I entered server url to connect to Robohelp Server using RoboSource Control 3. I also mark that it should connect to this server every time the project is started. It is the wrong URL and it does not error out or abend. I am unable to go in and unmark the automatic connect because the first thing it does it try to connect. How or where can I stop it from trying to connect to this url address?
System Attributes
Robohelp HTML v8.02
RoboSource Control 3.1
Robohelp Server V8.0
Webhelp Pro 5.50 (7.00.145)
I use the following method for TFS when I want to temporarily disconnect a project from source control. I assume it will work the same with RoboSource Control.
The projet is now disconnected. By not removing it from RH, you can disconnect a project while the files in source control are retained.
Greet,
Willam
First of all you can not connect to RoboHelp Server from RoboSourceControl. RoboHelp Server is a hosting application that is completely separate from RoboHelp which can connect with RoboSourceControl.
OK. Now that I've made that clear, I still do not understand your problem. Can you post a screenshot of what you are seeing? Is it that all your RoboHelp projects are automatically being added to RoboSourceControl?
Rich21
I posted an example.
Whoops, that didn't come through - try again.
PS - I would kill your auto-signature that includes your e-mail unless you like spambots harvesting it ;>)
Apparently my post did not take. How can I post a screen print.
In the web interface, use the camera icon to upload an image
See this...
The automatic open is marked and the server address is incorrect. It tries to connect but never does and it never error out.
what about setting up a new connection (called something else) with the correct info, then delete the "paid" connection that's wrong & tell it to use the new name?
I can't get to the dialog that does that because it's try to connect.
Isn't that the screen you just posted?
Yes.
Will your previous 6 steps solution resolve the problem I am having?
No idea - I don't use source control (plus I didn't suggest them - Willam did ). But it seems to me that you should be able to just start up RH clean (no projects) and adjust which database to connect to. That seems to be the screen that you show in your post, maybe I'm completely wrong...
