Hi, i'm trying to install activex for 64 bits for flash playaer 11.1.102.55 msi program, but when its installing an 2753 installAX64.exe error ocurs, i dont know how to fix it, any help?
Can you post the content of the FlashInstall.log file in C:\Windows\system32\Macromed\Flash ?
what do you mean with that, english its not my native language. But it supposed that i install everithing, but can install the install activex for 64 bits for flash playaer 11.1.102.55 msi program. the other plugins i could
Two questions:
For additional information see also http://www.adobe.com/devnet/flashplayer/articles/flash_player_admin_guide.html
Can you also try to run the uninstaller first? Download it from http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
Of course you will need to reinstall the ActiveX after running the uninstaller.
im trying to install an old version becouse im using flash builder, and need an older version, i use the unninstaler, but when im trying to install the package with windows says error 2753 activeax.exe is not marked for installation
Can you try to use the EXE installer instead?
Try downloading from here: http://helpx.adobe.com/flash-player/kb/archived-flash-player-versions.html
The error message you're seeing is also mentioned here: http://msdn.microsoft.com/en-us/library/windows/desktop/aa372835%28v=vs.85%29.aspx
