HI,
I'm using flash builder and I have a strange error, this error occurs randomly and in order to fix it I do the following:
1) Remove the line where the error is
2) Save the file (so the workspace is rebuild), the problem is gone
3) Paste the line removed
4) Save again and there is no problem
Here's a piece of code:
protected function comboHandler(event:ComboEvent):void
u.profilo = Profilo(event.picked);
The ComboEvent picked is of type Object
The u is referring to a class where there is a getter and setter
public function get profilo():Profilo
return profilo_value;
public function set profilo(i:Profilo):void
profilo_value = i;
The error I get from Flash Builder is
1118: Implicit coercion of a value with static type listClass:Profilo to a possibly unrelated type listClass:Profilo.
Why do I get this error?
Is it related to flash builder?
no one?
It would be great if you share code snippets of the Profilo class
Here's the full Profilo Class
package testClass
import mx.collections.ArrayList;
public class Profilo
public var COD_CLIENTE:String = "";
[Bindable]public var COD_PROFILO:String = "";
public var DESC_PROFILO:String = "";
public var selected:Boolean = false;
private var FUNZIONI:ArrayList = new ArrayList();
public function Profilo()
public function getFunzione(i:int):String
var t:ProfiloFunzioni = ProfiloFunzioni(FUNZIONI.getItemAt(i));
return t.COD_FUNZIONE;
public function get funzioniCount():int
return FUNZIONI.length;
Its gives error in this line :
Its error related to type conversion. Refer the following example:
Application file:
<?xml version="1.0" encoding="utf-8"?>
<!-- http://bharatria.wordpress.com/ -->
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
<fx:Script>
<![CDATA[
import spark.events.IndexChangeEvent;
import testClass.Profilo;
protected function cb_changeHandler(event:IndexChangeEvent):void
// TODO Auto-generated method stub
var classRef:Profilo = new Profilo();
classRef.profilo = String(cb.selectedItem);
</fx:Script>
<s:ComboBox id="cb"
change="cb_changeHandler(event)">
<s:ArrayList>
<fx:String>Flash</fx:String>
<fx:String>Flex</fx:String>
<fx:String>Dreamweaver</fx:String>
<fx:String>Photoshop</fx:String>
</s:ArrayList>
</s:ComboBox>
</s:Application>
Profilo Class :
package testClass
public var profilo_value:String = "";
public function get profilo():String
public function set profilo(i:String):void
profilo_value = i;
profilo is not a string but an Object (of the class Profilo) so I can not do what's in the example...
