5 Replies Latest reply on Apr 6, 2012 7:05 PM by Marc Autret
    ScriptUI stroking a field
    Loic.Aigon Adobe Community Professional
      I need to red stroke fields. Inspite of the doc and this great thread : http://forums.adobe.com/message/4215908#4215908,
      I can't get it working
      field.onDraw = function()
                var gx = this.graphics,
                 pen = this.graphics.newPen (this.graphics.PenType.SOLID_COLOR, [1, 0, 0,1], 5);
                gx.drawOSControl();
                gx.rectPath( this.location[0] , this.location[1], this.size.width, this.size.height);
                gx.strokePath(pen);
      What am I doing wrong ?
      Best,
      Loic
        • 1. Re: ScriptUI stroking a field
          I finally got what I wanted with a workaround. First of all I could get the above snippet adding this line :
                    gx.drawOSControl();
                    gx.newPath();
                    gx.strokePath(pen);
          But the result wasn't the one I expected. The path was indeed drawn inside the text field area when I wanted it outside. Finally my cheat was to create a dummy group object on the back of the text field. Those both objects are placed into a stacked group. Then it's easy to set dimensions and background attributes for the dummy group and finally get what I wanted.
          var w = new Window('dialog');
          var gp = w.add('group');
          gp.orientation = 'stack';
          gp.alignChildren = ['center','center'];
          var dummyGp = gp.add('group');
          dummyGp.preferredSize = [102,52];
          dummyGp.graphics.backgroundColor = dummyGp.graphics.newBrush (dummyGp.graphics.BrushType.SOLID_COLOR, [1,0,0,1] );
          var tf1 = gp.add('edittext');
          tf1.preferredSize = [100,50];
          w.show();
          Hope it helps.
          Loic
          • 2. Re: ScriptUI stroking a field
            pkahrel Adobe Community Professional & MVP
            Nice one, Loic. But remember that on the Mac and on Windows, the stacked objects are drawn in a different order. So on Windows, your script shows just a red rectangle because the edit field is placed behind the rectangle.
            Peter
            1 person found this helpful
            • 3. Re: ScriptUI stroking a field
              Marc Autret Level 4
              Hi Loïc,
              About your workaround, why don't you simply create a Group having 1px margins—this depends on the stroke weight you need—and the desired background color, then add the EditText field within?
              Marc
              • 4. Re: ScriptUI stroking a field
                Hi Peter, Marc,
                Sorry for the delay, I haven't been warned of your posts and almost seen them by surprise.
                @Peter, that's the nasty one. The environment should be 100% macs but that's not a reason.
                @Marc, I thought margins deal with spacing inside the items. I gave it a try and the margin itself look much wider than requested
                If I set margins = 1, I should expect 1 px wide stroke. But it looks like it's three added :?Capture d’écran 2012-04-03 à 01.02.36.png
                Loic
                • 5. Re: ScriptUI stroking a field
                  Marc Autret Level 4
                  Hi Loïc,
                  Yes, it's a Mac thing. On Mac OS, the EditText widget is subject to a specific focus ring wich automatically allocates 2 or 3 additional transparent pixels all around the field! Hence, if the control is nested within a background-colored group, that color is revealed through this additional space.
                  From that point you need to apply two fixes:
                  (1) create a white subgroup between the outer group and the EditText to make sure that the revealed background fits the EditText background;
                  (2) make the EditText borderless to inhibits its own stroke.
                  Now to the code:
                  // ScriptUI EditText with custom border (Win & Mac)
                  var STROKE_COLOR = [1,0,0],    // red
                      STROKE_WEIGHT = 1,        // in pixels
                      FILL_COLOR = [1,1,1],    // white
                      INSET_SPACE = 3;        // in pixels -- Mac OS focus ring needs it >=3
                  var u,
                      w = new Window('dialog'),
                      gBorder = w.add('panel').add('group'),
                      gSpacer = gBorder.add('group'),
                      e = gSpacer.add('edittext', u, u, {borderless:true}),
                      bCancel = w.add('button', u, "Cancel"),
                      gx = w.graphics,
                      SOLID_BRUSH = gx.BrushType.SOLID_COLOR;
                  // Edit field settings
                  e.characters = 12;
                  gBorder.margins = STROKE_WEIGHT;
                  gBorder.graphics.backgroundColor = gx.newBrush(SOLID_BRUSH, STROKE_COLOR );
                  gSpacer.margins = INSET_SPACE;
                  gSpacer.graphics.backgroundColor  = e.graphics.backgroundColor = gx.newBrush(SOLID_BRUSH, FILL_COLOR );
                  w.show();
                  Hope that works.
                  Marc
