Locked
How to Republish streams from one FMIS to another
Apr 03, 2012 Apr 03, 2012
Hi guys,
we are streaming 24/7 live from a number of FMLE's to FMS Interactive server to a livepkgr cloned app., and to our clients we stream both to Flash via rtmp and to iOS via HLS.
Since we want to introduce another server (to be able to serve more clients), the question is - hot to republish from one to another server so that both servers can stream rtmp and hls to clients?
We are already using the backup url in FMLE to stream to a backup server - this we do not want to change since the backup server is just that - backup, if the main server fails.
Could someone point me to a SSAS sample code that will do this (and work inside livepkgr existing main.asc which we did not change, except the "append" parameter which is changed to "record")?
947
Adobe Employee , Apr 03, 2012 Apr 03, 2012
I will suggest.
1. Create a app. Name it say ingestapp. Place a main.asc
application.onPublish = function(client, myStream) {
    trace(myStream.name + " is publishing into application " + application.name);
    // This is an example of using the multi-point publish feature to republish
    // streams to another application instance on the local server.
  // republishing to first server
        trace("Republishing the stream into livepkgr1/_definst_");
        nc1 = new NetConnection();
        nc
Adobe Employee ,
I will suggest.
        nc1.connect( "rtmp://localhost/livepkgr1" );
        ns1 = new NetStream(nc1);
        // called when the server NetStream object has a status
        ns1.onStatus = function(info) {
            trace("Stream Status: " + info.code)
            if (info.code == "NetStream.Publish.Start") {
                trace("The stream is now publishing");
        ns1.setBufferTime(2);
        ns1.attach(myStream);
        ns1.publish( myStream.name, "live" );
  // next server
        trace("Republishing the stream into livepkgr2/_definst_");
        nc2 = new NetConnection();
        nc2.connect( "rtmp://localhost/livepkgr2" );
        ns2 = new NetStream(nc2);
        ns2.onStatus = function(info) {
        ns2.setBufferTime(2);
        ns2.attach(myStream);
        ns2.publish( myStream.name, "live" );
application.onUnpublish = = function(client, myStream)
  ns1.attach(false);
  ns2.attach(false);
(You can write much better managed code .. It is just a sample)
2. Create two livepkgr application , livepkgr1 .. livepkgr2 .. In above code I assumed both are on same server, though you may change the server and keep the livepkrg application name same.
3. From FMLE, instead of publishing to livepkgr, publish to ingestapp .. else keep everything same.
4. From client subscribe to livepkgr1 and livepkgr2 and  to correct server..
so in this case, FMLE feed to ingest app and ingest app work as feeder to multiple livepkgr applications.. Hope this clarifies..
Regards.
Apr 04, 2012 Apr 04, 2012
Thank you Sir.
I'll try this when the time comes...
