hello,
we have hundreds filenames with not compliant url characters such as spaces, quotes, comma and french accents.
As we decided to generate our KB on web server (Webhelp on a linux server), we search a way to rename all filenames in one shot.
Does it exist an option ? A script ?
Same problem with folder names
And I have seen an another issue: when we rename a folder from RH, pictures in this folder are not moved. Can we do a link ?
Infos:
RoboHelp 9.0.2.271
Projects imported from RH5 ... imported from old CHMs ... probably generated from MS Word documents.
Thank's !
you should not try doing such renaming through scripts as it will just change the file/folder name but would fail to update its references (links/Index/TOC etc.).
It would be one time effort of renaming the through UI you can also try using some UI automation tool to do that like Auto-it.
but work on a backup
Ashish
I was afraid of this.
Thank you for your answer.
