1. Re: Space between paragraphes
jmlevy Mar 31, 2012 10:00 AM (in response to on5lb)Instead of typing the enter key twice, use “space after” or “space before” that you can find in the paragraph panel or (better) in your paragraph style panel. You will be able to control exactly the space you wish between paragraphs.
2. Re: Space between paragraphes
Steve Werner Mar 31, 2012 10:10 AM (in response to on5lb)If you're creating an eBook (exporting to EPUB—or Adobe Digital Editions as I think it reads in CS4), you should do most of our formatting with paragraph and character styles.
When exported to EPUB (or to HTML for that matter), all multiple paragraph returns are reduced to one, and all spaces are reduced to one.
As "jmlevy" pointed out, you want to use the Space Before and Space After attributes in your paragraph style to adjust the spacing.
3. Re: Space between paragraphes
on5lb Mar 31, 2012 11:34 AM (in response to jmlevy)Thanks jmlevy, for your help.
Actually, i'm not starting an eBook, but a technical manual (about 70 pages !) which i'll convert into PDF.
I'm not sure in understand exactly the procedure. (i'm from Belgium !).
Can you fing the time to show me the way to (step by step ?) using the paragraph style panel (which i did already).
It should be nice if could put the mouse between two paragraphs and adjusting the space by modifying the interline !
And thanks to Steve as well for his support.
Jean
4. Re: Space between paragraphes
Steve Werner Mar 31, 2012 12:12 PM (in response to on5lb)You don't put your mouse between two paragraphs. You select one of the paragraphs (the one above or the one below), and you use the Space Above or Space Below attribute. It's actually done very similarly in Microsoft Word.
Here are a couple pictures. Select a paragraph. Create its attributes for font size, leading (what you call "interline"), maybe a first line indent. From the Paragraph Styles panel, choose New Paragraph Style. I called mine Body Copy.
To add the space between paragraphs, go to the Indents and Spacing panel (on the left). Set the Space Below value as shown below:
I'm using picas and points (default in the US), but it would be the same if you were specifying millimeters or centimeters.
5. Re: Space between paragraphes
P Spier Mar 31, 2012 12:32 PM (in response to on5lb)If you don't want to add space to all paragraphs of a particular style, you can do it as a local override setting from either the Paragraph panel or the Control Panel:
Space before or afer are set in either the Patagraph panel or the Control panel paragraph fields. I've highlighted both in the illustration above.
7. Re: Space between paragraphes
on5lb Apr 1, 2012 3:40 AM (in response to jmlevy)Many thanks to all of you guys ! Steve :: Peter and jmlevy (merci pour le français) !.
This is a real technical support, i all "pick & place" it just in case....
I have to use so much various app's , so i'm confused each time i reuse one of them from several mounths ago.
It work fin (of course) and i can go on using Adobe stuff
Best regads and have a nice day.
Jean
