1. Re: Flash Player 11.2.202.228 no longer plays my audio flv
josh_on Apr 2, 2012 11:55 AM (in response to ppongsclub)We are having the same issue.
2. Re: Flash Player 11.2.202.228 no longer plays my audio flv
panicfarm Apr 2, 2012 1:24 PM (in response to ppongsclub)We are having the same issue: video flv play, but audio flvs do not.
Tried with a "start" parameter: Netstream.play('http://example.com', 0) , still does not work.
Everything works in 11.1 or less.
3. Re: Flash Player 11.2.202.228 no longer plays my audio flv
sinious Apr 2, 2012 1:24 PM (in response to josh_on)A lot of people are having the same issue. I put this on the same level of Adobe screwing up video for Radeons so video was just a flat green color with audio. They never fixed it for my old 4870 x2 nor my 4870 non-x2. I had to disable hardware acceleration to see video. Just google 'flash player green video' and you'll see what a mess flash player can make.
The last thread I asked this question became a debacle, let's see how it goes here. Why are you using a FLV container when you only have audio? Why not just use an audio format? The other thread was absolutely sure that FLV audio was somehow 'better compressed' than mp3. Is this the case here too or do you have some other reason for sticking audio-only in a video container?
4. Re: Flash Player 11.2.202.228 no longer plays my audio flv
panicfarm Apr 2, 2012 1:29 PM (in response to sinious)The reason we have for sticking to FLV is that we have 11 million users that have recorded hundreds of thousands of FLV files over the last three years, whose playback was just broken by 11.2. Are we going to transcode this huge user-generated file library to .mp3 now???
5. Re: Flash Player 11.2.202.228 no longer plays my audio flv
danielfrith Apr 2, 2012 1:38 PM (in response to panicfarm)Yup, same reason for me (I reported the same problem in another thread..). My users publish audio recordings which flash stores in FLV format. And so I have thousands of .flvs created like that. Plus I need the option to play back more or less as soon as recording is finished so converting to another format is not really an option.
6. Re: Flash Player 11.2.202.228 no longer plays my audio flv
sinious Apr 2, 2012 1:47 PM (in response to danielfrith)panicfarm~ Nope you're definitely going to advise users not to upgrade to the latest flash until a fix is made .
danielfrith~ FLV already has to compress the audio using a codec. The fact that it's in a FLV container doesn't make it any faster to encode (actually slower) nor faster to play back immediately. It's a misunderstanding of how containers and codecs work. You can merely look here to see how to unpack your FLVs to see what format they actually are, MP3 or AAC. You could have just encoded them to that format to begin with, disregarding the unnecessary step of the FLV container.
7. Re: Flash Player 11.2.202.228 no longer plays my audio flv
josh_on Apr 2, 2012 2:01 PM (in response to ppongsclub)Just in case this helps - here is the meta data that is coming in with a FLV file with no video:
metadata: duration=29.866 width=undefined height=undefined framerate=undefined videocodecid: -1
Still haven't found a fix, but if the FLV component can be made to work then I imagine that there is a solution in Actionscript. A setting on the flash.media.video instance. Ours was set to invisible on Audio only playback, setting it to visible did not help...
8. Re: Flash Player 11.2.202.228 no longer plays my audio flv
danielfrith Apr 2, 2012 2:13 PM (in response to sinious)@sinious, that really doesn't help me It's encoded client side by flash player (Nellymoser, in fact, not mp3), I want those FLVs to play back again without any server side processing which may incur a delay. Do you have a fix for this problem? If you want to discuss containers, please start a new thread.
9. Re: Flash Player 11.2.202.228 no longer plays my audio flv
danielfrith Apr 2, 2012 2:19 PM (in response to josh_on)A general question - is anybody with this problem actually using FMS? I'm using CRTMPServer, someone else mentioned Red5...
I wonder if/how the meta data in a FMS generated FLV differs...
10. Re: Flash Player 11.2.202.228 no longer plays my audio flv
josh_on Apr 2, 2012 2:59 PM (in response to danielfrith)The metadata I posted came from a FLV file generated by red5.
11. Re: Flash Player 11.2.202.228 no longer plays my audio flv
josh_on Apr 2, 2012 5:44 PM (in response to ppongsclub)From the 11.2 release notes:
http://helpx.adobe.com/flash-player/release-note/release-notes-flash-player-11_20120305.ht ml
"Netstream API briefly returns wrong value when video buffer is drained(2737056)"
That fix is probably the cause.
I switched to rtmp playback of our files - I still get the same Netstream.play.failed error.
