In Flash Builder I see a lot of options for debugging but no one for exporting an apk built as debug. The only way of exporting the apk that i could fine is "Export release build", but that will export the release version.
I want to export an apk that I can install in the device but which will run in debug mode. I used to be able to do that in Flash Professional but can't find it in Flash Builder
thanks
m.
I mean, anything like "export debug build" ??
matteosistisette,
If you want to debug an application on an Android device, you can do so by selecting Run > Debug Configurations from the Flash Builder menu. For detailed instructions, see http://help.adobe.com/en_US/flex/mobileapps/WSa8161994b114d624-33657d5912b7ab2d73b-7fe5.html.
The debug APK file will be available in the bin-debug folder of your project.
Hope this helps,
Mallika Yelandur
Flash Builder Community Help & Learning
Adobe Systems Incorporated
Can we build for Android Studio debugger? It's hard to debug for some native codes.
David
