1. Re: InDesign crashes at startup
John Hawkinson Mar 29, 2012 11:13 PM (in response to BenAllroundTeam)Did you trash your preferences?
Trash, Replace, Reset, or Restore the application Preferences: http://forums.adobe.com/thread/526990
2. Re: InDesign crashes at startup
BenAllroundTeam Mar 30, 2012 12:18 AM (in response to John Hawkinson)Hi John and thanks for the reply. Yes, actually i did trash the preferences, but it didnt help.
3. Re: InDesign crashes at startup
John Hawkinson Mar 30, 2012 12:23 AM (in response to BenAllroundTeam)Did you install Java?
Try a different user account?
If that doesn't fix it, I'd reinstall InDesign. OS upgrades can be troublesome, and an ID uninstall/reinstall doesn't take that long anyhow.
4. Re: InDesign crashes at startup
BenAllroundTeam Mar 30, 2012 12:38 AM (in response to John Hawkinson)Hi John,
Java is up and running. Uninstalled/reinstalled ID twice. Other user accounts work without any problems. It s really strange...
5. Re: InDesign crashes at startup
Peter Spier Mar 30, 2012 4:54 AM (in response to BenAllroundTeam)Uninstall again, then run the clean tool: Resolve installation problems with CS5 Cleaner Tool and reinstall, or you can wait for John to come back with a list of files/folders to try removing from your user library. Something in there is corrupt.
6. Re: InDesign crashes at startup
John Hawkinson Mar 30, 2012 5:01 AM (in response to Peter Spier)Wait, wait. I think we don't think the cleaner tool is going to help. As far as I'm aware, it does not remove user-specific state, so if the problem goes with a user account, the cleaner tool won't help...gotta find that list, back in a bit...
7. Re: InDesign crashes at startup
John Hawkinson Mar 30, 2012 5:06 AM (in response to BenAllroundTeam)Java is up and running. Uninstalled/reinstalled ID twice. Other user accounts work without any problems. It s really strange...
OK, the information that other user accounts work means it really cannot be an installation problem. So reinstalling won't help and Java isn't related to the problem., etc., etc.
As Peter suggested, I have a list of folders/files to remove from your user Library directory. Note that under Lion, you must hold down Option to see the Library folder in the Go menu of the Finder. It is hidden from normal navigation.
Here's my list:
~/Library/Application Support/Adobe/Adobe InDesign CS5.5
~/Library/Caches/Adobe InDesign
~/Library/Caches/com.adobe.InDesign
~/Library/Preferences/Adobe InDesign
~/Library/Preferences/com.adobe.InDesign.plist
~/Library/Preferences/com.adobe.InDesign.plist.lockfile
~/Library/Saved Application State/com.adobe.InDesign.savedStateSo try quitting InDesign, getting rid of all of those (you can move them to a temp. folder on the Desktop instead of deleting them just to be safe!), and then restarting.
8. Re: InDesign crashes at startup
Peter Spier Mar 30, 2012 5:14 AM (in response to John Hawkinson)John Hawkinson wrote:
OK, I've never had to run the tool on any of my systems, and I'm on Windows, so I don't know for sure, but I've always assumed it would remove all traces, including user profile or library folders (the uninstallers will do that, if you tell them to). I've got a test system to break down in the next month or two, though, so I'll try to remember to run the tool and see what happens before I restore my clean image.
9. Re: InDesign crashes at startup
BenAllroundTeam Mar 30, 2012 7:54 AM (in response to John Hawkinson)Hi John,
thanks a lot for your help, deleting the files worked. ID is running smooth again, even without reinstalling.
10. Re: InDesign crashes at startup
BenAllroundTeam Mar 30, 2012 7:57 AM (in response to Peter Spier)Hi Peter,
thanks for the help, Johns tip worked out quite well, no crashes anymore.
11. Re: InDesign crashes at startup
Peter Spier Mar 30, 2012 4:14 PM (in response to BenAllroundTeam)That's great.
12. Re: InDesign crashes at startup
BenAllroundTeam Apr 5, 2012 6:00 AM (in response to Peter Spier)Hi Peter,
believe it or not but right now i've got the same Problem with Photoshop. If i open a psd file, photoshop crashes almost instantly.
Any suggestions, what it could be this time?
I will post the crash report in a minute.
Thanks a lot
Ben
13. Re: InDesign crashes at startup
Peter Spier Apr 5, 2012 6:34 AM (in response to BenAllroundTeam)Do you run Suitcase?
Have you tried trashing the Photoshop prefs? I think there's just one file for them.
14. Re: InDesign crashes at startup
BenAllroundTeam Apr 5, 2012 6:57 AM (in response to Peter Spier)Hi Peter,
just trashed the preferences, it didnt help.
Here is the crash report:
Thanks for the help!
15. Re: InDesign crashes at startup
BenAllroundTeam Apr 5, 2012 7:11 AM (in response to Peter Spier)almost forgot, i dont use suitcase...
16. Re: InDesign crashes at startup
Peter Spier Apr 5, 2012 7:27 AM (in response to BenAllroundTeam)John is the main man for this, but it looks to me like the problem is in Font Xplorer, so most likely either there is a bad font on the system, or there's an incompatibility. You might want to see if there are updates, or remove the auto-activation plugins.
17. Re: InDesign crashes at startup
BenAllroundTeam Apr 5, 2012 7:29 AM (in response to Peter Spier)Hi Peter,
good idea, i thought about a font problem,too. Where do i remove the plug ins?
