1. Re: Clarity Slider
dj_paige Apr 3, 2012 5:13 AM (in response to DV8OR1)I have read someone from Adobe say something similar to "The new clarity slider has twice the effect as the old one".
So, if you were using a clarity of 25 in the past, maybe you should try a 12. Or maybe you should continue to use Process Version 2010, which still has the old clarity slider
Do you really think Adobe will go back just because some people in a forum don't like it?
For what its worth, I like the new clarity slider, I think it is an improvement.
2. Re: Clarity Slider
-Agfaclack- Apr 3, 2012 5:15 AM (in response to DV8OR1)i do not agree.
i like the new one better.
keep in mind you now have to use a value of around 20 instead of 40 to get a similiar effect.
3. Re: Clarity Slider
john beardsworth Apr 3, 2012 5:21 AM (in response to -Agfaclack-)Also try using stronger Clarity values in combination with reducing the Contrast value.
4. Re: Clarity Slider
DV8OR1 Apr 26, 2012 10:18 AM (in response to dj_paige)There is more to it than just the strength of the clarity slider in LR4 - see here: http://www.keptlight.com/2012/04/lightroom-4-clarity-slider/
I use the clarity slider in negative as a quick fix for smoothing skin. In LR4 this is noit possible as it changes the exposure substantially.
And yes - if enough people complain about it perhaps Adobe will do something about it.
5. Re: Clarity Slider
Keith_Reeder Apr 26, 2012 12:01 PM (in response to DV8OR1)Not a fan of the PV2012 slider, I must admit - it's too heavy-handed and, as others have pointed out, tending too much towards faux HDR, something I detest.
