5 Replies Latest reply on Apr 11, 2012 12:15 AM by AmbooS
    Acrobat X Pro crashes when using commenting tools after saving as Reader Extended pdf
      Working in large PDF with editor who uses Reader X. After I save pdf as Reader Ext PDF-Enable Commenting & Measuring and use Insert text at cursor tool, Replace text tool, etc, the program crashes often. Usually no recovered pdf is available. I do not have Reader installed. I've tried resetting default PDF handling in Preference\General, but it doesn't seem to make a difference.
      In fact, I also sometime crash using Commenting tools in a PDF just shared and edited between Acrobat X Pro users.
      (Win 7 64-bit)
      The error is always in Annots.api
      Faulting Application Path:              C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrobat.exe
      Problem signature
      Problem Event Name:                      APPCRASH
      Application Name:                           Acrobat.exe
      Application Version:
      Application Timestamp:                   4f02e85c
      Fault Module Name:                        Annots.api
      Fault Module Version:
      Fault Module Timestamp:                4f02f5dd
      Exception Code:                                c0000005
      Exception Offset:                              000f5d33
      OS Version:                                        6.1.7601.
      Locale ID:                                           1033
      Additional Information 1:                0a9e
      Additional Information 2:                0a9e372d3b4ad19135b953a78882e789
      Additional Information 3:                0a9e
      Additional Information 4:                0a9e372d3b4ad19135b953a78882e789
      Extra information about the problem
      Bucket ID:                                          2779602682