12. Re: Flash Player 11.2.202.228 no longer plays my audio flv
danielfrith Apr 3, 2012 4:33 AM (in response to ppongsclub)I filed a bug report:
https://bugbase.adobe.com/index.cfm?event=bug&id=3156305
Perhaps others could add any comments or notes to it..
13. Re: Flash Player 11.2.202.228 no longer plays my audio flv
panicfarm Apr 3, 2012 11:46 AM (in response to danielfrith)@danielfrith:
can you check the .flv file that does not play with flvcheck ?
Do you have an audio-only .flv file that is created with FMS, that actually plays?
14. Re: Flash Player 11.2.202.228 no longer plays my audio flv
danielfrith Apr 3, 2012 1:03 PM (in response to panicfarm)Ok, I checked some files - some give me:
"Error: -9 Invalid FLV message footer."
others give me:
"Error: -5 File read error."
And yes, they all give one or the other error. Nethertheless, these played fine in older flash players.
No, I don't have access to FMS.
(I only speculated that FMS might work since someone over on a Red5 mailing list suggested it did: http://groups.google.com/group/red5interest/browse_thread/thread/994f6808bfd1a404/76383001 f6d45d16 )
15. Re: Flash Player 11.2.202.228 no longer plays my audio flv
panicfarm Apr 3, 2012 3:26 PM (in response to danielfrith)Given the fact that Adobe is transitioning away from Flash, I would not have high hopes that they will fix it then.
As a practical matter, the problem is in the empty video stream of the flv files. Ideally, the audio-only files should only have one stream, but they are saved with two streams, an empty video stream, and an audio stream.I removed the video stream like this:
ffmpeg -i src.flv -vn -acodec copy src-copy.flv
The resulting file is playable in 11.2.
(you need a very recent version of ffmpeg, or you will get white noise)
I am now modifying the red5 app to run this command right after the file is saved, and send a message back to the client on success.
After that, I will have to write a batch script that will go over the entire file library, find audio-only files, and remove video streams from them.
16. Re: Flash Player 11.2.202.228 no longer plays my audio flv
danielfrith Apr 4, 2012 2:51 AM (in response to panicfarm)Thanks, that's very useful to know.
17. Re: Flash Player 11.2.202.228 no longer plays my audio flv
SHI001 Apr 4, 2012 8:43 AM (in response to danielfrith)Similiar issue here!
On top of the playback issues I have embedded markers in my FLV to fire off actions in an elearning module - this really makes things bad!
Going back in to all the modules and adding some work-around is NOT really an option...there is something different about how audio only FLV's are being played now.
BTW - FireFox FF & other version of Flash Player DO work though w/o a single glitch! So problem seems limited to IE8 w/ 11.1.202.228 -
18. Re: Flash Player 11.2.202.228 no longer plays my audio flv
sinious Apr 4, 2012 11:09 AM (in response to SHI001)Perhaps programatically adding back in your cuepoints will solve your problem for now.
I still can't believe there's this many people using a video container for audio. It's like buying a tractor trailer to save on gas. Makes no sense.
19. Re: Flash Player 11.2.202.228 no longer plays my audio flv
eric1107856 Apr 5, 2012 9:11 AM (in response to sinious)Hi Sinious, im having the same issue, and like the first post said, we are using red5 to record the stream, and red5 just save this stream in a flv file.
im waiting any advice to solve this, but i think the solution should come from adobe/flashplayer, there are a lot of applications that reads a FLV sound file, and until
flashplayer 11.1 everyting works.
thanks
20. Re: Flash Player 11.2.202.228 no longer plays my audio flv
SHI001 Apr 5, 2012 9:31 AM (in response to sinious)The authoring tool for courseware I build limits my choices and FLV is the prefferred choice (ecspecially for adding event triggers). It always worked like a champ till the other day when machines started upgrading to 11.2.202.228.
Upon further investigation I did discover that some FLV's did work OK (they were coicindentally produced directly using Adobe Media Encoder) while the other FLV's that did NOT work were produced within the authoring tool itself (converts WAV's to FLV's).
So I decided to crack them both open and look for any differences...sure enoough I found one:
FLV's that did NOT work were created using MPEG 1 - level 3, The FLV's that DID work were created using MPEG 2 - level 3.
Could it be that MPEG-1 is no longer FULLY supported in 11.2.202.228 ?
Maybe this will help others... -
21. Re: Flash Player 11.2.202.228 no longer plays my audio flv
eric1107856 Apr 5, 2012 9:39 AM (in response to SHI001)Hi do you know a tool to convert FLV MPEG 1 - level 3 to FLV MPEG 2 - level 3 ?
thanks
22. Re: Flash Player 11.2.202.228 no longer plays my audio flv
ron hughes Apr 6, 2012 8:44 AM (in response to ppongsclub)We are experiencing the same thing. Using Red5 on backend I can record and stream back an flv through FP 11.1.102.55. The same flv cannot be played back on FP 11.2.202.228. I filed a bug report: https://bugbase.adobe.com/index.cfm?event=bug&id=3157899. Adobe responded that they looking into the issue.
