Locked
Are these correct files for flash player 11.2.202.229?
Apr 02, 2012 Apr 02, 2012
Use Vista 32 bit with IE8
Installed new flash player 11.2.202.228 appears without problems. However, When I look at some of the files, they appear to look a lot different than previous one.
For example, the active x file use to look something like this
Flash11g.ocx
Now the new one looks like this
Flash_32_11_2_202_228.ocx
I also see FlashPlayerApp (an exe file)   in C:\WINDOWS\system32\
So should FlashPlayerApp show   in C:\WINDOWS\system32  ?
And is Flash_32_11_2_202_228.ocx the correct flash player for windows Vista 32 bit?
2.8K
Deleted User
Apr 04, 2012 Apr 04, 2012
Hi FPagain,
Yes, all the files are installed in the right place and FlashPlayerApp.exe should be in C:\Windows\system32.
-Stephen
I'm almost 100% sure I downloaded the version for Vista 32 bit and IE  browser, but these files look different than in the past so I makes me worried I  downloaded the wrong flash player
Do others see these items too?
Surely I'm not the only one noticing this???
Adobe Employee ,
Apr 03, 2012 Apr 03, 2012
From where are you downloading the installation files?
Guest
Hi FPAgain,
Yes, the files and file names that you mention are 100% authentic. If you are ever in doubt, right-click on the file and select properties. There, please check the Digital Signature tab. You should see Adobe Systems Incorporated as the signer of the binary.
To give you some background: The file names had to change as part of the new Background Updater (introduced with FP11.2). If you'd like to read more about the Background Updater, you can do so in this DevNet article and my blog post that answers some FAQs.
Hope this helps!
-Stephen
I knew that the files were legit from ADOBE, but was unclear if they were the right files for 32 bit vista with IE browser type. Was wondering if they were installed in the right place too
And FlashPlayerApp (an exe file)  should be located  in C:\WINDOWS\system32  folder?
Guest
Hi FPagain,
-Stephen
