4").forget()
        sprite(4).member = "Jellyfish_new_1"
      end