23. Re: Flash Player 11.2.202.228 no longer plays my audio flv
mlee25 Apr 10, 2012 11:16 AM (in response to ppongsclub)If it's important to you that this bug be fixed, please let Adobe know, and vote:
24. Re: Flash Player 11.2.202.228 no longer plays my audio flv
eric1107856 Apr 13, 2012 6:59 AM (in response to ppongsclub)Adobe release a new version of flash player
11.2.202.233
http://www.adobe.com/support/flashplayer/downloads.html#fp11
but to me the error with playing flv audio files persist.
25. Re: Flash Player 11.2.202.228 no longer plays my audio flv
SHI001 Apr 13, 2012 7:29 AM (in response to eric1107856)Updated too, didn't do anything helpful to rectify my problem either!
26. Re: Flash Player 11.2.202.228 no longer plays my audio flv
OctavianN Apr 14, 2012 6:38 AM (in response to ppongsclub)We have the same issue.
The latest updates affects our FLV Audio Recorder customers (http://flvar.com). #
It seems to happen only with Red5. Our online demo of the audio recorder (http://flvar.com/demo/index.html) is connected to a FMIS hosting account on influxis.com and it works just fine.
27. Re: Flash Player 11.2.202.228 no longer plays my audio flv
ppongsclub Apr 15, 2012 5:45 PM (in response to ppongsclub)This bug is still present with the new update 11.2.202.233.
This bug appears not only using the rtmp protocol, but also when using the http protocol for <s:videoplayer source="http://url" /> as well.
28. Re: Flash Player 11.2.202.228 no longer plays my audio flv
sinious Apr 16, 2012 7:46 AM (in response to ppongsclub)I voted to add back in proper mpeg1 support. That's silly that they did that.
29. Re: Flash Player 11.2.202.228 no longer plays my audio flv
juztinius Apr 17, 2012 4:52 PM (in response to ppongsclub)We also have this problem at poodll.com . But after a lot of testing it seems the flv file recorded by Red5 in the older versions has a problem that previous flash was more tolerant of. When recording with the latest version of Red5 (NOT the precompiled version, you have to download the source and recompile it!!) audio only flv files playback.
So thats a good workaround for many people. But RTMPT in the latest Red5 version seems really unstable, so it may not work for us.
30. Re: Flash Player 11.2.202.228 no longer plays my audio flv
ron hughes Apr 19, 2012 12:12 PM (in response to juztinius)juztinius - Did you compile Red5 off of repository head, release candidate 1.0, or 0.9.1? Now that you've been running with it a few days, are you still satisfied that it solved the audio playback problem?
31. Re: Flash Player 11.2.202.228 no longer plays my audio flv
juztinius Apr 19, 2012 4:04 PM (in response to ron hughes)We compiled off the repository head. We have been running it for a few days on a separate site here in Nagasaki, and it has been working fine. We had an issue yesterday with one machine running 11.2.202.228 on 64 bit Windows 7 where playback failed and flash crashed, but after a reboot playback and flash were working again.
I looked through the Red5 changes since 1.0 RC1 was released and they have indeed done some work on how they write the flv file. So I am guessing thats the reason it works now. But RTMPT is sadly not reliable. So we are considering running two Red5 servers on our public site. One using the version compiled from repository head for RTMP connections and the old 1.0 RC1 for running RTMPT. I wish we had an ETA for the bug fix by Adobe.
We will be doing some more testing, and if any more information comes to light will post back here.
Justin
32. Re: Flash Player 11.2.202.228 no longer plays my audio flv
juztinius Apr 21, 2012 9:03 AM (in response to juztinius)Ok we are pretty confident now the version compiled from repository head works.
If you want you can test it over at our demo site, http://demo.poodll.com to see for yourself. (if you have problems, make sure you are using port 1935)
33. Re: Flash Player 11.2.202.228 no longer plays my audio flv
mike klem654 Apr 23, 2012 10:50 AM (in response to ppongsclub)FYI I was experiencing the same problem. I installed the Flash Player 11.3 beta and my problem is now resolved.
34. Re: Flash Player 11.2.202.228 no longer plays my audio flv
IanRae Apr 25, 2012 10:50 AM (in response to mike klem654)Yes, 11.3 beta is working for us as well, playing audio FLVs from red5.
