Form Structure Sorting
Participant ,
Oct 12, 2006 Oct 12, 2006
How can I sort the form structure on output? Here is my script.
<table>
<tr>
<th>Variable Name</th>
<th>Value</th>
</tr>
<!--- loop over the Form structure and output all
of the variable names and their associated
values --->
<cfloop collection="#Form#" item="VarName">
<cfoutput>
<tr>
<td>#VarName#</td>
<td>#Form[VarName]#</td>
</tr>
</cfoutput>
</cfloop>
Advanced techniques
733
You would sort the output by the query....
<cfquery name="myquery" datasourse="application.ds">
Select ID, whatever, fields, you, need
From tblMytable
Order by Mysortingcrit
</cfquery>
<cfloop query="myquery">
<---this is where you would put your table structure and variables--->
</cfloop>
he's not sorting a query. he's sorting a form structure.
Participant ,
I was thinking that maybe, I can dump the form elements into a query and then sort them that way and just out put from the query. I am little stuck on the code for this. Any help would be appreciated.
<cfset form.harry = "hello">
<cfset form.fred = "goodbye">
<cfset count = 1>
<cfset myQuery = QueryNew("#VarName#,")>
<cfset temp = QuerySetCell(myQuery, "#VarName#", "#Form[VarName]#", #Count#)>
<cfset count = count + 1>
</cfloop>
<cfdump var="#myQuery#">
<cfoutput>
<cfloop list="#listSort(struckKeyList(form))# index="key">
form.#key# = #form[key]#<br>
</cfloop>
</cfoutput>
Correct whatever syntax errors I made typing that and you should have
what you want. As long as you just want ascending or descending
alphabetical order.
Participant ,
Ian, I tried to get your code to work. I modified it to look like this.
<cfloop list="#listSort(struckKeyList(form,","), "ASC")#" index="i">
<cfoutput>
form.#i# = #form #<br>
</cfoutput>
</cfloop>
However, I get this error message.
Variable STRUCKKEYLIST is undefined.
As I said debug my typing StructKeyList() NOT StruckKeyList()
Participant ,
Ian, this is what I got with your code.
Parameter validation error for function LISTSORT.
The function takes 2 to 4 parameters.
This is what I am running from your code.
<cfoutput>
<cfloop list="#listSort(struckKeyList(form))#" index="key">
</cfloop>
</cfoutput>
Code tested and ran.
<cfoutput>
<cfloop list="#listSort(structKeyList(form),'textNoCase')#" index="key">
form.#key# = #form[key]#<br/>
</cfloop>
</cfoutput>
My previous examples where just to give you the idea of what functions
and logic you could use. I don't use these functions everyday so I do
not know all required parameters without looking at the documentation.
Documentation