18. Re: InDesign crashes at startup
Peter Spier Apr 5, 2012 7:38 AM (in response to BenAllroundTeam)There should be plugins folders for each application. I'm on Windows, so I can't tell you where, exactly, to look on your Mac.
19. Re: InDesign crashes at startup
BenAllroundTeam Apr 5, 2012 8:27 AM (in response to Peter Spier)Hi Peter,
i just updated fontexplorer to the latest free version 1.2.3 and it seems to work now.
Thanks for the fast reply, very much appreciated!
Ben
20. Re: InDesign crashes at startup
John Hawkinson Apr 5, 2012 11:48 AM (in response to Peter Spier)Peter Spier wrote:
Looks like it got straightened out, but yes, the crash was clearly in Font Xplorer.
At the end of the crash report it tells you where the files are:
0x111bb3000 - 0x11249aff7 +FontExplorer X Pro for Photoshop CS5 (3.2.1 - ???) <C8383148-9AB8-2C07-43C6-3B19E7D0E0B6> /Applications/Adobe Photoshop CS5.1/*/FontExplorer X for Photoshop CS5.plugin/Contents/MacOS/FontExplorer X Pro for Photoshop CS5
So in this case: /Applications/Adobe Photoshop CS5.1/Plug-Ins/FontExplorer X for Photoshop CS5.plugin
21. Re: InDesign crashes at startup
nishi1234 Oct 3, 2014 1:01 PM (in response to John Hawkinson)InDesign crashing 5 seconds after the start up, tried deleting the files as mentioned in the earlier thread...
Help!
22. Re: InDesign crashes at startup
Peter Spier Oct 3, 2014 2:30 PM (in response to nishi1234)Version? OS? Do you have a crash report?
24. Re: InDesign crashes at startup
BobLevine Oct 4, 2014 7:13 AM (in response to nishi1234)First things first, patch InDesign to 8.0.2
25. Re: InDesign crashes at startup
nishi1234 Oct 4, 2014 1:34 PM (in response to BobLevine)still not working!!
26. Re: InDesign crashes at startup
Peter Spier Oct 4, 2014 1:58 PM (in response to nishi1234)Post a new crash report...
28. Re: InDesign crashes at startup
Peter Spier Oct 5, 2014 2:10 AM (in response to nishi1234)If Help > Updates.. does not work, download and install the path manually from Adobe - InDesign : For Macintosh : Adobe InDesign CS6 8.0.2 update - All Languages
29. Re: InDesign crashes at startup
oliviaalice111 Nov 6, 2014 2:20 AM (in response to BenAllroundTeam)thanks so much this worked for me! thank you everyone.
30. Re: InDesign crashes at startup
h8w8ing Jun 5, 2015 10:31 AM (in response to BenAllroundTeam)Thanks, this worked GREAT!
31. Re: InDesign crashes at startup
monkeyboog Nov 4, 2015 12:45 PM (in response to Peter Spier)CS5 InDesign crashing on new MacBook Pro running El Capitan. I've tried running on a new admin account on the same system and it works. When I follow the steps to trash perfs, and copy over from working account, it still crashes. Here is the error log. Any help is greatly appreciated!
32. Re: InDesign crashes at startup
BobLevine Nov 4, 2015 1:04 PM (in response to monkeyboog)1 person found this helpfulCS5 is not and never will be supported under El Capitan.
That said, the one thing that seems to help is turning off auto hide menu bars in the general preferences.
33. Re: InDesign crashes at startup
monkeyboog Nov 5, 2015 6:55 AM (in response to BobLevine)Illustrator and Photoshop for CS5 work just fine under my account. InDesign will work under a new admin account. All on El Capitan.
34. Re: InDesign crashes at startup
jessiem81703242 Nov 5, 2015 9:35 AM (in response to BobLevine)1 person found this helpfulRe: InDesign crashes at startup
This helped for me thanks!
35. Re: InDesign crashes at startup
jonnaemilia Nov 7, 2015 11:22 PM (in response to jessiem81703242)I just had the same problem with Creative Cloud InDesign – it just wouldn't open. It kept on crashing. But this "turning off auto hide menu bars" really did the trick for me too. Thank you for the tip!
36. Re: InDesign crashes at startup
tonygamino Nov 20, 2015 2:29 PM (in response to jonnaemilia)why does that work? It's so random??? Happy that my InDesign works now but geez, come on Adobe!
37. Re: InDesign crashes at startup
BobLevine Nov 20, 2015 3:12 PM (in response to tonygamino)What makes you think it's Adobe's problem? It might well be, but that is a new O/S setting and you'd think Apple would have tested it against high end applications.
38. Re: InDesign crashes at startup
nalf Dec 1, 2015 10:23 AM (in response to jessiem81703242)1 person found this helpfulWas sitting here for a good 2 hours trying to figure out why InDesign CS5 suddenly crashed upon launching on El Capitan. Worked previously so I was quite confused.
Turned off the 'auto-hide menu bars' option in system preferences and bam, it works again!
39. Re: InDesign crashes at startup
A-maya Aug 14, 2016 7:31 PM (in response to BobLevine)That seriously helped! I'm astonished by this, for I have tried everything to make it work again (InDesign kept shutting down, tried new admin, that worked for only a week).
So just one simple change in preferences and it worked again. Thank you so much!