35. Re: Flash Player 11.2.202.228 no longer plays my audio flv
mediaBrian May 4, 2012 7:23 AM (in response to IanRae)11.3 beta plays the audio FLVs. But NetStream events are not triggered properly. NetStream.Play.Complete now fails to ever trigger. Problems persist.... I hope the public releases fixed this.
36. Re: Flash Player 11.2.202.228 no longer plays my audio flv
ron hughes May 4, 2012 1:45 PM (in response to mediaBrian)Confirmed that the 11.3 beta released today (5/4) does not dispatch the NetStream.Play.Complete event. The previous 11.3 beta version exhibits the same behavior. I submitted a bug -- please vote: https://bugbase.adobe.com/index.cfm?event=bug&id=3182633
37. Re: Flash Player 11.2.202.228 no longer plays my audio flv
brendan7979 May 7, 2012 9:04 AM (in response to ron hughes)sinious,
Community Member
Apr 2, 2012 2:24 PM
The last thread I asked this question became a debacle, let's see how it goes here. Why are you using a FLV container when you only have audio? Why not just use an audio format? The other thread was absolutely sure that FLV audio was somehow 'better compressed' than mp3. Is this the case here too or do you have some other reason for sticking audio-only in a video container?"
**Any news on this? I'm pretty much spot-on w/ the same issue's. I've been searching the Google's of the world - Not happening ANYWHERE... Thanks!
B
38. Re: Flash Player 11.2.202.228 no longer plays my audio flv
SHI001 May 7, 2012 9:36 AM (in response to brendan7979)Reason I use an FLV for audio is pretty simple. I'm an elearning designer / developer and the software I use allows me to convert my audio files automatically in the software i use (Lectora) and utilize cue points to fire off events (such as to have bullets appear in sync with audio). This has worked for years in the past and it was only after the recent Flash player upgrades (inc. the 11.3 beta) that my problems began.
Audio plays partially and fires off events in what seems like once load time is met instead of when it really should. A real problem when you multiple things to keep in sync on a single page.The result is audio cuts-off prematurely and jumps forward etc...
I've tried several "fixes" without any sucess (both things listed here and as well as on the Trivantis Lectroa forum.The killer is that these were established modules that had been working perfect before users began upgrading their flash player (and we have many modules). From what research I have done it appears the FLV's compressed using older MPEG1 technology are a problem. Modules produced with a later version of the product (that utilized MPEG2) technology seem to work better. For me it's been a bit of a nightmare for weeks now!
BTW rolling back to 8.2 (for testing) did resolve my issues, so something is defiently different in the players ability to process the audio portion in the FLV. In this case newer is not better!
39. Re: Flash Player 11.2.202.228 no longer plays my audio flv
Mark Fritz Sutter May 29, 2012 11:41 AM (in response to ppongsclub)Ok, here is my ugly perl script I used to re-encode my flvs so that they work. You need to have ffmpeg and ffprobe in your current dir, specify the directory that you want to re-encode, and create a dir 'processedaudio' where it will put the processed files, and also have an image button_blue_play.png in your local directory. Basically, it makes a video out of the png of a few seconds longer than your audio (I found that necessary, to prevent cutting off), then adds the stream to your .flv. (it skips files that already have a video in them, and writes a list of those to 'videolist.txt')
use File::Copy;
$dir = $ARGV[0];
opendir LOCALDIR, $dir;
@dirlist = readdir LOCALDIR;
close LOCALDIR;
open(VIDEOSFILE,">videolist.txt");
foreach $file (@dirlist) {
if ($file =~ /flv/) {
print "got file $file\n";
$thisfile = $dir . "\\" . $file;
$newfile = "processedaudio\\" . $file;
`ffprobe $thisfile 2> test.txt`;
open(INFILE,"test.txt");
$havevideo = "false";
while ($line=<INFILE>)
if ($line =~ / Duration:/) {
#print "line $line";
$duration = $line;
$duration =~ s/.*Duration: //g;
$duration =~ s/,.*//g;
@myarray = split(":",$duration);
#print "minutes $myarray[1] seconds $myarray[2]\n";
$durationseconds = $myarray[1] * 60 + $myarray[2] + 6;
if ($line =~ / Video:/) {
$havevideo = "true";
close INFILE;
print "duration $durationseconds\n";
if ($havevideo =~ /false/) {
unlink("tempvideo.mpeg");
`ffmpeg -loop 1 -vframes 60 -r 29.97 -t $durationseconds -i button_blue_play.png -qscale 5 -an tempvideo.mpeg`;
`ffmpeg -i tempvideo.mpeg -i $thisfile -sameq $newfile`;
} else {
print VIDEOSFILE "$thisfile\n";
close VIDEOSFILE;
