This is the script i have in the Change event of a checkbox:
if (xfa.resolveNode("this").rawValue == "1" && SSN.isNull)
SSN.mandatory = "error";
app.alert("Please fill in the Dependent SSN portion of this form.");
else
SSN.mandatory = "disabled";
I also need this to verify that the "age" field is >= 1, if not return a message.
Total Likes
If you are using the change event, you need to bear in mind that the event fires BEFORE the user's input has registered in the object's .rawValue.
Either use xfa.event.newText instead of this.rawValue OR move the script to the clcik event (where this.rawValue is appropriate).
I haven't checked the script - too late,
Niall
Total Likes
This script does what i want, i just need to add the verify "age" field thing.
Total Likes
I am surprised you are getting the script to work where you are using .rawValue in the change event.
In any case, if you can to test the age field, then you have a couple of choices.
Hope that helps,
Niall
Total Likes
