1 2 Previous Next 44 Replies Latest reply on Mar 14, 2013 9:42 AM by mondain
    Flash Player 11.2.202.228 no longer plays my audio flv
    ppongsclub Level 1
      After updating to the new flash player (version 11.2.202.228) audio only flv files no longer play.
      air3.2 update too.
      In the source code below:
      red5 server is used for audio recording and playback
      ns.play() does not run.
      But, there is no problem with recording [ns.publish()]
      /**NetConnection**/
      private function setupNC():void{
         myServer = "rtmp://ip";
         nc = new NetConnection();
         nc.connect(myServer);
         nc.client = this;
         nc.addEventListener(NetStatusEvent.NET_STATUS, netStatus1);
         nc.addEventListener(AsyncErrorEvent.ASYNC_ERROR, asyncErrorHandler);
         nc.addEventListener(SecurityErrorEvent.SECURITY_ERROR, securityErrorHandler);
      /*** ns.publish ***/
      private function record_start():void{
         tbSoundFile = rndSoundFile(); //sound file
         initMic("0xff0000");
         ns = new NetStream(nc);
         ns.addEventListener(NetStatusEvent.NET_STATUS, netStatus2);
         ns.attachAudio(myMic);
         ns.publish(tbSoundFile, "record");
      private function record_play():void{
         var myClient:Object = new Object();
         ns.addEventListener(NetStatusEvent.NET_STATUS, netStatus3);
         ns.bufferTime = 5;
         ns.client = myClient;
         myClient.onMetaData = function(myMeta:Object):void {
             myDuration = myMeta["duration"];
          myClient.onPlayStatus = function(myPBstatus:Object):void{
              if(myPBstatus["code"] == "NetStream.Play.Complete"){
                  recordingState = "idle";
           mySoundFile = tbSoundFile;    //sound file
           ns.play(mySoundFile);
      private function netStatus3(event:NetStatusEvent):void {
           trace(event.info.description);   <<<<<<< (1)
            switch (event.info.code){
                  case "NetConnection.Connect.Success" :
                      nc.removeEventListener(NetStatusEvent.NET_STATUS, netStatus);
                      break;
                  case "NetStream.Play.Failed" :     <<<<<<<<<<< (2)
                       record_stop();
                       break;
      Trace results for event.info.description (1):
        playing and resetting <file_name>
        Started playing <file_name>
        undefined
        undefined
      Trace results for event.info.code (2):
      Netstream.Play.Failed
        1 2 Previous Next
