4 Replies Latest reply on Apr 5, 2012 12:45 AM by Mohanvalli
    Un used swatches in Illustrator
    Mohanvalli Newcomer
      While working in Illustrator faced issue of morethan 30 unused swatches.
      Unused swatches are there in Illustrator file, it is only showing in separation preview not in Swatches.
        • 1. Re: Un used swatches in Illustrator
          Jeffcd19 Helper
          Hey MOhan,
          I have come across this many times in my shop. It's cause is a bit complex so I'll just tell you the work around. You have to get rid of these Deleted Global Colours in your file. Do this by creating a new document same size as the corrupt document. You have to copy and paste your art into the new file but NOT by just copying and pasting. You instead have to select all the artwork from the offending file and drag into your new document. This will bring in all the deleted global colours but you can then choose delete unused colours from the swatch menu fly-out. I have an action that does this with one keystroke so it can be pretty quick if you have a lot of files like this.
          Just deleting them in the original file is not good enough, they will come back. Leaving them in your file causes severe slow downs and frequent crashes. It took me a while to figure this all out but trust me it works.
          Good luck mate,
          Jeff
          • 2. Re: Un used swatches in Illustrator
            Mohanvalli Newcomer
            Thanks Jeff.
            I use to open the file in Cs5 and save it to Cs4 to fix it. It works fine.
            Is it possible to share the action which you using.
            Best Regards
            MOhan
            • 3. Re: Un used swatches in Illustrator
              Jeffcd19 Helper
              All you have to do is record your keystrokes in the actions pallett and save them. If you want I can email you the action that I use to delete unwanted colours but I would need your email address for that.
              jeff
              1 person found this helpful
              • 4. Re: Un used swatches in Illustrator
                Mohanvalli Newcomer
                Thanks in advance Jeff.
                My email ID: mohan.raj@alia.in
                I work in Mac.
                MOhan
