We have FMS interactive configured to do RTMP and HLS streaming. However the clips still can be downloaded through http://domain.name.com/vod folder. Is there a way to disable progressive downloads? While at it is there a way to disable HDS also? I want to allow HLS and RTMP only.
In that case just change HttpStreamingContentPath to correct location of the media folder under hls-vod tag. like this:-
<Location /hls-vod>
HLSHttpStreamingEnabled true
HLSMediaFileDuration 8000
HttpStreamingContentPath "<application-folder-path>/vod/media"
HLSFmsDirPath ".."
HLSJITConfAllowed true
Options -Indexes FollowSymLinks
</Location>
Restart Apache.
Reason for your data available for progressive dowload is because its there in webroot. Webroot/<extendend-path> is by default available to any client via http://server-name/<extendend-path> unless you have taken measures to protect it inside Apache's httpd.conf.
You can do one thing. Keep your content outside Apache's webroot. Say C:/myvideos/. for example there is a video there sample.f4v i.e C:/myvideos/sample.f4v
Now you can change the location "HttpStreamingContentPath" pointing to from "../webroot/vod" to "c:/myvideos/" under hls-vod inside httpd.conf (Apache/conf)
<Location /hls-vod>
HttpStreamingContentPath "C:/myvideos/"
HLSFmsDirPath ".."
</Location>
Or you can disable(modify) content availibilty by making appropriate changes unders in httpd.conf
<Directory "../webroot">
AllowOverride None
Order allow,deny
Allow from all
</Directory>
To disable HDS-Live, set "HttpStreamingEnabled" to false under hds-live location directive
<Location /hds-live>
HttpStreamingEnabled false
To disable HDS-vod, set "HttpStreamingJITPEnabled" to false under hds-vod location directive
<Location /hds-vod>
HttpStreamingJITPEnabled false
To disable HDS-vod offline fragmented content, set "HttpStreamingEnabled" to false under vod location directive
<Location /vod>
You need to restart the Apache server after making the changes to get them reflected next time..
Hope it help
Will this work?
AllowOverride None
Order allow,deny
Deny from all
</Directory>
I guess, yes .. but it may deny all request to webroot.. Even everything beyond FMS usage like your own hosted pages, FMS default index.html will not be allowed.. I hope you underrstand what all you are restricting as per your usage/requirement..
Ahh, yes you are right. This is not good.
I'm looking at VOD_DIR and VOD_COMMON_DIR options in fms.ini now. Tell me, if I do the following:
Put all my files under fms/applications/vod/media instead of fms/webroot/vod will HLS and RTMP work? Or do I need additional adjustments in httpd.conf?
<Location /hls-vod>
HLSFmsDirPath ".."
</Location>
Restart Apache.
Thank you. This works.
Note for others trying to achieve the same. You can also disable progressive downloads by adding the following to your httpd.conf:
<Location /vod>
AllowOverride None
Order allow,deny
Deny from all
</Location>
This way only links that start with http://yourdomain.com/vod will be disabled and you can still have access to Administration Console.
